what is wrong? username and password
tiga
Post by tiga »
what am i doing wrong?
i have a lua script running on my raspberry with this line in it:
commandArray['OpenURL']='192.168.0.123:8080/json.htm?type=command&param=updateuservariable&vname=deltaT&vtype=1&vvalue='..tostring(delta)
that works perfect, in my settings: i dont need to use a username and password when connected to my local network.
but i want to change this so i have to implement my username and password in this line.
so this is what i did:
commandArray['OpenURL']='http://USERNAME:[email protected] ... ing(delta)
i succesfully use this command with the username and password in "tasker" on my Phone but in lua it does not work.
or can it be done more easely?
this allso does not work :(
commandArray['OpenURL']='USERNAME:[email protected]:8080/json.htm?type=command&param=updateuservariable&vname=deltaT&vtype=1&vvalue='..tostring(delta)
zicht
Domoticz version: 2023.1+
Re: what is wrong? username and password
Post by zicht »
The format is wrong...
it should be like :
https://IP:Port/json.htm?username=yourname==&password=yourpassword&type=command&param=updateuservariable&vname=IETS&vtype=2&vvalue=AnDERS
Be aware you have to encode your username and password in base64
https://www.domoticz.com/wiki/Domoticz_ ... horization
Hope this helps
tiga
Post by tiga »
Ok thank you very much.i give IT a try!!
