Plotly script combine charts
devros
Post by devros »
Hello all,
made simple script (im not python expert) because i want one chart with my energy consumption (i have owl energy meter) and solar saving (i use json values from web http://www.shinemonitor.com/) in one graph.
here is my result Image
i wrote python script, in domoticz setup dummy device and script is fired everymidnight to update values. Also created custom html links page in domotictz custom menu (tried directly link iframe but without succes)
1/so you need two idx that you want to compare (i used it by days, but should be easy to modify...), modify IP adress and user and pass
2/ install plotly (sudo pip3 install plotly)
3/ register plotly (more info https://plot.ly/python/getting-started/
4/ creaty file with this script
thats all ....
#!/usr/bin/python3
try:
  import plotly.plotly as py
  import plotly.graph_objs as go
except ImportError:
  print ('Plotly ERROR')
import json
import requests
from requests.auth import HTTPBasicAuth
idx_total = '220'
idx_solar = '218'
# READING DOMOTICZ CALUES
urltotal ='http://XXXXXXXXXXXXX:XXXX/json.htm?type=graph&sensor=counter&idx=' + str(idx_total) + '&range=month&method=1'
urlsolar ='http://XXXXXXXXXXXXX:XXXX/json.htm?type=graph&sensor=counter&idx=' + str(idx_solar) + '&range=month&method=1'
jsontotal = requests.get(url=urltotal, auth=HTTPBasicAuth('USER', 'PASS'), timeout=5).json()
jsonsolar = requests.get(url=urlsolar, auth=HTTPBasicAuth('USER', 'PASS'), timeout=5).json()
hodnoty_total = jsontotal['result']
datumy_total = (', '.join(d['d'] for d in hodnoty_total))
datumy_total_l = [str(x) for x in datumy_total.split(',')]
hodnoty_total = (', '.join(d['v'] for d in hodnoty_total))
hodnoty_total_l = [str(x) for x in hodnoty_total.split(',')]
hodnoty_solar = jsonsolar['result']
datumy_solar = (', '.join(d['d'] for d in hodnoty_solar))
datumy_solar_l = [str(x) for x in datumy_solar.split(',')]
hodnoty_solar = (', '.join(d['v'] for d in hodnoty_solar))
hodnoty_solar_l = [str(x) for x in hodnoty_solar.split(',')]
hodnoty_solar_float = [float(i) for i in hodnoty_solar_l] # convert to float
hodnoty_total_float = [float(i) for i in hodnoty_total_l] # convert to float
def graf():
  layout = dict(title = 'Energy',
                paper_bgcolor='rgb(255,255,255)',
                plot_bgcolor='rgb(229,229,229)',
                xaxis = dict(
                               title = 'Months',showgrid=True,),
                yaxis = dict(title = 'Kwh',showgrid=True,rangemode='nonnegative'),
                legend=dict(x=0,y=1,bgcolor='rgb(229,229,229)'),
                barmode='stack'
  trace0 = go.Bar(
      x = datumy_total_l,
      y = hodnoty_total_float,
      name = 'Energie celkem',
  trace1 = go.Bar(
      x = datumy_solar_l,
      y = hodnoty_solar_float + hodnoty_total_float,
      name = 'Solar energy',
  data = [trace0, trace1]
  fig = dict(data=data, layout=layout)
  py.plot(fig, filename='basic-line')
graf()
