hello, I have domoticz on my Synology with the RFXtrx433E. I have 3 shutters with ASA GO-4 motor. I try to add switch with the learning mode but it doesn't see anything. I am a new with this and I don't undertand how I can get the shutter on domoticz.
Did I have to do as for a somfy?
Can someone please put me in the good way?
ASA ETR Blids motor
- Target OS: -
Re: ASA ETR Blinds motor
Yes, use the same procedure as Somfy RTS to add the device in Domoticz.
You can also use RFXmngr to pair the AS motor and use the same ID-Unit code in Domoticz as used in RFXmngr.
RFX-433, RFX-433EMC, RFX-868
- Domoticz version: V3.604
Oke thanks. I will try.b_weijenberg wrote:Yes, use the same procedure as Somfy RTS to add the device in Domoticz.
It works... thanks for your help
Re: ASA ETR Blids motor
Can You share your solution? I'm fighting with this few hours
