Help with creating a HTTPs poll plugin (unifi)
jammiejammie
Hi Guys,
I'm trying to get a python plugin going. I need to poll a webpage that returns a JSON string that i need to parse.
I'm polling the status page of an Unifi controller and need to parse te json status page.
I used the http template from the wiki. But changing the URL to the unificontroller page results in status -1.
Does this framework support HTTPS ?
- Dnpwwo
Re: Help with creating a HTTPs poll plugin (unifi)
@jammiejammie,
Not yet I'm afraid, it is on the list though
jammiejammie
allright, thanx!
I will put this one in the fridge for now, will pick it up as soon as HTTPS is added.
jammiejammie
I'm wondering if there is an update regarding https compatibility of the python plugin.
edwin
Hi @jammiejammie,
If you have node-red installed, you can easily create a very crude proxy by tying together a http input, request and response. You would expose a local link like http://localhost:1880/myproxydata to data gathered from a https server.
Cheers,
Edwin
Cheers,
Edwin
Recent beta (git) on Arch Linux | Dashticz v2 (git) | RFLink 46.0 | Ikea Trådfri | P1 Smart Meter
jammiejammie
Well all i would need is a little work around that handles the ssl offloading.
Or... would it be possible to use the tcp socket plugin type and build the ssl layer inside the plugin? I'm not sure if the ssl is in the tcp layer or not.
mivo
for simple HTTPS requests you can sure use standard Python module like urllib.request:
https://docs.python.org/3.4/library/url ... ib.request
My toys:
Raspberry Pi 3 + UPS PIco HV3.0 A Stack
Minibian (Raspbian Jessie) + Domoticz beta
RFLink 433 Gateway, 1wire DS18B20 temp sensors (GPIO)
RaZberry module + 2x Comet Z-Wave + Z-wave socket
Plugins: WeMo Switch, UPS PIco HV3.0A on GitHub
jammiejammie
Well....
I want to use the python plugin framework for this, so i can't use the python https requests for this.
mivo
I am using urllib.request in my plugin for WeMo switch, becasue plugin framework Connection method is not suitable for WeMo - WeMo drops connection few seconds after HTTP request.
So you can wait until HTTPS will be developed, develop yourself, or use workaround
My toys:
I too have tried to create an HTTPs plugin in Python for ThinkEco's (mymodlet.com) interface to control my AC units. I have the 3 versions of the python script working with their API for status and control of the units, using urllib.request, Requests, and http (urllib2 for python3). All of the scripts work fine standalone, but dont work in the Domoticz plugin framework (Requests, as most of you know wont even load).
I think we sadly need to wait for HTTPs to be supported by Domoticz before we can move ahead. Otherwise, I need to create external LUA/Python scripts that control virtual switches....
mivo
Just to be sure - created simple plugin. Only opens page in onStart function and parse <title> element from it. Runs also from command line.
#!/usr/bin/python3
# HTTPS test Python Plugin Example
# Author: mivo
<plugin key="test-web" name="Test SSL web Python Plugin">
<params>
<param field="Address" label="Address" width="200px" required="true" default="www.google.com" />
<param field="Mode6" label="Debug" width="75px">
<options>
<option label="True" value="Debug" />
<option label="False" value="Normal" default="true" />
</options>
</param>
</params>
</plugin>
#import Domoticz - imported on end of file - if not started from command line
import urllib.request
from urllib.parse import quote
def onStart():
Domoticz.Heartbeat(60)
if Parameters["Mode6"] == "Debug":
Domoticz.Debugging(1)
url = Parameters["Address"]
with urllib.request.urlopen('https://' + url) as f:
output = f.read(500).decode("utf-8")
Domoticz.Log("HTTPS " + url + " page TITLE: " + _extract(output, "title"))
# Generic helper functions
def _extract(XML, tagName):
startTag = '<%s>' % (tagName)
endTag = '</%s>' % (tagName)
startPos = XML.find(startTag)
endPos = XML.find(endTag, startPos+1)
if ((startPos == -1) or (endPos == -1)):
return "'"+tagName+"' not found in supplied XML"
return XML[startPos+len(startTag):endPos]
# Command line function
def main():
print("Started from command line")
print("*" * 30 + "\n")
url = "www.google.com"
print("output Quoted:\n", quote(output))
print("output:\n", output)
print("HTTPS " + url + " page TITLE: ", _extract(output, "title"))
if __name__ == '__main__':
main()
else:
#import Domoticz - if not started from command line
import Domoticz
My toys:
Yes, urllib.request seems to work but I can't get my Domoticz version of my script to properly grab the CookieJar from a login. I have a standalone py3 that leverages the same code from the command line and works fine.
Sent from my SM-G955U using Tapatalk
Users browsing this forum: fdemees and 1 guest
