Sorry if this isn't a Domoticz problem but I've also raised the issues in the Lets Control It forum.
Since having to upgrade from the stable release of ESPEasy to v2.0.0-dev8 (I needed to be able to access the 4 different I2C addresses for 4 x INA219 current/voltage sensor boards), none of my new boards (another one with a single instance of INA219) with v2.0.0-dev8 firmware are communicating with Domoticz. i.e. Last seen is about the time that I upgraded to v2.0.0-dev8 build.
I wondered if anyone else had had this problem or whether there was an issue of sending different builds of ESPEasy to the same instance of Domoticz. i.e. Do I have to upgrade all my devices to the new build for Domoticz to be able to display the data.
The devices are working as they display the correct data in the ESPEasy device list, and I've attached LCDs to both problematic boards to show the valid data. Just seems to be unable to get it across to Domoticz. ...and all the stable build devices are still working with Domoticz. If you require more details then please let me know.
Nothing obvious in the Domoticz log/error-log, to me at least, but if someone can help me out I'd really appreciate it. The ESPEasy forum entry is here https://www.letscontrolit.com/forum/vie ... 289#p16289
Update: I reflashed the standard build on the same device, and it worked. Data all the way throught to Domoticz.
Domotics not updated when upgrade device to ESPEasy v2.0.0-dev8
robatbentley
- Domoticz version: 3.8889
Cezary
Re: Domotics not updated when upgrade device to ESPEasy v2.0.0-dev8
How do you read the data from INA219 through espeasy in domoticz?
misterleffe
