Hesmink
Post by Hesmink »
Hesmink wrote: Unfortunately I'm not able to code this functionality in the original code without breaking stuff (because of lack of javascript knowledge, not because it's impossible);
I gave it a shot, this way the code checks for 'webcapture.jpg' in the URL, and modifies it with a small(er) timestamp in the middle.
All other URLs are treated with the full timestamp at the end.
function reloadImage(i,image){
        var sep='?';
        if(typeof(image.image)!=='undefined'){
                var img = image.image;
                if (img.indexOf("webcapture.jpg") != -1) {
                        // Webcams with the 'webcapture.jpg' command don't accept anything after the URL
                        // it does support a short timestamp within the URL
                        var newt=(new Date()).getTime();
                        var newt2 = newt.toString();
                        newt2 = newt2.substr(newt2.length - 5);
                        var newimg = img.split("webcapture.jpg");
                        img = newimg[0];
                        img+='webcapture.jpg?command=snap&t='+newt2+'&channel=1'
                } else {
                        if (img.indexOf("?") != -1) var sep='&';
                        if (img.indexOf("?") != -1){
                                var newimg = img.split(sep+'t=');
                                img = newimg;
                        img+=sep+'t='+(new Date()).getTime();
        $('.imgblock'+i).find('img').attr('src',img);
albertomarrod
Domoticz version: Latest
Post by albertomarrod »
EdKo66 wrote:
albertomarrod wrote:Hello guys.
Is the weather compatible for UK or other countries or is just for NL?
Thank you in advance!
Did you get a API-key from Weather Underground? That is what drives the weather-information on Dashticz. Get the developer plan. It's free, and more then enough for private use.
Yes I did but nothing appears the API key was already working before I installed Dashticz. It's quite weird...
EDIT: I tried with the city where I am originally from (Valladolid, Spain) and it´s working but is not with the city where I´m living know (Newcastle Upon Tyne, United Kingdom). It has to be something wrong with the vars below...
For "var _weather_city" I have tried Newcastle, Newcastle Upon Tyne, Newcastle-upon-Tyne.
For "var _weather_country" I have tried UK, GB and United Kingdom.
any idea?
EDIT 2: The var for the country is UK as with London, Oxford, Birmingham it´s working but no with other cities like mine (Newcastle Upon Tyne), Manchester, Leeds, Sunderland...
I almost got it...
Pi3, latest beta
z-wave (AEOTEC, switches, temhum, pir, contacts, roller shutter),
Pylips, WiFi ping, Mi-Light,
Xiaomi Xiaofang cams, zigbee2mqtt,
dashticz v3
Hesmink
Post by Hesmink »
any idea?
I almost got it...
https://www.wunderground.com/weather-forecast/UK.html
Newcastle airport?
albertomarrod
any idea?
I almost got it...
Newcastle airport?
What I stupid I´m feeling right now! I didn´t know that I had to use that one exactly. I thought that I had to use the city name.
Newcastle Airport is like 10 km from mine so it´ll be enough. Thanks for your help.
Pi3, latest beta
dashticz v3
robgeerts
Domoticz version: 3.7067
Post by robgeerts »
Hesmink wrote: Fixed it by re-adding definition of col2 and col3. This would only affect people using the default set.
Fixed in latest beta!
Hesmink wrote: I did some further testing, and my webcam is rather picky. It will work if I put something in the middle, so:
Original URL: http://192.168.123.25/webcapture.jpg?co ... &channel=1
Working addition: http://192.168.123.25/webcapture.jpg?co ... &channel=1
Does it work when adding it right after the ? (so it is the first argument..)
Hesmink wrote: I gave it a shot, this way the code checks for 'webcapture.jpg' in the URL, and modifies it with a small(er) timestamp in the middle.
        var sep='?';
                        img = newimg[0];
                } else {
                                img = newimg;
Ok, but this too general, maybe another webcam from another manufacturer also uses the filename webcapture.jpg but another channel or something. If the timestamp works as first argument, i could fix this in another way...
Hesmink
Post by Hesmink »
robgeerts wrote: Ok, but this too general, maybe another webcam from another manufacturer also uses the filename webcapture.jpg but another channel or something. If the timestamp works as first argument, i could fix this in another way...
Doesn't work, it will then automatically download the image, not display it.
I'll try some more.
Hesmink
Post by Hesmink »
I'll try some more.
What does work is this:
http://192.168.133.25/webcapture.jpg?command=snap&t=12345&channel=1?t=12345678
And this
http://192.168.133.25/webcapture.jpg?command=snap&t=12345&channel=1;t=12345678
The first one (?) is not legal in an HTTP request, the second one apparently is. You should be able to replace a & with a ;
EddyG
Post by EddyG »
jjnj wrote:Is it possible to adjust the height of the Google maps picture? I would like it to be a bit bigger.
In creative.css on line 108 (beta) change in "height:200px !important;" the 200 in 400 or something like that.
robgeerts
Post by robgeerts »
Do this in custom.css, not in creative.css otherwise it will be overwritten in a future version.
Hesmink
Post by Hesmink »
Hesmink wrote:
With this information, changing line 662 of main.js to:
if (img.indexOf("?") != -1) var sep=';';
Would fix it, and should be compatible with others.
For me it works, but I wouldn't be surprised if other devices do not support the ';' as separator.
Derik
Post by Derik »
mmm
Is there a option to set/adjust all tekst in the switches:
I will try set all the tekst on my favorite place.
The heads and the info..colars etc etc
Perhaps under the block if possible? [ standard color of the switch is no problem ]
blocks['s13'] = {}
blocks['s13']['width'] = 12; //1 to 12, remove this line if you want to use the default (4)
blocks['s13']['title'] = 'zithoek'; //if you want change the name of switch different then domoticz
blocks['s13']['icon'] = 'fa-eye'; //if you want an other icon instead of the default, choose from: http://fontawesome.io/cheatsheet/
blocks['s13']['image'] = 'bulb_off.png'; //if you want to show an image instead if icon, place image in img/ folder
blocks['s13']['switch'] = true; //if you want to switch the title and data
blocks['s13']['hide_data'] = true; //if you want to hide the data of this block
blocks['s13']['show_lastupdate'] = true; //if you want to show the last update specific for this block
blocks['s13']['playsound'] = 'sounds/ping.mp3'; //play a sound when a device changes
blocks['s13']['protected'] = false; //protect switching manually in Dashticz
Or in the css
And i hope i can change the colors from the inside devices.
Like the colors and fontsize of the weather tekst and icon.
And the clock
And an option to set the clock data in 1 line.
And some more adjustable nice options..
[a css from someone i liketo puzzle ]
Yustmenl
Domoticz version: 3.5997
Post by Yustmenl »
Hopefully someone can help me,
I installed Dashticz on my synology and edited the config.js
var _LANGUAGE 				= 'nl_NL'; //or: en_US, fr_FR, hu_HU
var _HOST_DOMOTICZ		  	= 'http://xxx.xxx.xxx.xxx:8080';
var _DOMOTICZ_REFRESH		= 3; //in seconds
var _DASHTICZ_REFRESH		= 5; //in minutes
var _THEME 					= 'default'; // default = dashticz default theme
var _HOST_ZIGGO_HORIZON	  	= ''; //e.g. http://192.168.1.3/domoticz/switch_horizon.php';
var _APIKEY_WUNDERGROUND  	= 'xxxx';
var _WEATHER_CITY 			= 'xxx';
var _WEATHER_CITYNAME 		= ''; //show a different city name, leave empty if same as _WEATHER_CITY
var _WEATHER_COUNTRY 		= 'NL';
var _USE_AUTO_POSITIONING 	= false; //don't want to configure positions, use auto positioning
var _USE_FAVORITES			= false; //only used when using auto positioning
var _HIDE_SECONDS_IN_CLOCK  = false; //do not show the seconds in the clock
var _NEWS_RSSFEED			= 'http://www.nu.nl/rss/algemeen';
var _USE_FAHRENHEIT			= false;
var _USE_BEAUFORT 			= false; //Bft instead of m/s
var _TRANSLATE_SPEED 		= false; //windspeed, north northwest instead of NNW
var _STANDBY_AFTER_MINUTES  = false; //enter amount of minutes like: 5 (5 minutes)
var _SCROLL_NEWS_AFTER 		= 7000; //milliseconds, so 7000 is 7 seconds
var _SHOW_LASTUPDATE 		= true;
var _LASTUPDATE_FORMAT 		= 'DD-MM-YY HH:mm';
var _SCREENSLIDER_EFFECT 	= 'slide'; //'slide' or 'fade' or 'cube' or 'coverflow' or 'flip'
//var _APIKEY_MAPS			= '';
//var _MAPS_LATITUDE			= '';
//ar _MAPS_LONGITUDE			= '';
//var _AUTO_SWIPEBACK_TO		= 1; //when no activity, swipe back to main screen after x seconds
//var _AUTO_SWIPEBACK_TIME	= 10; //seconds
var buttons = {}
//buttons.moon= {width:12, isimage:true, refreshimage:60000, image: 'moon'}
//buttons.calendar = {mijn kalendar'}
//buttons.buienradar = {width:12, isimage:true, image: 'http://api.buienradar.nl/image/1.0/RadarMapNL?w=285&h=256'}
//buttons.nunl = {width:12, icon: 'fa-newspaper-o', title: 'Nu.nl', url: 'http://www.nu.nl'}
//CUSTOM POSITIONING;
//defining wich blocks to show, de numbers represents the IDX of the device in Domoticz
//only define if you want to use a custom width instead of the default
var blocks = {}
blocks['blocktitle_1'] = {}
blocks['blocktitle_1']['title'] = 'Schakelaars'
blocks[93] = {}//schemerlanp woonkamer
blocks[93]['width'] = 4; //1 to 12, remove this line if you want to use the default (4)
//defining number of columns, their contents en widths
//width can be a number 1 to 12, but total widths of all columns should always be 12
columns[1] = {}
columns[1]['blocks'] = ['blocktitle_1',93]
columns[1]['width'] = 12;
I used possitioning and favorites as true and false in all combinations but i don't get any information on my screen
so i also tryed to add switches manualy and this also doesn't get anything on screen.
the only thin i get is the WU blocks
when i look at http://xxx.xxx.xxx.xxx:8080/json.htm?ty ... favorite=1
it shows all the favorites.
hopefully someone can point me in the right direction.
Rasberry Pi 3; Razberry 2.0; RFXCOM
HansieNL
Post by HansieNL »
Yustmenl wrote:Hopefully someone can help me,
var buttons = {}
var blocks = {}
columns[1] = {}
You are missing var columns = {}
var screens = {}
screens[1] = {}
screens[1]['background'] = 'bg1.jpg';
screens[1]['columns'] = [1]
Blah blah blah
Yustmenl
Post by Yustmenl »
thanks, i missed those.
EddyG
Post by EddyG »
robgeerts wrote:Do this in custom.css, not in creative.css otherwise it will be overwritten in a future version.
I am not an expert on css, so how should that been done in custom.css?
Edit: Found it, just copy the complete .trafficmap block and change the 200 in 400
robgeerts
Post by robgeerts »
Well, in fact, you only have to keep the height-line in that block, you dont need to duplicate the other lines ;)
So, you can remove:
padding-left: 13px !important;
    padding-right: 13px !important;
Derik
Post by Derik »
robgeerts wrote:Well, in fact, you only have to keep the height-line in that block, you dont need to duplicate the other lines ;)
So, you can remove:
This for me?
htilburgs
Post by htilburgs »
No, for EddyG
Hardware:
krizzz
Post by krizzz »
I am trying to get an additional newsfeed in my dashboard. But it will not showup. I just copied the lines from the Wiki
http://www.domoticz.com/wiki/Dashticz_V2_-_Tips,_Tricks_%26_Customization
I have now in my Config.js (I took out some unimportant parts for my question)
var _HOST_DOMOTICZ = 'http://xxxxxxxxxxxxxxxx';
var _DOMOTICZ_REFRESH = 5; //in seconds
var _APIKEY_WUNDERGROUND = 'xxxxxxxxx';
var _WEATHER_CITY = 'xxxxxxr';
var _USE_AUTO_POSITIONING = true; //don't want to configure positions, use auto positioning
var _SHOW_LASTUPDATE = false;
var _DO_NOT_USE_COLORED_TRASHCAN = true;
var _MAPS_LONGITUDE = '';
//Buttons or images to open webpages in an iframe, like a news website or weather forecast
var buttons = {}
buttons.buienradar = {width:12, isimage:true, refreshimage:60000, image: 'http://api.buienradar.nl/image/1.0/RadarMapNL?w=xxx&h=256', url: 'http://www.weeronline.nl/Europa/Nederland/'}
// http://fontawesome.io/cheatsheet/
var screens = {}
screens[1] = {}
screens[1]['background'] = 'Toscane.jpg';
var blocks = {}
blocks['blocktitle_1a'] = {}
blocks['blocktitle_1a']['type'] = 'blocktitle';
blocks['blocktitle_1a']['title'] = 'Schakelaars';
blocks['blocktitle_1b'] = {}
blocks['blocktitle_1b']['type'] = 'blocktitle';
blocks['blocktitle_1b']['title'] = 'Temperatuur';
blocks['blocktitle_1c'] = {}
blocks['blocktitle_1c']['type'] = 'blocktitle';
blocks['blocktitle_1c']['title'] = 'Divers';
blocks['news_1'] = {}
blocks['news_1']['feed'] = 'https://crossorigin.me/http://www.nu.nl/rss/Algemeen';
blocks['news_2'] = {}
blocks['news_2']['feed'] = 'https://crossorigin.me/http://feeds.feedburner.com/tweakers/nieuws';
var columns = {}
columns[2] = {}
columns[2]['blocks'] = [
'weather',
'traffic',
'train',
'news_1',
'news_2']
columns[2]['width'] = 5;
columns[3] = {}
columns[3]['blocks'] = [
'blocktitle_1a',
61,
42,
56,
'blocktitle_1b',
89,
49,
90,
'blocktitle_1c',
85,
83,
columns[3]['width'] = 5;
And only the first rss feed appears... does anyone know why?
Derik
Post by Derik »
[/code]@ Krizz:
I think your link is not correct:
'http://feeds.feedburner.com/tweakers/nieuws';
mmm
Edit:
I get mine not working to...
Locked
