Have you checked here... https://developers.google.com/maps/docu ... avascript/remb0 wrote:When I use google maps the map is visible and after a few seconds i got: Oops something got wrong.
press F12 for ....
The message is that my api key isn't activated.
can somebody tell me how to create? I had it worked a few years before but I got the message: not activated now.
- HansieNL
Blah blah blah
ok, we were talking beside each other ( lekker hollands)HansieNL wrote:Ahhhh... You are using the nice stationclock. No, the variable is not for the stationclock.qwerk wrote:robgeerts wrote:Impossible
At least, if you are sure nothing gets cached and you have the latest beta
I can make the impossible, possible
I tried everything, I removed the ":ss" from main.js where the variable is checked.
same result.
Sure the stationclock is getting his info from clock???
As a workaround you can edit your main.js and change clock.secondHand = StationClock.HoleShapedSecondHand; to clock.secondHand = StationClock.NoSecondHand; and ask Rob to add a variable for it.
I get it, I used the wrong clock for this.
I like the stationclock better, for now I will take the stottering second hand.
And I will ask Rob to add a variable.
thanks HansieNL
- Domoticz version: 3.7067
In latest beta the variable is ALSO for the stationclockHansieNL wrote:Ahhhh... You are using the nice stationclock. No, the variable is not for the stationclock.qwerk wrote:robgeerts wrote:Impossible
same result.
In latest beta, may scrolling is disabled? I have 3 pages, but cannout scroll. I do see three small dots in the bottom (smaller than before), but cannot reach page 2 and 3. I do see a small bit of the second page at the right border of the first page.
Someone else with this problem?
Edit: only seems to be broken in firefox...
- wizjos
I can confirm that... In FF you see a small 'preview' of the next page. Edge doesn't show this. And indeed in both browsers the navigational dots are fairly small compared to before and blue instead of white (before)...lukev wrote:In latest beta, may scrolling is disabled? I have 3 pages, but cannout scroll. I do see three small dots in the bottom (smaller than before), but cannot reach page 2 and 3. I do see a small bit of the second page at the right border of the first page.
Wizjos
- wizjos
wizjos wrote:I can confirm that... In FF you see a small 'preview' of the next page at the far right. Edge doesn't show this. And indeed in both browsers the navigational dots are fairly small compared to before and blue in stead of white (before)...lukev wrote:In latest beta, may scrolling is disabled? I have 3 pages, but cannout scroll. I do see three small dots in the bottom (smaller than before), but cannot reach page 2 and 3. I do see a small bit of the second page at the right border of the first page.
Wizjos
Hmm its working fine at my laptop in firefox...
The dots where gone before but are back sinds last update... wil remove them again
Try latest beta!
Try latest beta!
For the RSS, I was able to make the XML work with crossorigin.me but, it displays the whole article. It would be nice to only have the Title, that way, we can display more news in less spacegodinperson wrote:Can't place my rss. Would that link work: http://www.rds.ca/cmlink/le-fil-de-pres ... ttes-1.831 (French sports). I would also have another link which is in XML http://www.lapresse.ca/rss/225.xml
For the media player, which one is it? It would be nice to have a widget where it shows currently playing and basic control. I can help gather the information is you want.
- Domoticz version: 3.5877
in calendar i see for whole day entrys "hele dag" in front of entry, is there any way to change this to my language?
For sure i can do it in calendar.js but after every update it will change back. Using last beta.
- Domoticz version: 4.10717
Hi mvveelen,mvveelen wrote:I was wondering: Is it possible to get the "var _SHOW_LASTUPDATE" per device?
For instance: I couldn't care less when the last time it was when I switch off a light, but it would be nice to see when a door sensor has been opened/closed.
Did you manage to set this up? I am looking for a similar thing.
Grtz
Sent from my iPad using Tapatalk
- HansieNL
Nooooooo... I'm using the normal clock without seconds in 1st screen and StationClock with seconhand in 2nd screen.robgeerts wrote:In latest beta the variable is ALSO for the stationclock
Now my lovely secondhand of the StationClock is gone
Can you create for the StationClock secondhand an other variable?
Blah blah blah
Done in latest beta
New var voor stationclock is:
var _HIDE_SECONDS_IN_STATIONCLOCK = false;
- EdwinK
- Domoticz version: BETA
Evil... Latest git pull wanted to overwrite my custom.js.
Luckily I always have backup
Yes I accidentially overwrote this file
PLEASE BACKUP PEOPLE!!
- EdwinK
Good thing GIT warns you about it before you really do any damage
Trying to ingnore this file but because it is commited before this is not so easy
- EdwinK
No harm done. It was exact what I already had (minus the IDX)
Ok, fixed now but you can get the overwrite warning once more...
From then it wont happen again...
BACKUP CUSTOM.JS!
BACKUP CUSTOM.JS!
- EdwinK
- Domoticz version: 3.8993
Always responsibility of the user to make backupsrobgeerts wrote:Trying to ingnore this file but because it is commited before this is not so easy
