Anyone can help me here?
Thanks in Advance!
Sorry for the off-topic. I've tried to make a reliable "presence" check for my robot mower for a few times now. First with z-wave magnet sensor, but the issue was range (ok, could do something about that but the price/effort in current situation would be a bit high) and then with a microswitch attached to Nexa WBT-912 which has enough range, but the return mechanism in the microswitch is so strong / switch is so sensitive that the switch "opens" by itself soon after the mower has docked. So the question, what is your weapon of choice and how have you been able to make it reliable?Cloud wrote:Havent found anything about this. I try to check a virtual dummy text field for a specified value and cant get it too work.
Thanks in Advance!
Hi Lebo2d9,Lebo2d9 wrote:I do this with a user variable
Thanks! Yes a wifi-connection would be nice, but no retrofits available for a Robomow that I can see of. Maybe need to experiment with the magnet switch still or try if a z-wave power plug would give different readings when mowing, charging & idle (range should be better for a powered device, but remains to be seen whether there is notable consumption difference for idle / mowing, I guess there should be though).Cloud wrote:@Nautilus i have an Gardena mower with an wlan module (robonect) so i can just ping the module for a presence check. But i think a z-wave magnet sensor woud be the best bet if its possible with the mower.
<robonect>
<successful>true</successful>
<name>XXXXXXX</name>
<status>
<status>17</status>
<stopped>false</stopped>
<duration>29636</duration>
<mode>0</mode>
<battery>100</battery>
<hours>1234</hours>
</status>
<timer>
<status>2</status>
<next>
<date>25.09.2017</date>
<time>06:00:00</time>
<unix>1506319200</unix>
</next>
</timer>
<wlan>
<signal>-95</signal>
</wlan>
</robonect>Users browsing this forum: No registered users and 1 guest
