HansieNL
Post by HansieNL »
Trigun wrote:Hi Guy's, i al looking to install the Calendar feature but i was wondering if it is possible to install the google calendar of a different account than setup on the specific device. Reason for this question is that I don't see a place where you put in you credentials of the desired account.
You can use the private ical link from a Google calender.
Blah blah blah
htilburgs
Re: Dashticz - Module - Calendar
Post by htilburgs »
HansieNL wrote:
htilburgs wrote:
HansieNL wrote:Is it possible to change the height of the title block of the calendar?
Can you tell me how you add this calendar? I'm very interested!
1. The calendar is a .ics file from Formula 1 site https://www.formula1.com/sp/static/f1/2 ... r/ical.ics
2. Created a new Google calendar Formule 1 Race
3. Choose import from local file and selected Formule 1 Race calender to import to
4. I used the Googles' Formule 1 Race calender private address in Dashticz calendar
calendars.f1 = { maxitems: 7, title: 'Formule 1 Kalender', icalurl: 'https://calendar.google.com/calendar/ic ... /basic.ics' }
Thnx... Working!
Hardware:
HansieNL
Post by HansieNL »
htilburgs wrote:
HansieNL wrote:
htilburgs wrote: Can you tell me how you add this calendar? I'm very interested!
Thnx... Working!
You're welcome. My problem with Homey and an ical is also solved now. Homey told me the race was gonna start over 60 minutes and a nice race sound was played. Only a shame Max didn't finish.
Blah blah blah
Trigun
Domoticz version: 4.10717
Post by Trigun »
EdKo66 wrote:Samsung is Android ;)
Haha ok, i guess i should have been more specific ;) i meant Wich version. @ jake, Are you on the latest? If not; perhaps an update of Your os is an option?
Also, try downloading another browser on the tab.
bsmeding
Post by bsmeding »
Does someone know how to enable an popup on a switch?
I want to create an popup on the status icon if someone is offline and the status icon i red, then when you clock on the user it will popup an google maps card with the location.
same window when clicking the buttons.webcam or buttons.news but than for a switch.
Feature maybe? When adding to config.js ? so every block can have an popup window?
buttons.block[xxx] { url:http://www.url.to'}
or
block[xxx]:url:http://www.url.to'}
Schermafbeelding 2017-05-03 om 17.05.40.png (81.97 KiB) Viewed 2882 times
jake
Post by jake »
After I saw in the 'show your dashticz' topic that user Swordfish used this device, I googled it at XDA and found a broad community around it. I therefore bought a 2nd hand one on Marktplaats, put TWRP and 2 different flavors of Android 7.1.2 on it. Both firmwares behave the same way as I described.
So far I tried with a blank CM 14.1 version the 'Full Kiosk Browser' and 'Chrome'. On my current firmware (Xenon HD, for what's in a name) I only used 'Chrome' with equal issues.
Obviously the clock value is a GMT value (2hr behind Amsterdam), while the tablet itself is in the right time zone. I checked the RPI and also there both the time is accurate and the time zone is specified correctly.
I am on the latest beta and started to disable functions, like the buienradar and news feed, traffic and train info, but to no avail.
SwordFish
Domoticz version: V4.11375
Post by SwordFish »
Is you're tablet rooted?
I use the original firmeware (4.4.2) and chrome browers (Shortcut to Dashticz on homescreen).
Have no problems with running Dashticz or time or graph.
page 3.jpg (58.38 KiB) Viewed 2818 times
page 1.jpg (120.3 KiB) Viewed 2818 times
Derik
Post by Derik »
Is there somebody that has a good advise for a cheap 12 or 13 inch tablet
NicoLP
Post by NicoLP »
What temp meters for 433mhz are good for domoticz or dashticz ???
or what do you guys use
Nico
blacksn0w
Post by blacksn0w »
NicoLP wrote:What temp meters for 433mhz are good for domoticz or dashticz ???
Nico
I'm using some cheap Xiaomi Temperatur/Humidity Sensors in combination with the hub. Perfect interaction with Domoticz, extremely small and perfect build quality.
NicoLP
Post by NicoLP »
where did you buy it ??
Nico
jake
Post by jake »
SwordFish wrote:
jake wrote:
Trigun wrote: Haha ok, i guess i should have been more specific ;) i meant Wich version. @ jake, Are you on the latest? If not; perhaps an update of Your os is an option?
The tablet is rooted indeed. I installed System Monitor on the tablet. In the graph/log I can see that it is using 70+% when Dashticz is running, but only 5-10% when the home screen is visible (I used a widget to show CPU/mem usage) Memory consumption overall is only 34%, so plenty left.
I wonder why Dashticz uses so much CPU time (I changed CPU governor to 'Performance' to rule out a 'smart' governor which would concentrate on battery performance).
Based on logic and Swordfishes experience, I don't think this tablet is too slow/old to run a webpage like this (Duo core 1.5 GHz and 1.5Gb. RAM). I now also disabled animated weather icons, just to be sure.
After 3 days of showing the Dashticz interface nonetheless, I was surprised when I came home today and found the time had corrected itself to local time. No idea what triggered that, but so far so good.
SwordFish
Post by SwordFish »
I now that when I want to show the graphs from my nest thermostat the dashboard get slowly, I think because it's has dots every 5 minutes and take some time to load. But when I remove it it runs smoothly.
madrian
Post by madrian »
(Relatively) cheap 3D printed iPad holder:
philuxe
Post by philuxe »
congratulation to Rob for the good work !
I read most of the previous 117 pages yesterday and found some users (two if I remember well) who reported high cpu issues and I believe I have the same behavior (OSX + chrome in my case), so I was wondering whether there was some fix/workaround or not ? I did not notice the same cpu usage on the iphone .
Second point, I use a couple of temp/humidity sensor, the same device report two values with one block definition :
blocks[40] = {} // TEMP ROOM_1
blocks[40]['width'] = 6;
then form the column definition I can make a reference to '40_1' for temperature or '40_2' for humidity only however the block is not clickable anymore and I dont get the graph.
On the other side when the same sensor produce two blocks both are clickable but each of them points to the temperature graph. Any idea ?
Last request :D is there a way to translate 'grafiek' in the graph pop up (when you pass ur mouse over the line ) ?
bye and thanks again for all the efforts
cyberclwn
Domoticz version: 2024.4
Post by cyberclwn »
Hey,
Thanks for the great work.
But there are somethings i don't know how to get working on dashticz:
1. I have a radiator-valve from Smartwares. it uses 2 devices. One is day/night (on/off) and one to use to set temperature/setpoint with. But if i add both to dashticz/CONFIG.js they both are shown as on/off devices. I can't find a way to show the 2nd device as a thermostat-option.
2. Can't get a google calendar displayed on my dahsticz, but i read you are working on changing a lot on that topic, so i wait for that. (there is a %-sign in my address, maybe that is messing things up tho)
There is a lot of posts to search thru, i apologize if i missed the solution somewhere.
3xPi 2B (Domoticz "live", Domoticz "sandbox", PhotoFrame)
RFXCom433(E), KaKu, Oregon Scientific, Keyes 2-relay, Logitech Media Server, MiLight, Smartwares heating controller(2x), IR Send/Receive, Keyes PIR, XH-M131 DuskSensor, DHT22/11
philuxe
Post by philuxe »
Nico
I recommand Oregon Scientific THGR 810 for inside and Oregon Scientific THGR 122 NX.
Oregon Scientific THGR 122 NX is normally for inside but you can put it outisde under a shelter
they are very accurate and good quality product , you will need the Rfxcom
EdwinK
Post by EdwinK »
cyberclwn wrote:Hey,
If you mean ' %40', that5 is the HTML-code for the '@' symbol.
Derik
Post by Derik »
mm i set multiple screens..on dashticz swiping automaticly..
only swipe everytime to the last screen instat to the first
can i set somewhere the swipe stop by the first?
Or a random swipe to all screens, and wait x minute on the first?
Ierlandfan
Post by Ierlandfan »
Offtopic: If you want to play around with 433 mhz sensors like temp/humidity/doorbell/(insert-sensor here) or already have a weather station, you can use rxcom or use the (much cheaper) Arduino+433mhz+rflink firmware way.
Locked
