Moderators: leecollings , htilburgs , robgeerts
krizzz
Posts: 200 Joined: Wednesday 20 November 2013 20:36
Post
by krizzz » Tuesday 06 June 2017 22:36
robgeerts wrote: krizzz wrote:
var trashcan = {}
trashcan.hvc = { maxitems: 10, trashapp: 'hvc', width:6, zipcode:'XXXXxx', housenumber:'3X }
You are missing a ' ??
(After 3X)
Sorry for my shitty copy and paste skills. The ' is there. I just replaced the ' with an X accidently.
I just updated to the last beta, and still the same error....
robgeerts
Posts: 1273 Joined: Saturday 24 January 2015 22:12
Domoticz version: 3.7067
Post
by robgeerts » Tuesday 06 June 2017 22:39
Could you send me your zipcode and housenumber via pm so i can test with it?
robgeerts
Post
by robgeerts » Tuesday 06 June 2017 22:42
Swifty wrote: @robgeerts
Any thoughts on the lack of localisation for pickup day text?
I had a look at some of the code to try and understand - it looks like today and tomorrow are localised, but anything else is hardcoded to NL ? (Trash.js line 335)
Could you try latest version?
Make sure you have the following line in config.js:
(change de to fr, en, pl or something else
Swifty
Posts: 76 Joined: Saturday 31 December 2016 21:03
Post
by Swifty » Wednesday 07 June 2017 1:09
robgeerts wrote: Swifty wrote: @robgeerts
Awesome, many thanks.
Just tested out and working brilliantly
Eddiever
Posts: 105 Joined: Thursday 27 April 2017 20:32
Domoticz version: 2022.1
Post
by Eddiever » Wednesday 07 June 2017 21:48
Hi Rob, great work!
And can you add Hoogeveen?
http://www.areareiniging.nl/home/bewone ... -digitaal/
(really don't know how to see if it uses JSON)
Eddiever on Thursday 08 June 2017 20:01, edited 1 time in total.
Derik
Posts: 1605 Joined: Friday 18 October 2013 23:33
Post
by Derik » Wednesday 07 June 2017 21:54
How can i adjust the text to the right for only this block:
And my Klliko is not changing and i use:
var _DO_NOT_USE_COLORED_TRASHCAN = true;
var _DO_NOT_USE_COLORED_TRASHCAN = false;
Make no different s...
jake
Posts: 751 Joined: Saturday 30 May 2015 22:40
Post
by jake » Wednesday 07 June 2017 23:16
robgeerts wrote: jake wrote: I updated to the latest beta and I lost the custom names and colors of the garbage types. Also the different font sizes is gone. Settings are still there in config.js and custom.css
Try latest beta version...
Fixed. Thanks again!
htilburgs
Posts: 464 Joined: Tuesday 03 November 2015 11:01
Post
by htilburgs » Thursday 08 June 2017 8:52
Derik wrote: How can i adjust the text to the right for only this block:
Try to add this to your custom.css (modify 15px to your needs):
.trash .state div.trashrow {
margin-left: 15px;
Hardware:
Derik
Post
by Derik » Thursday 08 June 2017 9:36
@ htilburgs
Thanks this wil do the trick!!
Now the changing colors of the KLIKO left...
Yustmenl
Posts: 24 Joined: Wednesday 28 September 2016 17:26
Domoticz version: 3.5997
Post
by Yustmenl » Thursday 08 June 2017 17:50
Rasberry Pi 3; Razberry 2.0; RFXCOM
robgeerts
Post
by robgeerts » Thursday 08 June 2017 22:35
I dont think it has a JSON-source, but do you have an example zipcode?
krizzz
Post
by krizzz » Thursday 08 June 2017 23:37
f.y.i
Rob solved my "LowerCase" error. It had nothing to do with dashticz but only my inferior programming skills
Thanks Rob!
Yustmenl
Post
by Yustmenl » Friday 09 June 2017 9:19
robgeerts wrote: I dont think it has a JSON-source, but do you have an example zipcode?
if i go to
http://www.afvalstoffendienst.nl/afvalkalender and use 5236sg 160 i get the information.
hopefully that is of some use to you.
Edit: i send the question to the website, hopefully they can give us some good information.
Swifty
Post
by Swifty » Tuesday 13 June 2017 17:55
Is ical trash broken in the current beta? - I am not able to get my calendar to load, it just says 'loading...' permanently.
I added the same ical url as a 'calendar' item` and it loads fine.
Is there somewhere I can view any log or anything relating to this? - I even converted my ical to json and saved it locally, then edited the js to point locally at my own apache server, but still no luck.
Derik
Post
by Derik » Tuesday 13 June 2017 20:56
perhaps ctrl and F5
robgeerts
Post
by robgeerts » Tuesday 13 June 2017 20:58
I've only changed calendar function in last beta... could you send me your trash url via pm?
Swifty
Post
by Swifty » Tuesday 13 June 2017 22:02
@derik, unfortunately a forced refresh doesn't help
@robgeerts - I've sent you a PM with my current ical url.
Swifty
Post
by Swifty » Wednesday 14 June 2017 12:02
@robgeerts - Sorry, not sure what happened to my PM yesterday! - I have resent.
Makes sense that the old URL I sent doesn't work, as I regenerated the ical links in Google Calendar when troubleshooting this issue.
New link works fine on ical-to-json though (worked ok when i tried yesterday, but that URL is blocked at the moment as i'm at work)
raymond
Posts: 71 Joined: Monday 12 October 2015 15:46
Domoticz version: V4.10232
Post
by raymond » Wednesday 14 June 2017 16:12
robgeerts wrote: htilburgs wrote: Currently my Trashcan plugin won't load, it's only saying "Loading......"
Has anybody else this problem right now?
Please send me the piece of code of the trashcan in config.js..
Have the very same problem all of a sudden. It says Loading...
Did this get resolved in the end? And how can I try to fix?
Ray
