I am using Domoticz with MySensors.
Is it possible to dynamically change PIR settings on the node?
For example, if PIR is triggered many times (there are people in the room) during the day, I'd like to disable it for 1h in order to preserve battery on the node? It is possible to do from Domoticz?
Alex
PIR settings
- Egregius
- Domoticz version: v2024.7
Re: PIR settings
Everything you can set with the web interface you can set with a script.
Search the posted data in the developer view of a good browser and curl that in a link.
