How to run Domoticz on start without GUI , only server daemon ?
On Raspberry PI .
How to run Domoticz on start without GUI , only server daemon ? Topic is solved
Re: How to run Domoticz on start without GUI , only server daemon ?
You can start domoticz with -www 0 -sslwww 0, at least you are not able to connect to it then
No, I want to be able to it with other devices, I just don't want it to open on raspberry pi because I am running something else on it.
I really don't understand what you are trying to acomplish, You asked on Raspberry PI, hence my answer.semkras wrote:No, I want to be able to it with other devices, I just don't want it to open on raspberry pi because I am running something else on it.
i want to be able to connect to it from other devices without running client side (GUI , web page) on Rasberry PI.
Yes, but after Raspberry pi started i got browser loaded and shown with default Domoticz web page, i want to know how disable that.gordonb3 wrote:There is no GUI in Domoticz. Nothing that uses any graphic resources on the host that is. All it has is a web content server that allows a web browser to combine information from the Domoticz server into something that one could consider a GUI but is usually referenced to as a web front end.
Sometimes i do need browser and i got magicmirror who uses it.
cannot find nothing in startup script
this is sample of this script
https://github.com/domoticz/domoticz/bl ... omoticz.sh
