No succes with Aeotec ZW130
Quax1507
Post by Quax1507 »
I received my Aeotec ZW130 "Wallmote" today but can not get it working.
I included the device and it was recognized correctly. I also added device 1 (Razberry Controller) to association Groups 1-9.
I then tried to learn light/Switch without success :(
Anybody got this working?
Quax1507
thorian
Domoticz version: 2.2563
Re: No succes with Aeotec ZW130
Post by thorian »
I got one too and:
- it is discovered and added
- if you press any button, the zwave log says:
2017-02-08 22:48:42.797 Error, Node048, Cannot find endpoint map to instance for Command Class COMMAND_CLASS_CENTRAL_SCENE endpoint 0
2017-02-08 22:48:42.797 Always,
2017-02-08 22:48:42.797 Always, Dumping queued log messages
2017-02-08 22:48:42.798 Always,
2017-02-08 22:48:42.798 Always, End of queued log message dump
Looks like we need to go to open-zwave developer who added Wallmote...
Open-Zwave version: 1.4-2228-gbce4a88-dirty
thorian
Post by thorian »
OK, so open-zwave will support the COMMAND_CLASS_CENTRAL_SCENE pretty soon, so we can count on some development here.
Quax1507
Post by Quax1507 »
That's good to hear :-)
rjay
Post by rjay »
Following, really wanting to get Wallmote, they look so useful for different tasks but had posted earlier and was told they weren't compatible yet.
Please update the thread once you have working :)
thanks
methinx
Domoticz version: 4.9700
Post by methinx »
I want one too. Not sure if it's working yet, but i can find it in the openzwave database:
https://github.com/OpenZWave/open-zwave ... /zw130.xml
Edit: acoording to the last post on this page it should be working: https://github.com/OpenZWave/open-zwave/pull/1125
not sure if domoticz is already updated with this version of openzwave
Raspberry Pi 3 + RLink + Aeon Labs Gen 5 USB + 4 Relay board on GPIO + Fibaro wall plug + 2x Neo coolcam wall plug + 2 Eurodomest power outlets + 2x fibaro FGS-223 double switch.
rjay
Post by rjay »
I see you found my other thread on this;
https://www.domoticz.com/forum/viewtopi ... 24&t=16372
yeh not sure, I suppose one way to test is to install the latest beta version of Domoticz and see if you have functionality?
YcKe
Post by YcKe »
The functionality is not yet merged in openzwave with the main source which means it's also not available in domoticz yet ;).
Keep an eye on the pull request, they are probably testing the functionality more thoroughly.
Greetz YcKe
rjay
Post by rjay »
Thanks! if someone sees it in the pull requests before me can they post up on one of the threads? either mine or this one. Also if some crew that have them setup in Domoticz want to post up some screenshots of the functionality I would be pretty keen to see that to :)
soetew
Post by soetew »
Anyone news on this?
Frixzon
Post by Frixzon »
Any update on this matter?
Frixzon
Post by Frixzon »
The same discussion is ongoing in this thread: viewtopic.php?f=24&t=16372&start=40
Users browsing this forum: Amazon [Bot], Bing [Bot] and 1 guest
