Has anyone already configured their pywws and weather station to submit to Domoticz?
Would you be willing to share your config?
pywws posting to Domoticz
jimicek
Re: pywws posting to Domoticz
my pywws weather station was sending data to Weatherunderground, and Domoticz downloaded it back.
Now I created a pywws template and shell script to transfer weather data directly.
Virtual sensors of adequate type must be created, and their numbers filled in the shell script
This all is placed in my Synology NAS, for your implementation should be probably needed some path modifications
Here is the code:
1/ domoticz.txt template -should be placed along with others txt templates in pywws, and is invoked by placing the template into "logged"" section of weather.ini
2/ shell script pw2domo.sh, which takes data created by pywws and pushes to Domoticz (invoked by cron task)
Here is the code:
#raw#
T_OUT: #temp_out "%.1f" #
T_IN: #temp_in "%.1f" #
W_DIR: #wind_dir "%.0f" "0" "x * 22.5" #
W_AVE: #wind_ave "%.1f" "" "x * 10" #
W_GUST: #wind_gust "%.1f" "" "x * 10" #
H_OUT: #hum_out "%d" #
H_IN: #hum_in "%d" #
REL_P: #rel_pressure "%.1f" #
#hourly#
RAIN_H: #rain "%.1f" "" "x * 100"#
#daily#
RAIN_D: #rain "%.1f" #
#raw#
W_TXT: #wind_dir "%s" "-" "wind_dir_text[x]"#
#!/bin/bash
PATH=/opt/bin:/opt/sbin:/sbin:/bin:/usr/sbin:/usr/bin:/usr/syno/sbin:/usr/syno/bin:/usr/local/sbin:/usr/local/bin
#setup
host=192.168.1.22
port=8080
username=
password=
TOUTidx=213
TINidx=214
WDIRidx=218
WAVEidx=219
WGUSTidx=220
HOUTidx=221
HINidx=223
RELPidx=224
RAINidx=225
TOUT=$(cat /volume1/web/meteo/data/domoticz.txt | sed -ne 's/^T_OUT: \(-[0-9]*\.[0-9]*\).*/\1/p')
TIN=$(cat /volume1/web/meteo/data/domoticz.txt | sed -ne 's/^T_IN: \([0-9]*\.[0-9]*\).*/\1/p')
WDIR=$(cat /volume1/web/meteo/data/domoticz.txt | sed -ne 's/^W_DIR: \([0-9]\[0-9]\)*/\1/p')
WAVE=$(cat /volume1/web/meteo/data/domoticz.txt | sed -ne 's/^W_AVE: \([0-9]*\.[0-9]*\).*/\1/p')
WGUST=$(cat /volume1/web/meteo/data/domoticz.txt | sed -ne 's/^W_GUST: \([0-9]*\.[0-9]*\).*/\1/p')
HOUT=$(cat /volume1/web/meteo/data/domoticz.txt | sed -ne 's/^H_OUT: \([0-9]\[0-9]*\)*/\1/p')
HIN=$(cat /volume1/web/meteo/data/domoticz.txt | sed -ne 's/^H_IN: \([0-9]\.[0-9]\)*/\1/p')
RELP=$(cat /volume1/web/meteo/data/domoticz.txt | sed -ne 's/^REL_P: \([0-9]*\.[0-9]*\).*/\1/p')
RAINH=$(cat /volume1/web/meteo/data/domoticz.txt | sed -ne 's/^RAIN_H: \([0-9]*\.[0-9]*\).*/\1/p')
RAIND=$(cat /volume1/web/meteo/data/domoticz.txt | sed -ne 's/^RAIN_D: \([0-9]*\.[0-9]*\).*/\1/p')
WTXT=$(cat /volume1/web/meteo/data/domoticz.txt | sed -ne 's/^W_TXT: \([A-Z]*\[A-Z]*\)*/\1/p')
HIST=1
if [ "$HIN" -gt 60 ]
then HIST=3
fi
if
[ "$HIN" -ls 40 ]
then HIST=2
fi
HOST=0
if [ "$HOUT" -gt 60 ]
then HOST=3
fi
if
[ "$HOUT" -ls 40 ]
then HOST=2
fi
#output if you run it manually
echo "TOUT = $TOUT"
echo "TIN = $TIN"
echo "WDIR = $WDIR"
echo "WTXT = $WTXT"
echo "WAVE = $WAVE"
echo "WGUST = $WGUST"
echo "HOUT = $HOUT"
echo "HIN = $HIN"
echo "RELP = $RELP"
echo "RAINd = $RAIND"
echo "RAINh = $RAINH"
echo $HIST
echo $HOST
curl -s -i -H "Accept: application/json" "http://$username:$password@$host:$port/json.htm?type=command¶m=udevice&idx=$TOUTidx&svalue=$TOUT"
curl -s -i -H "Accept: application/json" "http://$username:$password@$host:$port/json.htm?type=command¶m=udevice&idx=$TINidx&svalue=$TIN"
curl -s -i -H "Accept: application/json" "http://$username:$password@$host:$port/json.htm?type=command¶m=udevice&idx=$WDIRidx&nvalue=0&svalue=$WDIR;$WTXT;$WAVE;$WGUST;0;0"
curl -s -i -H "Accept: application/json" "http://$username:$password@$host:$port/json.htm?type=command¶m=udevice&idx=$HOUTidx&nvalue=$HOUT&svalue=$HOST"
curl -s -i -H "Accept: application/json" "http://$username:$password@$host:$port/json.htm?type=command¶m=udevice&idx=$HINidx&nvalue=$HIN&svalue=$HIST"
curl -s -i -H "Accept: application/json" "http://$username:$password@$host:$port/json.htm?type=command¶m=udevice&idx=$RELPidx&nvalue=0&svalue=$RELP;5"
curl -s -i -H "Accept: application/json" "http://$username:$password@$host:$port/json.htm?type=command¶m=udevice&idx=$RAINidx&nvalue=0&svalue=$RAINH;$RAIND"
