Blocky script doesn't work like expected...
Nautilus
Re: Blocky script doesn't work like expected...
Post by Nautilus »
Lebo2d9 wrote:Hi,
I have also a strange behavior with a nested if else-if
The 2 write to log are always executed.
Is this normal or have I done soemthing wrong?
K3rryBlue wrote:Seems that the structure is correct. Both conditions if vakanie=off and else if vakanie=on are different, it should never execute both. In either case if one is true the other is always wrong. Unless "on/off" is not valid for this switch.
The issue is most probably the simple (yet disappointing) fact that nested if's do not work in Domoticz's Blockly implementation (as it has been covered in numerous of these threads discussing various Blockly issues in Domoticz :D). If you write the logic with just one "if - else" then it should work (i.e. add the the first condition to both of the nested conditions to remove the first condition fully)...
Lebo2d9
Domoticz version: L stab
Post by Lebo2d9 »
Hi Nautilus,
I have solved it this way
Thx for the replies
Koen
Domoicz on RPI3 (wifi) directly connected 3x ds18b20 for CV temp, Evohome (9 zone), 1 remote 220V switch based on ESP-12. RFXtrx433E, 16x AMST-606, 5 Somfy RTS motors
Domoticz on RPI3(wifi) as slave for terraruim control
More to come
Kubiekdriehoekje
Post by Kubiekdriehoekje »
Like Spitfire and others stated before else-if logic is broken:
The following example is how it should work:
PRE:
	x=0
	y=0
RUN 1:
	x == 0 && y == 0
	x -> 1
RUN 2:
	x == 1 && y == 0
	y -> 1
RUN 3:
	x == 1 && y == 1
	x -> 0
	y -> 0
But instead it behaves like this example:
PRE:
	x=0
	y=0
RUN 1:
	x == 0 && y == 0
	x -> 1
	x == 1 && y == 0
	y -> 1
	x == 1 && y == 1
	x -> 0
	y -> 0
tjerk
Domoticz version: 4.9700
Post by tjerk »
I'm facing the same issue/bug with nested if statements as described in viewtopic.php?f=62&t=16455#p126119
After reading multiple threads (viewtopic.php?f=62&t=16271) I'm not using nested blocks anymore. Would be nice to have this feature in the future ;-)
Example which triggers both error logs:
Example nested blog with bug.png (90.49 KiB) Viewed 458 times
