Request for new TypeNames
jeroenst
Domoticz version: V3.7976
Post by jeroenst »
I would like to have typenames "Watt" and "Frequency" as they are part of smartmeters and solar inverters.
For now I will use typename "Custom" instead, giving me the wrong precision and wrong icon.
Dnpwwo
Re: Request for new TypeNames
Post by Dnpwwo »
@jeroenst,
TypeNames are just short cut for existing functionality.
If you want them added then you will need to supply the Type and SubType combination that will work.
EDIT: For Watts I believe you can use the TypeName "Usage"
jeroenst
Post by jeroenst »
Dnpwwo wrote:@jeroenst,
This is a little odd, because with a solar inverter the watts are not used but provided..
Is there a list of available types and subtypes? I couldn't find them till now...
Dnpwwo
Post by Dnpwwo »
@jeroenst,
The list of types and subtypes is in hardwaretypes.h, you will need to find that on github.
The plugin framework uses the follwing:
					else if (sTypeName == "Usage")
						self->Type = pTypeUsage;
						self->SubType = sTypeElectric;
for Watts bases devices
