ip adress
douwebakker
Domoticz version: 3.5877
ip adress
Post by douwebakker »
Hi, Domoticz's ip address on raspberry changed spontaneously. What is the cause of this?
Douwe
jvdz
Domoticz version: 4.107
Re: ip adress
Post by jvdz »
When it is using DHCP to acquire its IP address, it will get it from your DHCP server (likely your router).
So you either hardcode the IPaddress in the PI or set a fix IP address in your DHCP server for the PI's MAC address.
Jos
douwebakker
Re: ip adress
Thanks for the reply. I'm a digibeet.
I thought the ip address automatically would be a fixed address, but not so.
jvdz
Re: ip adress
Post by jvdz »
When you want to fix it on your RPI you could follow this explanation in the WiKi:
https://www.domoticz.com/wiki/Preparing ... _ip-adress
Jos
Lebo2d9
Domoticz version: L stab
Re: ip adress
Post by Lebo2d9 »
Hi. I use an ip adress reservation in my router and leave the pi on dhch.
Domoicz on RPI3 (wifi) directly connected 3x ds18b20 for CV temp, Evohome (9 zone), 1 remote 220V switch based on ESP-12. RFXtrx433E, 16x AMST-606, 5 Somfy RTS motors
Domoticz on RPI3(wifi) as slave for terraruim control
More to come
TakeAway
Domoticz version: 3.7722
Re: ip adress
Post by TakeAway »
Lebo2d9 wrote:Hi. I use an ip adress reservation in my router and leave the pi on dhch.
I do it the same way, is this a good solution or is it better to fix your ip within your pi?
Raspberry Pi 3 - Domoticz 3.7722 - Aeon Labs Z-Stick GEN5 - RFXcom version: Ext/1012- Logitech Harmony Elite - Homebridge - Fibaro FGMS-001-ZW5 - Fibaro FGDW-002-01 - KAKU stuff.
EddyG
Re: ip adress
Post by EddyG »
I use fixed IP for all my 'fixed' eg. not mobile devices.
So Raspberry gets a fixed IPaddress.
Lebo2d9
Re: ip adress
Post by Lebo2d9 »
When you give your RPI a fix IP address and your RPI is for some reason offline,
your router can distribute the IP address that you give to your RPI.
When your RPI comes then online you have an IP confict in your network.
When you did an IP reservation in your router, the router only distribute that IP address to the MAC you specified.
You can also created a smaller DHCP pool on your router. And give your "fixed" devices a FIX address that is not in the pool.
More to come
jvdz
Re: ip adress
Post by jvdz »
That is indeed why I use the ip-addresses x.x.x.1-99 for fixed devices and DHCP uses the range x.x.x.100-244. ;)
This ensures you never have these type of conflicts.
So you either do it this way of have the reserve the IP address when it is part of the DHCP scope.
Jos
Users browsing this forum: Bing [Bot], JanJaap and 1 guest
