Fibaro wallplug settings gone after update Topic is solved
Keleos
Hello everyone,
after updating my Domoticz (beta) version I'm not able to configure my fibaro wallplug. Before this update I was able to change a lot of settings (like the led color et al.
How can I get back these options?
edit)
Descriptions says:
FIBARO System Unknown: type=0602, id=1001
edit)
Greetings
Kel
EDIT: To everyone interested: the solution is to delete / rename the zwave config file so every device is loaded with its new modules.
https://www.domoticz.com/forum/viewtopi ... 90#p139271
edit)
Descriptions says:
edit)
Greetings
Kel
YcKe
Re: Fibaro wallplug settings gone after update
Hi keleos,
What is the domoticz version you are running? Make sure you are running the beta version as the latest stable might not contain configuration for the wall plug.
Greetz YcKe
Greetz YcKe
guantolento
- Domoticz version: LastBeta
Any news about this? ??
Inviato dal mio GT-I9301I utilizzando Tapatalk
Master (pi3) - MB sensors + Dummy + Sysfs gpio + 1 NodOn MSP-3 + 1 Aeotec DSB28 Energy Meter + 3 Danfoss RS Room + 7 Danfoss Z Thermostat + 1 Swiid Inter + 9 FGS222
Slave01 (pi2) - MB sensors + Dummy + Weather Underground + 2 FGS223 + 1 FGWPE/F
YcKe
You are experiencing the same issue? If so, can you reply on the question above.guantolento wrote:Any news about this? ??
Greetz YcKe
Keleos
Hi YcKe,
thank you very much for your response. I use the latest beta version (Domoticz V3.7969).
The strange thing: the plug was configurable within an earlier beta version and after an update all settings are gone. Now I'm only able to rename it and set "Abfragemodus einschalten" (the checkbox bellow the name field)
Greetings
Greetings
YcKe
Hi Keleos,
Just updated my system also to the latest version and I'm not experiencing this problem.
Can you verify that the config file fgwpfzw5.xml is available in your OpenZwave config directory(config/fibaro/fgwpfzw5.xml)?
Kind regards,
YcKe
Kind regards,
YcKe
Keleos
Hi YcKe,
yes, it is there. It also is not empty... Maybe the type (0602 ?) is not recognized correctly?
Greetings
Kel
Greetings
Kel
YcKe
That should not be the problem, I have the same one installed here.Keleos wrote:Hi YcKe,
Greetings
Kel
Can you verify that the device is present in the config/manufacturer specific.xml file?
(Try downloading them again from the open zwave github)
If that's not the case, try changing your language to English. Some cases I've seen that it sometimes fails over special characters.
Greetz YcKe
Keleos
Hi YcKe,
Thank you very much for your patience.
How do I find out if the device is present?
Is there an ID I have to look at?
I've done a diff to the file online and there is no difference between my file and this one:
https://github.com/OpenZWave/open-zwave ... wpfzw5.xml
I also changed the language back to englisch, but the problem still exists.
Greetings
Kel
Do you mean the file "fgwpfzw5.xml"?Can you verify that the device is present in the config/manufacturer specific.xml file?
Greetings
Kel
YcKe
Hi Keleos,
In the config base folder, on folder back from the fibaro config folder, you will find an xml file called manufacturer specific.xml.
Check if the config file is registered there and your hardware id matches.
In the meanwhile, a new openzwave version was added to domoticz beta. Try updating to the latest version.
Greetz YcKe
Greetz YcKe
Keleos
Hi YcKe,
I've found the config file and also the line with the right type and id:
<Product type="0200" id="1000" name="FGWPE/F Wall Plug" config="fibaro/fgwpe.xml"/>
<Product type="0602" id="1001" name="FGWPE/F Wall Plug Gen5" config="fibaro/fgwpfzw5.xml" />
<Product type="0800" id="1001" name="FGMS001 Motion Sensor" config="fibaro/fgms.xml" />
Today I also updated Domoticz to V3.8000 - but the Wall Plug is still not configurable
Greetings
Kel
Greetings
Kel
YcKe
Hi Keleos,
This is a quite weird issue..
Can you check with the inspect of your browser if Javascript errors are thrown?
Can you check if the permissions of the config file is correct?
Are you running domoticz on a raspberry pi?
Greetz YcKe
Greetz YcKe
Keleos
Hi YcKe,
I know, that is really strange
Chrome does not throw any errors. But I've checked the network traffic und there is a request for getting all settings at once:
ipOfDomoticz /json.htm?type=openzwavenodes&idx=2
It returns a config entry for each device except the wall plug...
It looks like this:
the wall plug doesn't have any config string:
Because I do not know if I had to keep the HomeID secret I've removed it
The config files all have the same permissions (owner: pi:pi, read&write + read + read)
Yes I'm running domoticz on a raspberry pi.
There also is a file named "fgwpe.xml" which also seems to be for a fibaro wall plug... I renamed it to "fgwpfzw5.xml" but no changes at all...
It seems, the wall plug could not be identified and so no config file will be loaded...
edit)
May it has to do something with this error?
PluginSystem: Failed dynamic library load, install the latest libpython3.x library that is available for your platform.
EventSystem - Python: Failed dynamic library load, install the latest libpython3.x library that is available for your platform.
edit end)
Greetings
Kel
It looks like this:
"config" : [
"LastUpdate" : "-",
"help" : "Set the time period between polls of a node's state. The length of the interval is the same for all devices. To even out the Z-Wave network traffic generated by polling, OpenZWave divides the polling interval by the number of devices that have polling enabled, and polls each in turn. It is recommended that if possible, the interval should not be set shorter than the number of polled devices in seconds (so that the network does not have to cope with more than one poll per second).",
"index" : 1,
"label" : "Poll Interval",
"type" : "short",
"units" : "Seconds",
"value" : 60
},the wall plug doesn't have any config string:
"Description" : "FIBARO System Unknown: type=0602, id=1001",
"HaveUserCodes" : false,
"HomeID" : ---------------------------------,
"LastUpdate" : "2017-06-22 18:30:33",
"Manufacturer_id" : "0x010f",
"Manufacturer_name" : "FIBARO System",
"Name" : "Schaltbare Steckdose",
"NodeID" : 2,
"PollEnabled" : "false",
"Product_id" : "0x1001",
"Product_name" : "Unknown: type=0602, id=1001",
"Product_type" : "0x0602",
"State" : "Awake",
"Version" : 4,
"idx" : "2"
},Because I do not know if I had to keep the HomeID secret I've removed it
edit)
edit end)
Greetings
Kel
YcKe
Hi Keleos,
Have you tried deleting it from the hardware panel?
After a reboot it should be readded.
I have those errors too, no worries about that.
Greetz YcKe
Greetz YcKe
Keleos
Hi YcKe,
you mean deleting it here? Or have I to exclude the node?
(Source for picture: https://www.domoticz.com/forum/viewtopic.php?t=5197)
I've never just deleted a Node by clicking this delete Button
Greetings
Kel
Greetings
Kel
YcKe
Hi Keleos,
Correct, that button
Greetz YcKe
Greetz YcKe
Keleos
Hi YcKe,
did it, but after the device is back again, the situation doesn't change
Greetings
Kel
Greetings
Kel
YcKe
Hi Keleos,
Can you take a screenshot of your hardware screen?
Greetz YcKe
Greetz YcKe
Keleos
EDIT
I GOT IT
It was the config file I'd to delete!
After I've deleted the: zwcfg_0??????.xml file in the config folder the options are back
Thank you very much for helping me
Greetings
Kel
I GOT IT
Greetings
Kel
YcKe
Hi Keleos,
Great to hear that!
Greetz YcKe
Great to hear that!
Greetz YcKe
