My sprinkling controller (own build Mysensors node) reports progress of watering sending V_PERCENTAGE message. Domoticz doesn't support S_SPRINKLER sensor types I've tried to set "watering switch" as Dimmer and reports progress to Domoticz but there are a lot od disadvantages....
Is it possible to create dummy "Percenage" devices (it's possible) and feed it with data send over Mysesnors network from my sprinkler controller? I'm using RPI GPIO Mysensors.
Visualize usuported Mysensors value into Domoticz
- Domoticz version: v3.8975
Re: Visualize usuported Mysensors value into Domoticz
I do not think it is possible. If you were to use esp8266 and wifi then updating JSON would update your virtual switch, but this is not the case.Is it possible to create dummy "Percenage" devices (it's possible) and feed it with data send over Mysesnors network from my sprinkler controller? I'm using RPI GPIO Mysensors.
You can use either temperature/humidity or voltage. Voltage has advantage that its pretty high precision.
Temperature/humidity allows to graph combine two independent values on one chart. Humidity good for "percentage" values (0-100%).
I have used S_DUST/V_LEVEL to display percentage. Have a look at https://forum.mysensors.org/topic/5157/ ... ant-volume
