Would be great to add somehow support to join two IDX sensors, some sensors on RFLINK when i replace battery is recognised as new IDX device....
http://www.domoticz.com/forum/viewtopic ... 49&t=17738
so joining these sensors would fix the problem, of course it would work only on sensors with same type
Thanks Jan Devera
joining IDX numbers
- Domoticz version: zelatest
Re: joining IDX numbers
On temperature sensors you have 'Replace' in the edit window.
This is the function to use when a sensor gets a new ID when changing batteries.
Oooh sorry, now i found it...
thanks, works perfect
