Dashticz - Module - Garbage collector Topic is solved
- EdwinK
- Domoticz version: BETA
Re: Dashticz - Module - Garbage collector
Custom.css
Is it possible to add reinis to the garbage collector ? thnx in advance
http://www.reinis.nl/postcodecheck/
Daniel
Daniel
- Domoticz version: 3.7067
Could you try latest beta?Swifty wrote:No problem, as I say - not hassling just wasn't sure if I'd missed itrobgeerts wrote:No sorry... didnt have much time in the last couple of days... could you send me an example ical? (Or did you already?)Swifty wrote:@robgeerts - Any luck with adding iCal support for the garbage module?
I'm not hassling - just been away for a week or so, and trying to catch up on the board, so wondering if I missed it as i can't see it in the first post
I already sent a PM with ical link (sent 12th May) let me know if you need it again.
You dont need to add the colors in de description, will fetch the right colored icon based on name.
It only shows the collection dates in the upcoming month.
Thanks, I'll give it a try when I get home tonight and report backrobgeerts wrote:Could you try latest beta?Swifty wrote:No problem, as I say - not hassling just wasn't sure if I'd missed itrobgeerts wrote: No sorry... didnt have much time in the last couple of days... could you send me an example ical? (Or did you already?)
robgeerts wrote: Could you try latest beta?
So I've just had chance to check it out, slightly later than planned due to being greeted by sick children when I got homeSwifty wrote: Thanks, I'll give it a try when I get home tonight and report back
It all seems to work great, but for some reason the weekday names are showing up in dutch - eg. next collection is thursday, but the block shows donderdag instead.
I have the locale set to en_US in the dashticz config, so not sure where it's grabbing that from?
- EdwinK
It's a plot from us Dutch people to take over the world.
So, question. I am a novice with dashticz
so please be gentle.
I added the trashcan "device"
Then added it to columns
closed the CONFIG.js and my dashtica gave the following error:
Pretty strange, because line 165 in the CONFIG.js is a line with the // at the beginning so it should be non working code. Also in Dashtica you can see the "garbage bin" loading but not coming through. Any ideas?
var trashcan = {}
trashcan.hvc = { maxitems: 10, trashapp: 'hvc', width:6, zipcode:'XXXXxx', housenumber:'X' }
var trashnames = {}
trashnames['Rest'] = 'Restafval';
trashnames['Gft'] = 'GFT';
trashnames['Pmd'] = 'Plastic';
var trashcolors = {}
trashcolors['Gft'] = 'Lime';
trashcolors['Pmd'] = 'Orange';
columns[1] = {}
columns[1]['blocks'] = [
'clock',
'currentweather',
buttons.buienradar,
trashcan.hvc]
columns[1]['width'] = 2;
can someone help me so i can do it myself?h143 wrote:Can you add http://afvalkalender.leek.nl/afvalkalen ... chbox.html
Could you test latest beta?krizzz wrote:So, question. I am a novice with dashticzso please be gentle.
I added the trashcan "device"Code: Select all
var trashcan = {} trashcan.hvc = { maxitems: 10, trashapp: 'hvc', width:6, zipcode:'XXXXxx', housenumber:'X' } var trashnames = {} trashnames['Rest'] = 'Restafval'; trashnames['Gft'] = 'GFT'; trashnames['Pmd'] = 'Plastic'; var trashcolors = {} trashcolors['Gft'] = 'Lime'; trashcolors['Pmd'] = 'Orange';
Then added it to columnsclosed the CONFIG.js and my dashtica gave the following error:Code: Select all
columns[1] = {} columns[1]['blocks'] = [ 'clock', 'currentweather', buttons.buienradar, trashcan.hvc] columns[1]['width'] = 2;
- EdwinK
Yeah... a new beta
*does git pull*
*does git pull*
- Domoticz version: 4.10717
Hi Rob,
Is there chance you can add https://www.twentemilieu.nl/borne or perhaps there is a different way? Thnx for your help in advance!
Done, no change. Maybe you see some something in my CONFIG.js?robgeerts wrote:Could you test latest beta?
var _LANGUAGE = 'nl_NL'; //or: en_US, fr_FR, hu_HU
var _HOST_DOMOTICZ = 'http://192.168.X.XXX:8080';
var _DOMOTICZ_REFRESH = 5; //in seconds
var _APIKEY_WUNDERGROUND = 'xxxxxxxxxxxxxxxx';
var _WEATHER_CITY = 'xxxxx';
var _WEATHER_CITYNAME = ''; //show a different city name, leave empty if same as _WEATHER_CITY
var _WEATHER_COUNTRY = 'NL';
var _USE_AUTO_POSITIONING = true; //don't want to configure positions, use auto positioning
var _USE_FAVORITES = true; //only used when using auto positioning
var _HIDE_SECONDS_IN_CLOCK = false; //do not show the seconds in the clock
var _NEWS_RSSFEED = 'http://www.nu.nl/rss/algemeen';
var _USE_FAHRENHEIT = false;
var _USE_BEAUFORT = false; //Bft instead of m/s
var _TRANSLATE_SPEED = false; //windspeed, north northwest instead of NNW
var _STANDBY_AFTER_MINUTES = false; //enter amount of minutes like: 5 (5 minutes)
var _SCROLL_NEWS_AFTER = 7000; //milliseconds, so 7000 is 7 seconds
var _SHOW_LASTUPDATE = false;
var _LASTUPDATE_FORMAT = 'DD-MM-YY HH:mm';
var _APIKEY_MAPS = '';
var _MAPS_LATITUDE = '';
var _MAPS_LONGITUDE = '';
//Buttons or images to open webpages in an iframe, like a news website or weather forecast
var buttons = {}
buttons.buienradar = {width:12, isimage:true, refreshimage:60000, image: 'http://api.buienradar.nl/image/1.0/RadarMapNL?w=XXX&h=XXX', url: 'http://www.weeronline.nl/Europa/Nederland/xxxxxx/xxxxx'}
// http://fontawesome.io/cheatsheet/
var screens = {}
screens[1] = {}
screens[1]['background'] = 'toscane.jpg';
var trashcan = {}
trashcan.hvc = { maxitems: 10, trashapp: 'hvc', width:6, zipcode:'XXXXxx', housenumber:'3X }
var trashnames = {}
var blocks = {}
// WEER
// WOONKAMER
// KEUKEN
// SLAAPKAMER
// MEDIA
blocks['blocktitle_1a'] = {}
blocks['blocktitle_1a']['type'] = 'blocktitle';
blocks['blocktitle_1a']['title'] = 'Schakelaars';
blocks['blocktitle_1b'] = {}
blocks['blocktitle_1b']['type'] = 'blocktitle';
blocks['blocktitle_1b']['title'] = 'Temperatuur';
blocks['blocktitle_1c'] = {}
blocks['blocktitle_1c']['type'] = 'blocktitle';
blocks['blocktitle_1c']['title'] = 'Divers';
blocks['news_1'] = {}
blocks['news_1']['feed'] = 'https://crossorigin.me/http://www.nu.nl/rss/Algemeen';
blocks['news_2'] = {}
blocks['news_2']['feed'] = 'https://crossorigin.me/http://www.nu.nl/rss/Sport';
var columns = {}
columns[1] = {}
'clock',
'currentweather',
buttons.buienradar,
trashcan.hvc]
columns[2] = {}
columns[2]['blocks'] = [
'weather',
'traffic',
'train',
'news_1',
'news_2']
columns[2]['width'] = 5;
columns[3] = {}
columns[3]['blocks'] = [
'blocktitle_1a',
61,
'blocktitle_1b',
'blocktitle_1c',
columns[3]['width'] = 5;
columns[4] = {}
columns[4]['blocks'] = [
columns[4]['width'] = 5;
columns[5] = {}
columns[5]['blocks'] = [
columns[5]['width'] = 5;
columns[6] = {}
columns[6]['blocks'] = [
columns[6]['width'] = 2;
- EdwinK
Could it be because you have set the 'USE_AUTO_POSTIONING' and 'USE_FAVORITES' to 'TRUE'.
Thanks for the help, i adjusted the 'USE_FAVORITES' to FALSE. But no changes....EdKo66 wrote:Could it be because you have set the 'USE_AUTO_POSTIONING' and 'USE_FAVORITES' to 'TRUE'.
@robgeerts
Any thoughts on the lack of localisation for pickup day text?
I had a look at some of the code to try and understand - it looks like today and tomorrow are localised, but anything else is hardcoded to NL ? (Trash.js line 335)
I updated to the latest beta and I lost the custom names and colors of the garbage types. Also the different font sizes is gone. Settings are still there in config.js and custom.css
You are missing a ' ??krizzz wrote: var trashcan = {}
(After 3X)
Try latest beta version...jake wrote:I updated to the latest beta and I lost the custom names and colors of the garbage types. Also the different font sizes is gone. Settings are still there in config.js and custom.css
Guys, I'm trying to support more cities but the ones I dont support yet doesnt have a right data-source (JSON) available...
(Or havent found yet..)
