Hello, I'm developing a quite complex script with several global variables that I need to use every time when the event gets triggered. It's kind of reference counter that I want to use to make certain decisions in the script. For that reason I have instantiated and initiated the GLOBAL variables at the top of the script (TestVar = 0) and increase in the script. See example below:
TestVar = 0
commandArray = { }
If (TestVar == 0) then
[Do action 1...]
TestVar = TestVar + 1
DoFunction(TestVar)
return
This should work in C-code, HOWEVER I have the problem that TestVar is always initialized to 0 in every event trigger. And as a result, the else-statement with DoFunction(TestVar) is never reached. I found a workaround by using a User Variable, but this is not a very elegant solution as I have many of these variables, including some array's.
So, does anybody know how the value of global variables can be initialized once and then retained in each event trigger?
Many thanks!
How to use global variables ??
- emme
- Domoticz version: latest
Re: How to use global variables ??
why don't use UserVariables instead ?
"We always done this way"
PimJanse
Because I see UserVariables as variables that provide "interaction" with the user. This is great, because it gives me the ability to set parameters for my script, or read actual values.
However, in my case I need persistent variables to let my script work - without any need for user interaction. I agree that using UserVariables is an option, but not ideal because it will make the real UserVariables (with interaction) kind of unfindable because there are so many.
So, is there a possibility anyway to initiate variables (local or global) once and let them keep their value each time the event script is triggered?
