EdwinK
Post by EdwinK »
I'm trying to switch the title and data from a switch. Normally I would to something like this:
blocks['139_2'] = {}
blocks['139_2']['title'] = 'Luchtvochtigheid';
blocks['139_2']['switch'] = true;
blocks['139_3'] = {}
blocks['139_3']['title'] = 'Baro';
blocks['139_3']['switch'] = true;
But in this case it isn't working. It might not be possible
crashingdutchman
Domoticz version: Latest
Post by crashingdutchman »
Ierlandfan wrote:
crashingdutchman wrote:Would anyone be interested in adding Flightradar24 to his dashboard? I have this setup now and it seems to work nice, although I would like to be able to remove the left part of that site.Image
I was playing with that also. I use this:
frames.flightradar = {height:250,frameurl:"https://www.flightradar24.com/52.8,5/10",width:12}
Gives you the Northern part of Holland. No menu on the left side for me.
Edit, found a better source (thanx to Vliegveld Middenmeer)
https://www.flightradar24.com/simple?la ... 2=altspeed
If you want all aiprplanes you have to delete maxspeed and minspeed. If you only want light aircraft like Microlights, gliders, Cessna, Piper and that kind of airplanes leave them in place.
The 'simple' site where you link to in your edit is not supported anymore by FR24. It works now, but might not work in the future. I noticed that the menu on the left is not there if the screen resolution is smaller.
jake
Post by jake »
how to pull from the beta instead of the stable version? I now use 'git pull', but wat command should I use for pulling the beta?
Verstuurd vanaf mijn K00C met Tapatalk
EdwinK
Post by EdwinK »
I would make a backup of ALL changed file, CONFIG.js custom.css and custom.jss
Then I deleted the dasthicz folder and
git clone https://github.com/robgeerts/dashticz_v2.git
To check if it's really the beta, you can do
 git branche
Hope this helps.
(changed a bit)
jake
Re: RE: Re: Dashticz - General Discussions
Post by jake »
EdKo66 wrote:I would make a backup of ALL changed file, CONFIG.js custom.css and custom.jss
Then I deleted the dasthicz folder and then on https://github.com/robgeerts/dashticz_v2/tree/beta and after that a
 git branche
Hope this helps.
I don't understand your line to go "https://github.com/robgeerts/dashticz_v2/tree/beta" what to do there?
HansieNL
Post by HansieNL »
 git branche
Hope this helps.
In addition to your response:
Run command from your Domoticz www folder and change dashticz if you wanna install to subfolder with other name
git clone https://github.com/robgeerts/dashticz_v2.git --branch beta dashticz
Blah blah blah
EdwinK
Post by EdwinK »
Easier
mlamie
Domoticz version: 3.5877
Post by mlamie »
It looks like the beta version doesn't refresh the Domoticz icons (need to do a browser refresh), The stable version does. Is there a known issue there?
Raspberry Pi 3, RaZberry, RFXtrx433
Various Z-Wave devices, KlikAanKlikUit devices, ESP8266 NodeMCU, Sonoff POW and a Essent E-thermostaat
IP camera: Dahua 4MP IPC-HDBW4421R-AS, Vivotek FD8134V
HansieNL
Post by HansieNL »
mlamie wrote:It looks like the beta version doesn't refresh the Domoticz icons (need to do a browser refresh), The stable version does. Is there a known issue there?
Already reported in Dashticz - Bug report https://www.domoticz.com/forum/viewtopi ... 67&t=17427.
Thanks for asking.
Blah blah blah
lukev
Post by lukev »
Hi all, is there a way to fix the output of a graph in 'last month'? It always flips back to 'today' (which isn't actually a day but a few days...)
EdwinK
Post by EdwinK »
lukev wrote:Hi all, is there a way to fix the output of a graph in 'last month'? It always flips back to 'today' (which isn't actually a day but a few days...)
I don't think so. At least, I've seen this for quite some time nowIt might be on Rob's to-do-list.
tontze
Domoticz version: Beta Ch
Post by tontze »
Hi !
I was trying to get Wikis weather frame to work, but it makes screen blank .. I have done as wiki says :
var frames = {}
frames.weather = {refreshiframe:10000,height:500,frameurl:"http://iltasanomat.weatherproof.fi/tutka.php?map=Etel%C3%A4-Suomi",width:12}
columns[1]['blocks'] = [frames.weather];
Smartthings
zigbee2mqtt
RFLink 433mhz / Nrf 2.4Ghz
Mi Light
esp8266MiLight Hub
robgeerts
Domoticz version: 3.7067
Post by robgeerts »
htilburgs wrote: Error:
About the error, I can confirm that when you have var _STANDBY_AFTER_MINUTES = false; then you get this error. Something is wrong in the main.js file. I wil notice @robgeerts for this.
Put the var _STANDBY_AFTER_MINUTES = 10; than the error is gone for the moment.
Fixed in latest beta!
robgeerts
Post by robgeerts »
Please test this in latest version!
EdwinK
Post by EdwinK »
Hurray.. new updates :)
*goes doing a "git pull"*
mvveelen
Post by mvveelen »
Great, Rob is back with a few fixes :) :)
RPi3b+/RFXCOM rfxtrx433E/Shelly/Xiaomi Gateway/Philips HUE Lights/Atag Zone One/2 SunnyBoy inverters/AirconWithMe/P1 smartmeter/Domoticz latest Beta
blacksn0w
Post by blacksn0w »
Still not working here, have to refresh site to get updated device state.
mvveelen
Post by mvveelen »
Same here, unfortunately.
koowee
Post by koowee »
tontze wrote:Hi !
var frames = {}
I think that you need to add more parameters to "columns", try for example this
var frames = {}
columns[1] = {}
columns[1]['width'] = 4;
screens[2] = {}
screens[2]['background'] = 'bg1.jpg';
screens[2]['columns'] = [1]
Phantom
Domoticz version: 4.11652
Post by Phantom »
When i activate these 2 lines in main.js it works for me (not sure if it has any other impact) but it is also active in the master branche.
				if(typeof(_DEBUG)=='undefined' || _DEBUG===false) setTimeout(function(){ getDevices(); },(_DOMOTICZ_REFRESH*1000));
	else {
Locked
