Needed help to set Door Contact
fvdijke
Domoticz version: 3.8000
Post by fvdijke »
Hi, i need some help because this small case is driving me mad!!!!
I have a magnetic doorcontact that, when the door opens it set the switch to open. This switch wil stay open even when the door is closed again.
So, i created a script that, when the switch is set to Open, it sets it back to Closed after 2 sec. Simple but meaningfull to me :)
This is the small script:
if (devicechanged['Berging'] == 'Open') then
   commandArray['Berging'] = 'Closed AFTER 2'
  print('Deur is nog niet gesloten')
Name of the switch=Berging
Name of the script=Deursluiter
If i manualy open the switch Berging, the script is triggerd:
2017-07-06 14:38:52.389 User: fvdijke initiated a switch command (602/Berging/On)
2017-07-06 14:38:52.391 RFLink Sending: 10;EV1527;057f03;0;ON
2017-07-06 14:38:52.878 RFLink: 20;54;OK;
2017-07-06 14:38:52.892 EventSystem: Script event triggered: Deursluiter
2017-07-06 14:38:52.893 (RFLink 433 MHz) Light/Switch (Berging)
2017-07-06 14:38:54.650 LUA: Deur is nog niet gesloten
But never closes the switch again.
What is wrong with my script???
(i tried all scripttypes, all, device, .... and i tried on/off iso open/closed)
Thanks in advance
Fainted
Re: Needed help to set Door Contact
Post by Fainted »
Unsure about the LUA but it seems that you should try to fix the device instead, have you tried to configure the device to send basic or binary commands?
fvdijke
Post by fvdijke »
Oke, fixed the problem.
Apparently the script is triggered with the value 'Open' (log reports On) but the switch need the value "Off"
I tried On in the scripts but that's not working.
Confused? Well, i am :)
CODE: SELECT ALL
   commandArray['Berging'] = 'Off AFTER 2'
2017-07-06 21:44:04.101 User: Admin initiated a switch command (602/Berging/On)
2017-07-06 21:44:04.102 RFLink Sending: 10;EV1527;057f03;0;ON
2017-07-06 21:44:04.596 EventSystem: Script event triggered: Deursluiter
2017-07-06 21:44:06.598 RFLink Sending: 10;EV1527;057f03;0;OFF
