Hello, i want an action to be performed when i push a button for 3 times within 5 sec.
How can i manage this?
logic function
- Arkie
logic function
Synology DS412+
Philips Hue
Fibaro
Logitech Hamony elite
Foscam 9804 ip cam
RFXtrx433E USB 433.92MHz
ZXT 120 eu AC controller
Heatmiser NEO stat thermostats and Hub
Philips Hue
Fibaro
Foscam 9804 ip cam
- Domoticz version: 3.5877
Re: logic function
You need to use LUA - you can't do this in Blockly, but you can use the lastupdate value and time difference functions in LUA to achieve this.
AEOTEC ZStick, 11 ZWave Nodes, RFXCOMM, 50ish Byron Sockets.. HE851 (PIR), 2x HE852 (DoorContact)
WS2300, CM180, CC128, 2xTHGR122NX, 2xPiZeroW w/DS18B20, 8Ch 1W Relay Board.
8 Panasonic IP Cams, 1 16ch CCTV DVR + 15 CCTV Cams
- Domosapiens
- Domoticz version: V3.5981
Re: logic function
You could try something like this:
Define 2 dummy buttons
Push1 with Off_delay of 5 sec.
Push2 with Off_delay of 4 sec.
Assume you push button named Push
Blockly:
Blockly:
If Push=on And Push1=off
Set Push1=on
ElseIf Push=on And Push1=on
Set Push2=on
ElseIf Push=on And Push1=on And Push2=on
<perform action>
