dpkg problem
ropske
- Domoticz version: V3_8394
dpkg problem
i want to install some things(python, php,...) on my Pi3 running with Domoticz
but when i do for example:
sudo apt-get install php5-mysql i'm getting this error:
Bezig met het inlezen van changelogs... Klaar
Extraheren van sjablonen uit pakketten: 100%
Voorconfigureren van pakketten ...
dpkg: onherstelbare fatale fout; er wordt gestopt:
bestand met de lijst bestanden van pakket 'dpkg' heeft geen afsluitend regeleinde
E: Sub-process /usr/bin/dpkg returned an error code (2)
someone has any idea please?
- Egregius
- Domoticz version: v2024.7
Re: dpkg problem
Why is your system in Dutch? Would have been easier with a English version to Google the error.
Maybe this is a solution?
http://www.linuxquestions.org/questions ... ne-271118/
ropske
Re: dpkg problem
i tried allmost everything they say, some say complete reinstall is the best, because there will allways be somewhere other corrupted files.
really don't know how this comes, allready 3th time (2x on my old pi, now 1st time on my pi3)
ropske
Re: dpkg problem
yeah, what i was affraid off happened now, the Pi3 is not booting anymore, again a corrupt SD card.
3th now allready, pfff
is there anything that can be done to work without that SD card ?
- Egregius
Re: dpkg problem
Buy a good sd? Always shutdown before power off?
All Pi's still run on their first SD card here.
Only thing special I do is set /var/log as tmpfs so logfiles aren't written on SD.
ropske
Re: dpkg problem
Its allways a expensive and good one i buy.
Now im booting from usb, maybe that will be better than it is now.
My pi has never been shutdown by plugging out the supply voltage, allways by a reboot or shutdown.
ropske
Re: dpkg problem
It is the original one, what one are you using?
- Egregius
Re: dpkg problem
A 12-48VDC - USB converter from China or Hong Kong for 2 Pi's, other 3 have 'normal' 2,5A power supply.
I'm just thinking out loud... When your power supply is at it max to handle a Pi3 and you connect also a Zwave stick, a usb stick, a rfxcom,... maybe it's just to much for your power supply.
ropske
Re: dpkg problem
just checked my power supply, 5VDC/2500mA so should be enough i think?
What devices are on my Pi3? => Aeon Zwave Stick Gen5 and that's it
my rfxcom is on my older Pi+B
maybe i try with a ssd hd instead of SD?
ropske
Re: dpkg problem
I ordered a ssd usb HD
I will try it with this device, hopefully i dont have problems anymore
Users browsing this forum: Bing [Bot], Google [Bot] and 1 guest
