looking for device that checks whether door is locked
curious
Post by curious »
Does anyone know of a device that checks whether the door is locked ?
Must be cheap :) and easy to install.
Note : I don't want to check whether the door is closed. And i do not want to completely replace my door lock (cilinder)
Hardware from Nuki etc are far to expensive.
Egregius
Domoticz version: v2024.7
Re: looking for device that checks whether door is locked
Post by Egregius »
I use a Fibaro door contact with a microswitch installed inthe hole where the lock goes in.
K3rryBlue
Domoticz version: V4.10xx
Post by K3rryBlue »
lots of options:
  • microswitch
  • reed contact (need to fix a small magnet to the deadbolt)
  • hall element
  • deadbolt sensor
  • Insteon 2845-222 Hidden Door Sensor
Domoticz V4.10717, RPi2 -> Linux raspberrypi 4.4.47-v7+ , RFXCOM - RFXtrx433 USB 433.92MHz ,RAZBERRY2 and OpenZWave USB Version: 1.4-2363-g1f10253-dirty
