Just today at the Action (in Netherlands) I saw this camera
http://maxxter.biz/default.aspx?op=prod ... em&id=9357, at a reasonable price. I understand it will not be a top performer, but will this work within Domoticz?
Only found this information online:
- Spoiler: show
- ACT-IPC-01
Rotating HD WiFi camera
CAPTURE EVERYTHING
•720p High Definition video
•Easy WiFi configuration with your smartphone
•Free apps for Android and iOS
•Perfect for monitoring your office, home, warehouse, etc.
Features
HD 720p indoor WiFi IP-camera with built-in microphone, speaker
WiFi function - easily connect the camera to your network via your smartphone or tablet
LAN port for connecting to wired network
Practical microSD slot for easy video recording and capturing snapshots
Free mobile apps allow you to monitor your camera from all over the world via internet
Rotates up to 350° horizontally and tilts up to 90° vertically
Motion detection and alarm alerts by e-mail
Place it on any flat surface, or easily mount it to a wall or ceiling
Specifications
Interfaces: WiFi: 802.11 b/g/n, RJ45 LAN
Image sensor: 1/4'' CMOS 1 Mega pixels, 3.6 mm lens system, F = 2.0; 90 degrees angle of view
Video resolution: 30 fps at 1280 x 720, 640 x 360, 320 x 180
Video format: H.264/MJPEG
Sound SNR: 48 dB
Electronic shutter speed: 1/50 - 1/100000 second
Web-protocols supported: TCP/I, UDP/IP, HTTP, SMTP, FTP, DHCP, DDNS, UPNP, NTP, RTSP, ONVIF
Built-in speaker
Built-in IR backlight and IR-CUT filter
MicroSD card up to 64 GB supported
Power consumption: 5 VDC up to 2 A, no battery inside
AC power adapter: 100 - 240 V AC input, 5 V DC output up to 2 A
Dimensions: 120 x 120 x 135 mm
Weight: 0.3 kg
Operating conditions: -10 - 50 Celsius degrees at 10-85% humidity
FOR INDOOR USE ONLY
Package contents
Camera
Power adapter
