Plugins not showing in hardware list
webcolonel
Post by webcolonel »
Hallo.
I've been searching for some days an answer to my problem but I'm afraid I'm missing something and don't know what.
I'm running Domoticz 3.7449 on a Linux Ubuntu 14.04 system. It's a fresh install (I've installed from the beginning one week ago because I couldn't find a way to sort the problem out, but without luck)
It's working fine but NO PLUGINS are loaded, even in the startup log I can't see an attempt to load python plugins...
2017-05-12 14:21:13.212 Domoticz V3.7449 (c)2012-2017 GizMoCuz
2017-05-12 14:21:13.212 Build Hash: 9df6061, Date: 2017-05-08 18:36:04
2017-05-12 14:21:13.213 Startup Path: /home/domobianchi/domoticz/
2017-05-12 14:21:13.357 Sunrise: 05:58:00 SunSet:20:44:00
2017-05-12 14:21:13.357 EventSystem: reset all events...
2017-05-12 14:21:13.380 Active notification Subsystems: gcm (1/12)
2017-05-12 14:21:15.974 WebServer(HTTP) started on address: :: with port 5001
2017-05-12 14:21:16.289 Incoming connection from: 192.168.1.200
2017-05-12 14:21:25.659 Error: WebServer(SSL) startup failed on address 0.0.0.0 with port: 443: bind: Address already in use
2017-05-12 14:21:25.659 Error: WebServer(SSL) check privileges for opening ports below 1024
2017-05-12 14:21:25.659 Proxymanager started.
2017-05-12 14:21:28.878 Starting shared server on: :::6144
2017-05-12 14:21:28.879 TCPServer: shared server started...
2017-05-12 14:21:28.880 RxQueue: queue worker started...
2017-05-12 14:21:30.881 EventSystem: reset all events...
2017-05-12 14:21:30.882 EventSystem: reset all device statuses...
2017-05-12 14:21:30.884 EventSystem: Started
2017-05-12 14:21:31.381 OpenZWave: using config in: /home/domobianchi/domoticz/Config/
2017-05-12 14:21:31.444 OpenZWave: Starting...
2017-05-12 14:21:31.444 OpenZWave: Version: 1.4-2518-gf95fa41-dirty
2017-05-12 14:21:31.582 OpenZWave: Driver Ready
2017-05-12 14:21:31.583 OpenZWave: Value_Added: Node: 3 (0x03), CommandClass: SWITCH MULTILEVEL, Label: Level, Instance: 1
2017-05-12 14:21:31.584 OpenZWave: Value_Added: Node: 3 (0x03), CommandClass: SWITCH MULTILEVEL, Label: Bright, Instance: 1
2017-05-12 14:21:31.584 OpenZWave: Value_Added: Node: 3 (0x03), CommandClass: SWITCH MULTILEVEL, Label: Dim, Instance: 1
2017-05-12 14:21:31.584 OpenZWave: Value_Added: Node: 6 (0x06), CommandClass: SWITCH BINARY, Label: Switch, Instance: 1
2017-05-12 14:21:31.585 OpenZWave: Value_Added: Node: 6 (0x06), CommandClass: SWITCH BINARY, Label: Switch, Instance: 2
2017-05-12 14:21:31.586 OpenZWave: Value_Added: Node: 7 (0x07), CommandClass: SWITCH BINARY, Label: Switch, Instance: 1
2017-05-12 14:21:31.587 OpenZWave: Value_Added: Node: 10 (0x0a), CommandClass: SWITCH BINARY, Label: Switch, Instance: 1
2017-05-12 14:21:31.588 OpenZWave: Value_Added: Node: 12 (0x0c), CommandClass: SWITCH BINARY, Label: Switch, Instance: 1
2017-05-12 14:21:31.589 OpenZWave: Value_Added: Node: 13 (0x0d), CommandClass: SWITCH BINARY, Label: Switch, Instance: 1
2017-05-12 14:21:31.590 OpenZWave: Value_Added: Node: 16 (0x10), CommandClass: SWITCH BINARY, Label: Switch, Instance: 1
2017-05-12 14:21:31.590 OpenZWave: Value_Added: Node: 16 (0x10), CommandClass: SWITCH BINARY, Label: Switch, Instance: 2
2017-05-12 14:21:31.592 OpenZWave: Value_Added: Node: 17 (0x11), CommandClass: SWITCH BINARY, Label: Switch, Instance: 1
2017-05-12 14:21:31.592 OpenZWave: Value_Added: Node: 17 (0x11), CommandClass: SWITCH BINARY, Label: Switch, Instance: 2
2017-05-12 14:21:31.594 OpenZWave: Value_Added: Node: 18 (0x12), CommandClass: SWITCH BINARY, Label: Switch, Instance: 1
2017-05-12 14:22:08.954 OpenZWave: Received Node Dead notification from HomeID: 25288, NodeID: 7 (0x07)
2017-05-12 14:22:08.954 (Z-Wave) Light/Switch (Switch)
2017-05-12 14:22:13.830 OpenZWave: Received Node Dead notification from HomeID: 25288, NodeID: 10 (0x0a)
2017-05-12 14:22:13.829 (Z-Wave) Light/Switch (SwitchUnassigned)
2017-05-12 14:22:16.127 (Z-Wave) Light/Switch (Artemide)
2017-05-12 14:22:31.247 OpenZWave: Received timeout notification from HomeID: 25288, NodeID: 18 (0x12)
2017-05-12 14:22:31.572 OpenZWave: Awake Nodes queried
Python is this:
domobianchi@domobianchi-server:~/domoticz/plugins$ python --version
Python 3.4.3
I have some default stuff in plugins directory plus the Broadlink one that I've added
domobianchi@domobianchi-server:~/domoticz/plugins$ ls -ltr
totale 12
drwxr-xr-x 3 domobianchi domobianchi 4096 mag 8 21:17 AwoxSMP
drwxr-xr-x 2 domobianchi domobianchi 4096 mag 8 21:17 examples
drwxr-xr-x 2 domobianchi domobianchi 4096 mag 9 12:01 BroadlinkRM2
domobianchi@domobianchi-server:~/domoticz/plugins$ ls -ltr BroadlinkRM2/
totale 44
-rwxr-xr-x 1 domobianchi domobianchi 1473 mar 27 15:59 plugin_send.py
-rwxr-xr-x 1 domobianchi domobianchi 11422 apr 22 09:36 plugin_http.py
-rwxr-xr-x 1 domobianchi domobianchi 72 apr 22 09:36 plugin_http.sh
-rwxr-xr-x 1 domobianchi domobianchi 23475 apr 23 18:58 plugin.py
Unfortunately the plugins (I'm looking for broadlink RM) is not showing up in hardware list.
Please can you help me with this?
Thanks in advance!
Dnpwwo
Re: Plugins not showing in hardware list
Post by Dnpwwo »
@webcolonel,
Domoticz is not finding Python because there is no message in the log saying the the plugin system has started and a confirmation of the version.
Domoticz does not actually need Python3 on the system, it needs libpython. In your case libpython3.4.
try:
sudo apt-get install libpython3.4
followed by a restart of Domoticz
webcolonel
Thank you very much Dnpwwo.
I checked also libpython3.4, but it's already installed.
domobianchi@domobianchi-server:~/domoticz/plugins$ sudo apt-get install libpython3.4
Lettura elenco dei pacchetti... Fatto
Generazione albero delle dipendenze
Lettura informazioni sullo stato... Fatto
libpython3.4 è già alla versione più recente.
0 aggiornati, 0 installati, 0 da rimuovere e 1 non aggiornati.
Also, I checked the plugins section in CMakeLists.txt, as found in another post and added a "set(Python_ADDITIONAL_VERSIONS 3.4)" line, but again no luck.
option(USE_PYTHON_PLUGINS "Use Python Plugins" YES)
IF(USE_PYTHON_PLUGINS)
find_package(PythonLibs 3.4)
IF(PYTHONLIBS_FOUND)
MESSAGE(STATUS "Python3 includes found at: ${PYTHON_INCLUDE_PATH}")
INCLUDE_DIRECTORIES(${PYTHON_INCLUDE_PATH})
add_definitions(-DUSE_PYTHON_PLUGINS)
ELSE(PYTHONLIBS_FOUND)
MESSAGE(FATAL_ERROR "Python3 not found on your system, use USE_PYTHON_PLUGINS=NO or sudo apt-get install python3-dev)")
ENDIF(PYTHONLIBS_FOUND)
ENDIF(USE_PYTHON_PLUGINS)
Is it possible that restoring the configuration (that I had backupped from a domoticz2 installation) may have broken something?
elgringo
Domoticz version: Left
Post by elgringo »
My plugin (eg the base example) is shown in the hardwarelist after renaming it to plugin.py
When I want to add it nothing happens. Normally It should show up in the list above but this is not the case.
Logging doe not show anything
Edit: It works in Mozilla, but not with Chrome
emme
Domoticz version: latest
Post by emme »
uh...
looks like I have the same problem too
no plugin listed in the availbale hardware
I do have WanIP hardware installed (but I assume it is not working anymore)
and I've added SamsungTV control, but looks unavailble in the hardware list
Tried to install libpython3.4 but already installed.
Hardware is rPI3 with Raspbian and Domoticz latest beta 3.8392
ciao
M
"We always done this way"
pepijn
Post by pepijn »
emme wrote:uh...
ciao
M
The Python plugin system has been disabled in the current beta. Please use the stable version instead
Verzonden vanaf mijn iPhone met Tapatalk Pro
emme
Post by emme »
uh.. just read the other post :P
sorry
miljume
Domoticz version: v3.8742
Post by miljume »
Any plan for when the python plugin system will be available in the beta?
I would like to use the MELCloud plugin but have installed 3.8590
I know it is possible to downgrade but as this is not recommended I would like to avoid it as long as possible
Dnpwwo
Post by Dnpwwo »
@miljume,
I believe that python plugins were re-enabled in the Beta some weeks ago
miljume
Post by miljume »
Dnpwwo wrote: Wednesday 18 October 2017 1:42 @miljume,
3.8590 is the latest beta and the plugin i try to install is not availible in HW
So something seems to be wrong with the Python module
miljume
Post by miljume »
Plugin still not working in v3.8630 (not visible in hw list)
Can someone confirm that the Python engine is activated in that version?
ycahome
Domoticz version: lat Beta
Post by ycahome »
miljume wrote: Monday 23 October 2017 22:15 Plugin still not working in v3.8630 (not visible in hw list)
Confirmed. Plugins working on both beta and stable versions. (Never disabled - i think)
emme wrote: Monday 11 September 2017 10:51 uh...
....I do have WanIP hardware installed (but I assume it is not working anymore)
Hello emme, my instance of WANIp works perfectly (indeed sometimes there are some errors on the logs due to web request timeout)
