I hope someone can help me with this problem.
I got this :
pi@domoticz:~$ ls /sys/bus/w1/devices/
10-0008013ef41c 28-000005a0dfc4 w1_bus_master1
In Domoticz I have added 1wire
The 2 sensors doesn´t show up in Domoticz.
The logs tells that
2017-06-05 09:38:05.563 Error: 1-Wire system : error reading value from /sys/bus/w1/devices/28-000005a0dfc4
2017-06-05 09:38:13.863 Error: 1-Wire system : error reading value from /sys/bus/w1/devices/10-0008013ef41c
What can be wrong with my setup ?
Regards,
Micke
1wire no sensor values
- Target OS: -
Re: 1wire no sensor values
Have you setup the 1-wire with the config tool {raspi-config}.
Otherwise search the internet for wiringpi 1wire. There are some great tutorials including debugging.
As i remember correctly theres also a small wiki at domoticz.com/wiki.
Sent from my D6603 using Tapatalk
- Domoticz version: 3.5629
In domoticz go to setup, hardware and add 1-wire.
Rp3, youlesss, rfxcom, philips hue, dsb1820
