Generic Denon / Marantz python plugin
Szmalu
Re: Generic Denon / Marantz python plugin
THX for great plugin.
There is only one issue - you can't turn on Zone 2 alone just by clicking it - If you try to - Zone 1 turns on at the same time.
Artemgy
- Domoticz version: v3.7017b
Thanks for that @Dnpwwo - I was pulling my hair out trying to work out why the latest plugin version didn't behave as expected. I upgraded to latest beta and it worked a treatDnpwwo wrote:If you update to the latest beta it should create the additional devices.
cd ~/domoticz
./updatebeta- Dnpwwo
@Szmalu,
That appears to be the way the amplifier API works and not a plugin thing.
When the amp powers on it always turns on the main zone AFAIK
Szmalu
@Dnpwwo
Not exactly. When I turn on Zone2 via http command:
It works like it supposed to (Main Zone remains off).
http://DENON_IP/MainZone/index.put.asp?cmd0=PutZone_OnOff%2FON&cmd1=aspMainZone_WebUpdateStatus%2F&ZoneName=ZONE2
Dropshot
I don't get the new hardware in the dropdown list. I've followed the guide for installing plugins. I seet this in my log:
I use the latest beta version of Domoticz.
I do see one error though, maybe this is related:
Can anyone explain what I'm possibly doing wrong?
2017-04-28 17:42:11.214 PluginSystem: Started, Python version '3.4.2'.I do see one error though, maybe this is related:
2017-04-28 17:42:16.260 Error: PluginList: Error 'Error document empty.' at line 0 column 0 in XML ''.- G3rard
- Target OS: -
- Domoticz version: No
@Dropshot, I see that error message as well, also with other plugins, but it has no effect on the working of the plugin.
The name of the plugin in the dropdown menu is Denon AVR 4306 Amplifier.
Are other plugins working for you?
@Dnpwwo, any ideas what the cause of the error message is? I also have it when my Sony Bravia plugin is restarted after pressing the Update button in the hardware menu.
I see the error is raised on 2 parts of the code https://github.com/domoticz/domoticz/se ... L%22&type=.
Not using Domoticz anymore
- Dnpwwo
@G3rard,
I haven't been able to track down this error yet. I have a permanent breakpoint set on the log line on Windows but it has never gone off. I see this too on Linux but it does not affect functionality it is a lower priority.
I've added the plugin name to the log to help narrow down where this is coming from.
- G3rard
- Target OS: -
@Dnpwwo, it does not affect the plugin indeed. Let me know if I can do some testing, as it always happens if I update my plugin.
rjblake
Thanks for this plugin - works well with my Denon AVR-X2300W. The only thing that puzzles me is the Power ON/OFF. If I use Domoticz to turn on (there is only a power switch for Main Zone created), both Main and Zone 2 are turned on. Is this because it is using the 'PWON' as opposed to 'ZMON' perhaps? I'll do some further tests to see if changing this is perhaps an option and/or to created discrete power switches for each zone instead.
- Dnpwwo
@rjblake,
I tried sending the zone on specific commands but they didn't seem to work for me unless I had turned the power was turned on first. Happy to be corrected if you do some research.
I only have the main zone set up anyway so haven't tested too much for the others.
The next major release of the Python Framework will support multiple connections and I am testing it using this plugin and sending zone on commands via http which other users claim works without turning on the main zone. Will hopefully have this done in a coupe of weeks.
rjblake
@Dnpwwo - I just tried connecting through Telnet and issuing a ZMON command and it powered on my Main Zone only. I also sent a Z2ON and this powered my Zone2 on only. This is on an AVR-X2300W. I do have to open/close the connection after each command. Looking forward to seeing your updates and will take a look at the code in the mean time
rjblake
I've gone and made some simple mods to the code for the AVR-X2300W and now each zone turns on/off when the relevant selector switch is used. The 'main' power switch turns both on/off. I also modified the list of inputs to match those for the AVR and have attached the code for those interested.
# Denon & Marantz AVR plugin
# Author: Dnpwwo, 2016 - 2017, Artemgy 2017
# Mode3 ("Sources") needs to have '|' delimited names of sources that the Denon knows about.
# The Selector can be changed afterwards to any text and the plugin will still map to the actual Denon name.
# Modified by rjblake for Denon AVR-X2300W. Only powers on the Main Zone or Zone2 when a single zone is selected. Main Power turns both Zone on/off
# Also changed names of the inputs to match those for the AVR
<plugin key="DenonMarantz" version="2.5.5" name="Denon / Marantz AVR Amplifier" author="dnpwwo/artemgy" wikilink="" externallink="http://www.denon.co.uk/uk">
<description>
Denon & Marantz AVR plugin.<br/><br/>
"Sources" need to have '|' delimited names of sources that the Denon knows about from the technical manual.<br/>
The Sources Selector(s) can be changed after initial creation to any text and the plugin will still map to the actual Denon name.<br/><br/>
Devices will be created in the Devices Tab only and will need to be manually made active.
</description>
<params>
<param field="Address" label="IP Address" width="200px" required="true" default="127.0.0.1"/>
<param field="Port" label="Port" width="30px" required="true" default="23"/>
<param field="Mode2" label="Startup Delay" width="50px" required="true">
<options>
<option label="2" value="2"/>
<option label="3" value="3"/>
<option label="4" value="4" default="true" />
<option label="5" value="5"/>
<option label="6" value="6"/>
<option label="7" value="7"/>
<option label="10" value="10"/>
</options>
</param>
# Changed for Denon AVR-X2300W
<param field="Mode3" label="Sources" width="550px" required="true" default="Off|SAT/CBL|DVD|BD|GAME|AUX1|MPLAY|TV|AUX2|TUNER|USB/IPOD|CD|BT|IRP|FVP"/>
<param field="Mode6" label="Debug" width="75px">
<options>
<option label="True" value="Debug"/>
<option label="False" value="Normal" default="true" />
</options>
</param>
</params>
</plugin>
import Domoticz
import base64
import datetime
class BasePlugin:
isConnected = False
nextConnect = 3
oustandingPings = 0
powerOn = False
mainOn = False
mainSource = 0
mainVolume1 = 0
zone2On = False
zone2Source = 0
zone2Volume = 0
zone3On = False
zone3Source = 0
zone3Volume = 0
ignoreMessages = "|SS|SV|SD|MS|PS|CV|SY|TP|"
selectorMap = {}
pollingDict = {"PW":"ZM?\r", "ZM":"SI?\r", "SI":"MV?\r", "MV":"MU?\r", "MU":"PW?\r" }
lastMessage = ""
lastHeartbeat = datetime.datetime.now()
SourceOptions = {}
def onStart(self):
if Parameters["Mode6"] == "Debug":
Domoticz.Debugging(1)
self.SourceOptions = {'LevelActions': '|'*Parameters["Mode3"].count('|'),
'LevelNames': Parameters["Mode3"],
'LevelOffHidden': 'false',
'SelectorStyle': '1'}
if (len(Devices) == 0):
Domoticz.Device(Name="Power", Unit=1, TypeName="Switch", Image=5).Create()
Domoticz.Device(Name="Main Zone", Unit=2, TypeName="Selector Switch", Switchtype=18, Image=5, Options=self.SourceOptions).Create()
Domoticz.Device(Name="Main Volume", Unit=3, Type=244, Subtype=73, Switchtype=7, Image=8).Create()
else:
if (2 in Devices and (len(Devices[2].sValue) > 0)):
self.mainSource = int(Devices[2].sValue)
self.mainOn = (Devices[2].nValue != 0)
if (3 in Devices and (len(Devices[3].sValue) > 0)):
self.mainVolume1 = int(Devices[3].sValue) if (Devices[3].nValue != 0) else int(Devices[3].sValue)*-1
if (4 in Devices and (len(Devices[4].sValue) > 0)):
self.zone2Source = int(Devices[4].sValue)
self.zone2On = (Devices[4].nValue != 0)
if (5 in Devices and (len(Devices[5].sValue) > 0)):
self.zone2Volume = int(Devices[5].sValue) if (Devices[5].nValue != 0) else int(Devices[5].sValue)*-1
if (6 in Devices and (len(Devices[6].sValue) > 0)):
self.zone3Source = int(Devices[6].sValue)
self.zone3On = (Devices[6].nValue != 0)
if (7 in Devices and (len(Devices[7].sValue) > 0)):
self.zone3Volume = int(Devices[7].sValue) if (Devices[7].nValue != 0) else int(Devices[7].sValue)*-1
if (1 in Devices):
self.powerOn = (self.mainOn or self.zone2On or self.zone3On)
DumpConfigToLog()
dictValue=0
for item in Parameters["Mode3"].split('|'):
self.selectorMap[dictValue] = item
dictValue = dictValue + 10
Domoticz.Transport("TCP/IP", Parameters["Address"], Parameters["Port"])
Domoticz.Protocol("Line")
Domoticz.Connect()
return
def onConnect(self, Status, Description):
if (Status == 0):
self.isConnected = True
Domoticz.Log("Connected successfully to: "+Parameters["Address"]+":"+Parameters["Port"])
Domoticz.Send('PW?\r')
Domoticz.Send('ZM?\r', Delay=1)
Domoticz.Send('Z2?\r', Delay=2)
Domoticz.Send('Z3?\r', Delay=3)
else:
self.isConnected = False
self.powerOn = False
Domoticz.Log("Failed to connect ("+str(Status)+") to: "+Parameters["Address"]+":"+Parameters["Port"])
Domoticz.Debug("Failed to connect ("+str(Status)+") to: "+Parameters["Address"]+":"+Parameters["Port"]+" with error: "+Description)
self.SyncDevices()
return
def onMessage(self, Data, Status, Extra):
self.oustandingPings = self.oustandingPings - 1
strData = Data.decode("utf-8", "ignore")
Domoticz.Debug("onMessage called with Data: '"+str(strData)+"'")
strData = strData.strip()
action = strData[0:2]
detail = strData[2:]
if (action in self.pollingDict): self.lastMessage = action
if (action == "PW"): # Power Status
if (detail == "STANDBY"):
elif (detail == "ON"):
self.powerOn = True
else: Domoticz.Debug("Unknown: Action "+action+", Detail '"+detail+"' ignored.")
elif (action == "ZM"): # Main Zone on/off
self.mainOn = True
elif (detail == "OFF"):
self.mainOn = False
elif (action == "SI"): # Main Zone Source Input
for key, value in self.selectorMap.items():
if (detail == value): self.mainSource = key
elif (action == "MV"): # Master Volume
if (detail.isdigit()):
if (abs(self.mainVolume1) != int(detail[0:2])): self.mainVolume1 = int(detail[0:2])
elif (detail[0:3] == "MAX"): Domoticz.Debug("Unknown: Action "+action+", Detail '"+detail+"' ignored.")
else: Domoticz.Log("Unknown: Action "+action+", Detail '"+detail+"' ignored.")
elif (action == "MU"): # Overall Mute
if (detail == "ON"): self.mainVolume1 = abs(self.mainVolume1)*-1
elif (detail == "OFF"): self.mainVolume1 = abs(self.mainVolume1)
elif (action == "Z2"): # Zone 2
# Zone 2 response, make sure we have Zone 2 devices in Domoticz and they are polled
if (4 not in Devices):
LevelActions = '|'*Parameters["Mode3"].count('|')
Domoticz.Device(Name="Zone 2", Unit=4, TypeName="Selector Switch", Switchtype=18, Image=5, Options=self.SourceOptions).Create()
Domoticz.Log("Zone 2 responded, devices added.")
if (5 not in Devices):
Domoticz.Device(Name="Volume 2", Unit=5, Type=244, Subtype=73, Switchtype=7, Image=8).Create()
if ("Z2" not in self.pollingDict):
self.pollingDict = {"PW":"ZM?\r", "ZM":"SI?\r", "SI":"MV?\r", "MV":"MU?\r", "MU":"Z2?\r", "Z2":"PW?\r" }
self.zone2On = True
self.zone2On = False
elif (detail == "MUON"):
self.zone2Volume = abs(self.zone2Volume)*-1
elif (detail == "MUOFF"):
elif (detail.isdigit()):
if (abs(self.zone2Volume) != int(detail[0:2])): self.zone2Volume = int(detail[0:2])
else:
if (detail == value): self.zone2Source = key
elif (action == "Z3"): # Zone 3
# Zone 3 response, make sure we have Zone 3 devices in Domoticz and they are polled
if (6 not in Devices):
Domoticz.Device(Name="Zone 3", Unit=6, TypeName="Selector Switch", Switchtype=18, Image=5, Options=self.SourceOptions).Create()
Domoticz.Log("Zone 3 responded, devices added.")
if (7 not in Devices):
Domoticz.Device(Name="Volume 3", Unit=7, Type=244, Subtype=73, Switchtype=7, Image=8).Create()
if ("Z3" not in self.pollingDict):
self.pollingDict = {"PW":"ZM?\r", "ZM":"SI?\r", "SI":"MV?\r", "MV":"MU?\r", "MU":"Z2?\r", "Z2":"Z3?\r", "Z3":"PW?\r" }
self.zone3On = True
self.zone3On = False
self.zone3Volume = abs(self.zone3Volume)*-1
if (abs(self.zone3Volume) != int(detail[0:2])): self.zone3Volume = int(detail[0:2])
else:
if (detail == value): self.zone3Source = key
else:
if (self.ignoreMessages.find(action) < 0):
Domoticz.Debug("Unknown message '"+action+"' ignored.")
self.SyncDevices()
return
def onCommand(self, Unit, Command, Level, Hue):
Domoticz.Log("onCommand called for Unit " + str(Unit) + ": Parameter '" + str(Command) + "', Level: " + str(Level))
Command = Command.strip()
action, sep, params = Command.partition(' ')
action = action.capitalize()
params = params.capitalize()
delay = 0
if (self.powerOn == False):
delay = int(Parameters["Mode2"])
else:
# Amp will ignore commands if it is responding to a heartbeat so delay send
lastHeartbeatDelta = (datetime.datetime.now()-self.lastHeartbeat).total_seconds()
if (lastHeartbeatDelta < 0.5):
delay = 1
Domoticz.Log("Last heartbeat was "+str(lastHeartbeatDelta)+" seconds ago, delaying command send.")
if (Unit == 1): # Main power switch
if (action == "On"):
Domoticz.Send(Message='ZMON\r')
Domoticz.Send(Message='Z2ON\r')
elif (action == "Off"):
Domoticz.Send(Message='ZMOFF\r', Delay=delay)
Domoticz.Send(Message='Z2OFF\r', Delay=delay)
# Main Zone devices
elif (Unit == 2): # Main selector
elif (action == "Set"):
if (self.powerOn == False): Domoticz.Send(Message='ZMON\r')
Domoticz.Send(Message='SI'+self.selectorMap[Level]+'\r', Delay=delay)
elif (Unit == 3): # Main Volume control
Domoticz.Send(Message='MUOFF\r', Delay=delay)
Domoticz.Send(Message='MV'+str(Level)+'\r', Delay=delay)
Domoticz.Send(Message='MUON\r', Delay=delay)
# Zone 2 devices
elif (Unit == 4): # Zone 2 selector
Domoticz.Send(Message='Z2ON\r', Delay=delay)
if (self.zone2On == False):
delay += 1
Domoticz.Send(Message='Z2'+self.selectorMap[Level]+'\r', Delay=delay)
delay += 1
Domoticz.Send(Message='Z2?\r', Delay=delay)
elif (Unit == 5): # Zone 2 Volume control
# if (self.powerOn == False): Domoticz.Send(Message='PWON\r')
delay += 1
Domoticz.Send(Message='Z2MUOFF\r', Delay=delay)
Domoticz.Send(Message='Z2'+str(Level)+'\r', Delay=delay)
Domoticz.Send(Message='Z2MUON\r', Delay=delay)
# Zone 3 devices
elif (Unit == 6): # Zone 3 selector
Domoticz.Send(Message='Z3ON\r', Delay=delay)
if (self.zone3On == False):
delay += 1
Domoticz.Send(Message='Z3'+self.selectorMap[Level]+'\r', Delay=delay)
delay += 1
Domoticz.Send(Message='Z3?\r', Delay=delay)
Domoticz.Send(Message='Z3OFF\r', Delay=delay)
elif (Unit == 7): # Zone 3 Volume control
delay += 1
Domoticz.Send(Message='Z3MUOFF\r', Delay=delay)
Domoticz.Send(Message='Z3'+str(Level)+'\r', Delay=delay)
Domoticz.Send(Message='Z3MUON\r', Delay=delay)
return
def onDisconnect(self):
Domoticz.Log("Denon device has disconnected.")
return
def onHeartbeat(self):
if (self.isConnected == True):
if (self.oustandingPings > 5):
Domoticz.Disconnect()
self.nextConnect = 0
else:
Domoticz.Send(self.pollingDict[self.lastMessage])
Domoticz.Debug("onHeartbeat: self.lastMessage "+self.lastMessage+", Sending '"+self.pollingDict[self.lastMessage][0:2]+"'.")
self.oustandingPings = self.oustandingPings + 1
else:
# if not connected try and reconnected every 3 heartbeats
self.oustandingPings = 0
self.nextConnect = self.nextConnect - 1
if (self.nextConnect <= 0):
self.nextConnect = 3
Domoticz.Connect()
self.lastHeartbeat = datetime.datetime.now()
return
def SyncDevices(self):
UpdateDevice(1, 0, "Off")
UpdateDevice(2, 0, "0")
UpdateDevice(3, 0, str(abs(self.mainVolume1)))
UpdateDevice(4, 0, "0")
UpdateDevice(5, 0, str(abs(self.zone2Volume)))
UpdateDevice(6, 0, "0")
UpdateDevice(7, 0, str(abs(self.zone3Volume)))
else:
UpdateDevice(1, 1, "On")
UpdateDevice(2, self.mainSource if self.mainOn else 0, str(self.mainSource if self.mainOn else 0))
if (self.mainVolume1 <= 0 or self.mainOn == False): UpdateDevice(3, 0, str(abs(self.mainVolume1)))
else: UpdateDevice(3, 2, str(self.mainVolume1))
UpdateDevice(4, self.zone2Source if self.zone2On else 0, str(self.zone2Source if self.zone2On else 0))
if (self.zone2Volume <= 0 or self.zone2On == False): UpdateDevice(5, 0, str(abs(self.zone2Volume)))
else: UpdateDevice(5, 2, str(self.zone2Volume))
UpdateDevice(6, self.zone3Source if self.zone3On else 0, str(self.zone3Source if self.zone3On else 0))
if (self.zone3Volume <= 0 or self.zone3On == False): UpdateDevice(7, 0, str(abs(self.zone3Volume)))
else: UpdateDevice(7, 2, str(self.zone3Volume))
return
global _plugin
_plugin = BasePlugin()
def onStart():
global _plugin
_plugin.onStart()
def onConnect(Status, Description):
global _plugin
_plugin.onConnect(Status, Description)
def onMessage(Data, Status, Extra):
global _plugin
_plugin.onMessage(Data, Status, Extra)
def onCommand(Unit, Command, Level, Hue):
global _plugin
_plugin.onCommand(Unit, Command, Level, Hue)
def onDisconnect():
global _plugin
_plugin.onDisconnect()
def onHeartbeat():
global _plugin
_plugin.onHeartbeat()
def UpdateDevice(Unit, nValue, sValue):
# Make sure that the Domoticz device still exists (they can be deleted) before updating it
if (Unit in Devices):
if (Devices[Unit].nValue != nValue) or (Devices[Unit].sValue != sValue):
Devices[Unit].Update(nValue, str(sValue))
Domoticz.Log("Update "+str(nValue)+":'"+str(sValue)+"' ("+Devices[Unit].Name+")")
return
def DumpConfigToLog():
for x in Parameters:
if Parameters[x] != "":
Domoticz.Debug( "'" + x + "':'" + str(Parameters[x]) + "'")
Domoticz.Debug("Device count: " + str(len(Devices)))
for x in Devices:
Domoticz.Debug("Device: " + str(x) + " - " + str(Devices[x]))
Domoticz.Debug("Internal ID: '" + str(Devices[x].ID) + "'")
Domoticz.Debug("External ID: '" + str(Devices[x].DeviceID) + "'")
Domoticz.Debug("Device Name: '" + Devices[x].Name + "'")
Domoticz.Debug("Device nValue: " + str(Devices[x].nValue))
Domoticz.Debug("Device sValue: '" + Devices[x].sValue + "'")
Domoticz.Debug("Device LastLevel: " + str(Devices[x].LastLevel))
return
def stringToBase64(s):
return base64.b64encode(s.encode('utf-8')).decode("utf-8")
def base64ToString(b):
return base64.b64decode(b).decode('utf-8')
amontillado
I have trouble getting the plugin to work.
The plugin is available in the Hardware Dropdown List (Denon / Marantz AVR Amplifier) but when I try to Add it nothing happens.
The log shows no related error messages.
Plugin version 2.5.5 , Domoticz version 3.7450
Any ideas of what might be the cause?
rjblake
Perhaps start with the basics. Can you control the AVR from the official Denon app (IOS/Android), or connect through browser? Is the IP address of your AVR entered correctly and saved? Is the "IP Control" on the AVR set to "Always On"? Does the list of Inputs in the Domoticz Hardware match those for your model AVR (as per the Denon spreadsheet) exactly?amontillado wrote:I have trouble getting the plugin to work.
amontillado
Thanks for the quick reply.
Yes I can connect to the AVR using the App, as wel as via the XML api, using the IP I entered. The "IP Control" setting on the AVR is "Always on".
I've changed the list of sources, my exact model (Marantz SR6010) isn't listed in one of the sheet, but the previous and subsequent models are.
I didn't add all the sources, and after the unsucessfull first test now only added the Tuner.
From my first (somewhat amateuristic) glance at the code I didnt think all the sources should be added.
The strange thing is that I see absolutly nothing in the log, regardles of the "debug" setting being set to true or not.
All I see that is relevant is some metionins of the pluginsystem (PluginSystem: Started, Python version '3.4.2'. // PluginSystem: Entering work loop.)
but none of the plugin.
can anyone help me with my error ?
2017-05-18 08:49:05.698 Error: PluginList: Error 'Error reading Attributes.' at line 24 column 28 in XML '
Denon AVR plugin.
Denon AVR plugin.
rjblake
Seems you don't have the inputs named to match your specific AV Receiver. What model number do you have?Andyyyy wrote:Hi all,
Denon AVR plugin.
Hello rjblake,
i copy the plugin.py (with your code) to /domoticz/plugins/denon/plugin.py and then i restart Domoticz.
Next i go to the Hardware Page and then i get this error, i did not see the Denon Plugin in the Hardware pulldown, but i see the error in the log.
Andyyyy
Andyyyy
rjblake
What platform are you running Domoticz on? What version of Domoticz are you running?
Did you change the owner and/or rights of the plugin.py and the /denon/ folder to Executable (or RWX) if on *nix or Pi?
Hello rjblake,
I use Domoticz 3.7450 on a Raspberr Pi.
I changed to 755 witz user Pi ..
What else i have to change ??
Andyyyy
Andyyyy
