dzVents 2.0 just got integrated into Domoticz (beta v3.8023)
dannybloe
Re: dzVents 2.0 just got integrated into Domoticz (beta v3.8023)
Interesting.. 32bits ARM is way behind indeed. No idea how that works.
Doler
Maybe 'forgotten' by @gizmocuz
Mark: Domoticz latest Beta on Virtual machine (Proxmox) running Debian Bookworm - Z-Stick 7 - RFXCom - P1 - SolarEdge - Dahua - Philips Hue - Docker - Zigbee2mqtt (latest, docker) via python plugin - Zwave-js-ui (latest, docker) - dzVents - Nodered
- heggink
- Domoticz version: 12451
Still 8015 on rpi
snif.
DASHTICZ 🙃
P1 meter & solar panel
DASHTICZ 🙃
dannybloe
Yes. It's a hand job. Giz will build it this weekend. But you can build it yourself of course.
ultratoto14
Hi Dannybloe,
Just build it myself and tried two kinds of script, one based on switch and it is triggered and the second one based on time and this one is not triggered.
In debug mode, everything is taken into account, but no trace of triggering events based on time.
Any clue ?
8025 build on RPI3.
Any clue ?
8025 build on RPI3.
dannybloe
Make sure you get the on-syntax right. Did you verify this?
In my video you can see an example (around 21:30 minutes):
ultratoto14
Ok, just created one with the editor, like in your video and was working. Updated my script compared to that one and it's ok also.
Thanks a lot. Did not keep the old one, do not know whats wrong. Grrrr
Thanks.
Thanks.
dannybloe
Probably a typo or something like that.
ultratoto14
Ok seems that i found it.
Perhaps i've got something wrong on my repo but it seems that the examples are not up to date in scripts/dzVents/examples:
https://github.com/domoticz/domoticz/bl ... evices.lua
The timer is in [] and on the editor example it's now {}.
jeanclic
Hello everyone,
any news on when we will have dzVents available on RPI ?
RPI3B (Domoticz 4.9700 + ~60 scripts) + RFXtrx433E (fw1020) + Z-Stick Gen5 + MySensors / RPI2B+ (RasPlex)
x1 Eth. wired tablet
x8 T/H Oregon / x1 T/H Bresser
x7 heaters / x2 QUBINO "Flush 1 relay"
x10 plugs / x15 contacts
x4 fibaro / x1 PIR
x4 fibaro / x1 PIR
dannybloe
Gizmocus was abroad but he planned to build it today (1/7).
jeanclic
Thanks dannybloe for your answer.
I am looking forward to test your dzVents ! -> seems very good (never tested the 1.0 version).
x4 fibaro / x1 PIR
x4 fibaro / x1 PIR
randytsuch
I just updated my Pi Domoticz beta version, and it is now 8027
And indeed I see dzvents on the events page so seems pi users can now update and use the new dzvents.
edit
dzvents is also now on the setup/settings/other page
edit
jeanclic
got it too ! thanks Gizmocuz !
x4 fibaro / x1 PIR
x4 fibaro / x1 PIR
Doler
Got it running too (thanks @gizmocuz, @dannybloe), just noticed that Log Level setting doesn't represent the chosen value (after Apply Settings).
Mark
Mark
randytsuch
One comment.
If you use the domoticz events editor (which is very convenient), the example still uses [] for definitions instead of the new convention ()
Randy
Randy
- heggink
Some people appear to have issues (high cpu) with 8027 on rpi3. Anyone without these problems on rpi3?
DASHTICZ 🙃
DASHTICZ 🙃
Doler
No high CPU here, CPU is around 5%. Busy migrating from dzVents 1.02 to 2.0, no problems so far.
Mark
Mark
jeanclic
The 3.8034 beta has been released this morning, fixing the cpu usage a bit.
On my setup, there is stil issues when I activate dzVents, even if I keep the logs to "silent"...
On the 3.8027, I had 100% cpu usage or higher, except when I disabled all event system, not only dzVents...
x4 fibaro / x1 PIR
x4 fibaro / x1 PIR
dannybloe
Interesting.. running 3.8025 on my Pi3 and it hardly has any cpu usage here.
