LuaSocket on Synology DS716+ with a 64 bit Intel Celeron N3150 processor
mhwlng
Post by mhwlng »
to get the LuaSocket library working on a Synology DS716+ with a 64 bit Intel Celeron N3150 processor
take usrlocalliblua5p2.tar.gz and usrlocalsharelua5p2.tar.gz from this thread :
http://www.domoticz.com/forum/viewtopic ... 638#p22638
which contains core.so for raspberry pi ARM processor.
Then replace these core.so with the 64 bit versions from this github project :
https://github.com/pkulchenko/ZeroBraneStudio
\ZeroBraneStudio-master\bin\linux\x64\clibs52\mime\core.so
\ZeroBraneStudio-master\bin\linux\x64\clibs52\socket\core.so
(note that I have not tested the 32 bit versions of core.so from above github project on other Synology NAS devices with a 32 bit intel processor.)
Put the files here (directories didn't exist) :
/usr/local/lib/lua/5.2/mime/core.so
/usr/local/lib/lua/5.2/socket/core.so
/usr/local/share/lua/5.2/*.lua
/usr/local/share/lua/5.2/socket/*.lua
/usr/local/share/lua/5.2/socket/core.so
This now works :
local socket = require("socket")
local http = require("socket.http")
print(socket._VERSION)
print(http.request("http://w3.impa.br/~diego/software/luasocket/"))
ricvee
Domoticz version: Stable
Re: LuaSocket on Synology DS716+ with a 64 bit Intel Celeron N3150 processor
Post by ricvee »
What do you mean with:
Do I have to delete these files?
I followed your instructions, an now I get this error:
2016-05-25 18:06:05.282 Error: EventSystem: in pv.lua: error loading module 'socket.core' from file '/usr/local/lib/lua/5.2/socket/core.so':
/usr/local/lib/lua/5.2/socket/core.so: invalid ELF header
mhwlng
Post by mhwlng »
create the directories and put all the lua files in there
(don't make a directory with the name '*.lua')
invalid elf header probably means that you use 32 bit executable files on a 64 bit processor or the other way around (or you have an arm processor instead of an intel processor)
Gravityz
Domoticz version: 2025.1
Post by Gravityz »
Can anybody help me out with the correct lua socketlibrary for a synology 112+ (MARVELL Kirkwood 88F6282 cpu)
i tried above suggestions and took the 32 bit core.so form github but apparently that one is not for this cpu.
thanks
TroisSix
Domoticz version: 2025.2
Post by TroisSix »
Hi, I also followed instructions of mhwlng, but no luck on my DS412+ (Atom 2700 cedarview 64bits), the two core.so files are not functional for my syno: neither 64b nor 32bits... I get the same error as ricvee, has anyone found a solution?
Thanks for you help
VM Debian - Domoticz stable v2025.2, RFXtrx433, Aeotec Z-Stick Gen5, Zigbee, Two APC
- rts: dio, oregon, somfy
- zwave: fibaro fgs212, aeotec smart switch, vision ZG8101
- IO Homecontrol: Velux Connexoon
- philips hue, Pilot app.
TroisSix
Post by TroisSix »
Has someone any idea please? :roll:
My Pi3 works well with the philips hue script, but I'm still searching for a compatible solution on my NAS ;)
