Dear All,
I bought a KMTronic USB eight channel relay controller. In Domoticz I have selected KMTronic gateway USB. But how can I control the 8 relays? I can't select de KMTronic as hardware when making a new switch. Or do I have to make a LUA script?
Thanks for your help
KMTronic USB Relay
Meppel8
- Domoticz version: V3.5877
KMTronic USB Relay
- product_343.jpg (14.88 KiB) Viewed 1406 times
- Domoticz Hardware.JPG (72.11 KiB) Viewed 1406 times
guantolento
- Domoticz version: LastBeta
Re: KMTronic USB Relay
I think you can create a virtual switch from The switch tab And selected The km tronic source.
Inviato dal mio GT-I9301I utilizzando Tapatalk
Master (pi3) - MB sensors + Dummy + Sysfs gpio + 1 NodOn MSP-3 + 1 Aeotec DSB28 Energy Meter + 3 Danfoss RS Room + 7 Danfoss Z Thermostat + 1 Swiid Inter + 9 FGS222
Slave01 (pi2) - MB sensors + Dummy + Weather Underground + 2 FGS223 + 1 FGWPE/F
Meppel8
KMTronic USB Relay
It was a Conflict between two USB ports. Solved the problem. Now de relays are available in device tab.
Thanks for the help.
guantolento
That's good.
Alain
- Domoticz version: 2022.1
I have an 8-relay box too, but as an RS485 version with a USB converter. When I select KMtronic Gateway USB, no devices appear. I have tried different things for hours now but can't get it to work.Meppel8 wrote: Wednesday 07 June 2017 15:31 It was a Conflict between two USB ports. Solved the problem. Now de relays are available in device tab.
I also have two heat pumps, that when connected to the USB converter, they work without any issues. I have now disconnected the heat pumps and have only connected the relay box, but it doesn't seem to respond. The log says it is ready to read, but is not responding. Anyone have an idea?
Hue | Zigbee2Mqtt | MQTT | P1 | Xiaomi | RFXCom | Modbus | TP-Link | Node-Red | Grafana |
