Is there any way with blocky to achieve this result:
I have a room with 1 door and 3 windows.
All have contact sensors.
I want to send a notification when the door OPENS *and* 1 or more of the windows are opened. So, I don't need a notification when alle windows are closed and the door opens.
Check several contact sensors before notification
- StanHD
Re: Check several contact sensors before notification
Like this ?:-
Python:- Broadlink RM2, Sonos
mikkelnl
OMG, why didn't I think of that
Thanks, gonna try this
mikkelnl
Oh one more thing... would it be possible to add a counter to this, to avoid the notification when the door closes immediately?
So for instance: I want such a notification when the door stays open for 3 minutes? And not have a notification when the door closes before/during these 3 minutes?
- StanHD
I believe there is a way to do this with a variable or a dummy switch. But I'm not sure, sorrymikkelnl wrote:Oh one more thing... would it be possible to add a counter to this, to avoid the notification when the door closes immediately?
sion
I think Lua would be be best way do achieve this, but you could try this: ( I'm not sure if it will work though )
Create a dummy switch. For examples sake call it x.
Replace the door contact in your current blocky with x.
Now make a new blocky.
If door = open
Set x on after 180 seconds.
Else if door = closed.
Set x off.
I think setting x off will stop the countdown to setting it on. But I could be wrong
If door = open
Set x off.
running domoticz 3.4834 on rpi2, with
Hue bridge / bulbs.
lightwave rf sockets, mood controlers, sensors & contacts.
Home bridge / Siri.
Ha bridge / echo Alexa.
Hard wired alarm system - setting home / away status.
Next: harmony hub.
Hue bridge / bulbs.
Home bridge / Siri.
Next: harmony hub.
