convert Blocky to LUA
poudenes
Domoticz version: 3.8993
Post by poudenes »
Hi Guys,
I have a long list where i change "user variable" to trigger blocky actions. But want to change 1 specific one to make it easier to read.
See attachment what its now and how can i change this into LUA
Thanks for helping and push me in right direction of learning LUA code :)
freijn
Domoticz version: Stable
Re: convert Blocky to LUA
Post by freijn »
Instead of Blocky you select Lua
Please select 'userVarialbel' on the next drop down list !!!
Paste the below code and give it a try :-)
if (uservariables["AllOff"] == "1") then
	uservariables["ComeHome"] == "0"
	uservariables["Evening"] == "0"
poudenes
Post by poudenes »
freijn wrote:Instead of Blocky you select Lua
Thanks !! i give it a shot !!
poudenes
Post by poudenes »
This is not working:
error: 2017-05-08 11:22:31.899 Error: EventSystem: in MAN SCENE ON 17.05.08 (TEST): [string "commandArray = {}..."]:3: syntax error near '=='
the other user variable must updated to 0
if (uservariables["All Off"] == "1") then
    uservariables["Goodnight"] == "0"
    uservariables["Leaving"] == "0"
    uservariables["Morning"] == "0"
    uservariables["Movie"] == "0"
    uservariables["Sexy"] == "0"
    uservariables["TV"] == "0"
elseif (uservariables["ComeHome"] == "1") then
    uservariables["All Off"] == "0"
elseif (uservariables["Evening"] == "1") then
elseif (uservariables["Goodnight"] == "1") then
elseif (uservariables["Leaving"] == "1") then
elseif (uservariables["Morning"] == "1") then
elseif (uservariables["Movie"] == "1") then
elseif (uservariables["Sexy"] == "1") then
elseif (uservariables["TV"] == "1") then
manjh
Post by manjh »
The error is in the "==".
You use "==" to compare, and "="to assign.
for example:
if (a==b) then
	c = 1
	d = 2
	e = 3
Having said this, the way to assign a value to a user variable is not by simply assigning.
I use this to assign a value to variable named "TestVariable":
commandArray['Variable:TestVariable"] = 3
Hans
poudenes
Post by poudenes »
manjh wrote:The error is in the "==".
for example:
if (a==b) then
	c = 1
	d = 2
	e = 3
	commandArray['Variable:ComeHome"] = "0"
	commandArray['Variable:Evening"] = "0"
	commandArray['Variable:Goodnight"] = "0"
	commandArray['Variable:Leaving"] = "0"
	commandArray['Variable:Morning"] = "0"
	commandArray['Variable:Movie"] = "0"
	commandArray['Variable:Sexy"] = "0"
	commandArray['Variable:TV"] = "0"
    uservariables["All Off"] = "0"
    uservariables["Evening"] = "0"
    uservariables["Goodnight"] = "0"
    uservariables["Leaving"] = "0"
    uservariables["Morning"] = "0"
    uservariables["Movie"] = "0"
    uservariables["Sexy"] = "0"
    uservariables["TV"] = "0"
Sp the first IF is the correct one to use?
And how can i given that the variable type must stay as "Integer" (type 0) something like "and uservariables type = "0" ?
commandArray['Variable:ComeHome"] = "0" and uservariables type = "0"
sorry for the dumb question... hehe
manjh
Post by manjh »
Depending on the definition of the variable, you can use "tonumber" or "tostring" functions.
This is the nice thing about Domoticz: simply try it and see what works.
In my server, I have defined a dummy switch called "Testbutton". When I want to test some code, I put it into a LUA script (type "device") like this:
-- Test script
--if devicechanged['Testbutton']  then
    print ("@@@@@@@@ invoking tester")
    -- put the code to be tested here
    print ("@@@@@@@@ ending  tester")
--end
This way I can change the code, press the test button, and see what happens.....trial-and-error, but it's fun!
Hans
freijn
Post by freijn »
apologies yes == was 1 = to much.
quick copy and past error :-(
Thanks Manjh to assist here!
poudenes
Post by poudenes »
Grrr :( it worked. But does someone can tell me if i can use Scene/Group into a device changed? Tried it but don't work.
Have some scenes and when the scene is on, i also want update a user variable.
freijn
Post by freijn »
Please post your code , so we can understand what you are looking for?
I have found this :
commandArray['Scene:Livingroom']='On' -- remember, Scene cannot be turned Off!
The comment at the end is a little 'disturbing' :-(
poudenes
Post by poudenes »
freijn wrote:Please post your code , so we can understand what you are looking for?
I have found this :
Turn on groep All-Off then user variable must goto 1. When turn off then user variable must goto 0
if (Devicechanged["Group:All-Off"] == "On") then
   commandArray['Variable:All-Off"] = "1"
elseif (Devicechanged["Group:All-Off"] == "Off") then
With a switch it is working. But want remove the switch and do some actions directly on the ON/OFF from a group
freijn
Post by freijn »
Then let us know which action please? So we can try to suggest you.
The code you pasted , is from your memory or from your system? As I believe you have some errors in..
poudenes
Post by poudenes »
freijn wrote:Then let us know which action please? So we can try to suggest you.
That is a LUA script inside Domoticz. And yes its not working. Thats why i ask if i can use a scene or group as trigger ... the IF action
freijn
Post by freijn »
poudenes
I do not recognize the "Devicechaed" in your script.
According to my knowledge that is not a valid statement... or I am mistaken ?
poudenes
Post by poudenes »
freijn wrote:poudenes
sorry was a typo must be devicechanged but then its not working
