SwordFish
- Domoticz version: V4.11375
Thanks you guys, I have that all, but when you use the custom.js to change the on and off text to aanwezig and afwezig the last seen isn't working. When I remove it from the custom.js then it works like you guys say. Do I make any sense
bsmeding
Hi Ricardo,rpwessels wrote:Hello,
Can somebody help me, checked this discussion already but calendar(apple) is still not displaying. Changed CONFIG.js calendar settings in "var _ICALENDAR_URL = 'webcal://p32-calendars.icloud.com/published/2/i..... etc"
and placed 'icalendar' in column . Nothing is showing. What do i forget.
Ricardo
You have to wait a little more for the correct calendar plugin, see special calendar thread https://www.domoticz.com/forum/viewtopi ... 67&t=17425
bsmeding
can you post the custom.jsSwordFish wrote:Thanks you guys, I have that all, but when you use the custom.js to change the on and off text to aanwezig and afwezig the last seen isn't working. When I remove it from the custom.js then it works like you guys say. Do I make any sense
SwordFish
Will do later, have to eat first
SwordFish
So this is the code in custom.jsSwordFish wrote:I have in the custom.js code that turns on/off into aanwezig/afwezig (see Andrew thuis?). Is it right that last seen then don't work? When i quote it out then last seen is working. Is it possible to get it anyway with custum.js.
function getBlock_338(device,idx){ //change 233 to the idx of your device!
$('.block_'+idx).attr('onclick','switchDevice(this)');
var html='';
html+='<div class="col-xs-4 col-icon">';
if(device['Status']=='Off') html+=iconORimage(idx,'fa-toggle-off','','off icon');
else html+=iconORimage(idx,'fa-toggle-on','','on icon');
html+='</div>';
html+='<div class="col-xs-8 col-data">';
html+='<strong class="title">'+device['Name']+'</strong><br />';
if(device['Status']=='Off') html+='<span class="state">Afwezig</span>';
else html+='<span class="state">Aanwezig</span>';
html+='</div>';
return html;
rpwessels
- Domoticz version: V3.5641
Hello ,
I will wait and follow the discussion.
Ricardo
Ricardo
Ubuntu16.04 LTS | Z-wave | Opentherm | P1 Smartmeter
Without crossorigin.me of the front of the url it newer going to work.rpwessels wrote:Hello,
Ricardo
Swifty
OK, that was simplepkrabben wrote:Did you trySwifty wrote:I tried to set dashticz up on a windows tablet last night but all I got was 500 - Internal server error when browsing to the url.
My steps were as the wiki - done a git clone of the master into domoticz/www/dashboard, cp CONFIG_DEFAULT.js to CONFIG.js.
Edit the CONFIG.js to point at my local domoticz server (which uses auth, so specified as http://user:pass@my_ip:8080)
Set language to english.
I've tried a restart of the domoticz installation, just in case it needed to refresh anything from the new directory, but I still get a 500 error when browsing.
Any sort of log I can look at to troubleshoot?
http://IP address:port/{dashboard folder}/index.html
Didn't even think to try that.
Many thanks
repoman
Hi folks,
I've downloaded the latest beta and i like the moving weather icons. I'm also happy to see that the news items are scrolling again. Thnx!
The problem I have is with the dual output blocks. I'm using a youless device to monitor energy usage.
When I use 'idx_1' I get te total power usage of today and when I use 'idx_2' I get the total power usage.
I would like to see the current power usage. ('ídx_3' gives me an emty block...)
Related to this is are the temperature sensors. I suspect it should be possible to use i.e. 'idx_1'for temperature and 'idx_2' for humidity but it doesn't.
I still get two blocks while I only need the temperature reading..
Probably something stupid but I can't find it in the wiki..
A little help is much appreciated.
Thnx,
Pascal
Thnx,
Pascal
tontze
- Domoticz version: Beta Ch
Aha, ok thnxEdKo66 wrote:This is an indication that something IS wrong in your config. Not necessarily in the HOST_DOMOTICZ variable, but might be something further down the line. So double check if you might have forgotten a ';' or something trivial like that.
Smartthings
zigbee2mqtt
RFLink 433mhz / Nrf 2.4Ghz
Mi Light
esp8266MiLight Hub
Smartthings
zigbee2mqtt
Mi Light
esp8266MiLight Hub
bsmeding
Try to use this:SwordFish wrote:So this is the code in custom.jsSwordFish wrote:I have in the custom.js code that turns on/off into aanwezig/afwezig (see Andrew thuis?). Is it right that last seen then don't work? When i quote it out then last seen is working. Is it possible to get it anyway with custum.js.
var html='';
html+='</div>';
if(_SHOW_LASTUPDATE) html+='<br /><span class="lastupdate">'+moment(device['LastUpdate']).format(_LASTUPDATE_FORMAT)+'</span>';
html+='</div>';
return html;
qwerk
Does anybody know of an easy way to adjust multiple blocks in one go:
I now have:
blocks[1321] = {}
blocks[1321]['width'] = 5
is there a way to also apply this for device 1329 without copying the two lines?
like: blocks[1321]-[1329] = {} etc etc
I now have:
blocks[1321] = {}
SwordFish
That didn't work, sorry ( did also clear cache )Try to use this:
added : if(_SHOW_LASTUPDATE) html+='<br /><span class="lastupdate">'+moment(device['LastUpdate']).format(_LASTUPDATE_FORMAT)+'</span>';Code: Select all
function getBlock_338(device,idx){ //change 233 to the idx of your device! $('.block_'+idx).attr('onclick','switchDevice(this)'); var html=''; html+='<div class="col-xs-4 col-icon">'; if(device['Status']=='Off') html+=iconORimage(idx,'fa-toggle-off','','off icon'); else html+=iconORimage(idx,'fa-toggle-on','','on icon'); html+='</div>'; html+='<div class="col-xs-8 col-data">'; html+='<strong class="title">'+device['Name']+'</strong><br />'; if(device['Status']=='Off') html+='<span class="state">Afwezig</span>'; else html+='<span class="state">Aanwezig</span>'; if(_SHOW_LASTUPDATE) html+='<br /><span class="lastupdate">'+moment(device['LastUpdate']).format(_LASTUPDATE_FORMAT)+'</span>'; html+='</div>'; return html; }
bsmeding
and the variable _SHOW_LASTUPDATE = true in CONFIG.js?
bsmeding
If I change it it works
also check if you don't hide it in the blocks settings
in CONFIG.js
in custom.js
you can also force the update to change the line
to
in CONFIG.js
var _SHOW_LASTUPDATE = true;
var _LASTUPDATE_FORMAT = 'DD-MM-YY HH:mm'
and
blocks[402] = {}
blocks[402]['icon'] = 'fa-male';
blocks[402]['title'] = 'B';
function getBlock_402(device,idx){ //change 233 to the idx of your device!
var html='';
html+='</div>';
if(device['Status']=='Off') html+='<span class="state">AFWEZIG</span>';
else html+='<span class="state">AANWEZIG</span>';
html+='</div>';
return html;
to
- Schermafbeelding 2017-05-08 om 20.44.27.png (95.13 KiB) Viewed 2611 times
SwordFish
Will check it tomorrow, now not at home.
Thanks for the help
Thanks for the help
godinperson
@htilburgs
I'm not seeing anything. Is it because of my setup? I don't have much right now, only Kodi and outside temperature.
https://www.domoticz.com/forum/viewtopi ... =4&t=17474
lukev
Did you follow the wiki installation guide?godinperson wrote:@htilburgs
https://www.domoticz.com/wiki/Dashticz_V2
godinperson
I did yes! Installation and configuration
This is all I get: I should at least get some buttons or some weather?
- EdwinK
- Domoticz version: BETA
I bet your CONFIG.js is faulty.
