It's a graphical app, but it can be made to display remotely - ssh -X [email protected], and then run RFXFlash
Assuming you have all the X libraries that rfxflash/mono needs on the Pi, it will draw the output on your local display. There's no avoiding installing the requisite libraries on the rfxcom server though
1 x HP DL380 & KVM
1 x RPI
1 x RFXtrx433 V78
11 x LWRF Switches
1 x LIFX
2 x Echo Dots
6 x Byron PIRs
2 x Nexa PIRs
2 x Kodi
2 x ESP8266 MQTT
1 x GPIO/MQTT PIR
1 x GPIO(PWM)/MQTT LEDs
1 x GPIO(SPI)/MQTT LPD6803 LEDs
Lots of Node-Red glue
A little newbie question on firmware update to rfxcom... sure so,ebody can help me.
I see several downloads of the firmware for the 433MHz transceiver, named Type 1 and Type 2. what is correct one?
After download and unpacking i also see several increasing numbers, think this the version numbering mentioned before, correct?
How can i check my current installes firmware?
Just to be sure i am doing everything right and it works at least as before. Or os it like "mever chnage a running system"?
If you have a RAEX blinds motor than use Type2, else use Type1
The list of supported protocols in each Type is listed in chapter 2.2 of the RFXtrx User Guide
The current version is listed in RFXmngr.
Update the firmware only if you need the update. See the history file for the updates.
If you need an update than select the highest version. The older versions are only made available to be able to go back to a previous version in case the new version has broken something.
So what i understand ist that the firmware i need depends on the protocols i need.
I always thought it depends on the exact hardware model.
OK, the hardware model is more the type of transceiver and the frequency rfxcom lists the firmwares.
Is this understanding correct?
I would have a look again within some days and then give a suggestion for a Wiki entry as thanks for your help. Sure this would be interesting to other users, too.
Rohrmotor24 is a Blinds1 - T6 DC106 motor.
Use the same procedure with RFXmngr to pair the motor as you would do with the standard remote using the confirm command.
I don't know if Blinds1 - T6 DC106 is already implemented in Domoticz.
b_weijenberg wrote:Rohrmotor24 is a Blinds1 - T6 DC106 motor.
I get an error trying to pair with my Dooya. Somebody an idea? My RFXtrx433E Ext is flashed with firmware 240
