Dashticz - Show your dashboard and how-to's!
woody4165
Re: Show your Dashticz v2.0 and how-to's!
Post by woody4165 »
poudenes wrote:
Nice Nice. I mounted mine also on the wall. Here screenshot how i did it. i can take off the tablet as well to use it when needed:
p.s. don't look at the background... that was a joke :)
Hi @poudenes
How is the plastic bushing attached to the tablet? Is it removable?
Sorry for my Google translate...
poudenes
Domoticz version: 3.8993
Post by poudenes »
Hi @poudenes
Used double side tape. So you can remove it when you sell the tablet in future :D
EdwinK
Post by EdwinK »
poudenes wrote:
woody4165 wrote: Hi @poudenes
Hope you have strong enough tape, or you might wake up one morning with your tablet on the ground.
woody4165
Post by woody4165 »
poudenes wrote: Used double side tape. So you can remove it when you sell the tablet in future :D
Thanks @poudenes
I think I will go fo this, it will cost me around 16€ and the tablet it will be still removable...
PS: Just checked that is not good for my 7" tablet, it should be at least 17.8cm in the smaller side, an mine is 12...
Aaaargh
rbo0567
Domoticz version: v4.9701
Post by rbo0567 »
[quote="pkrabben"]Here is mine current dashboard still work in process to fine tune.
Adding more smoke detectors this week.
Looks very nice!
How did you hide the switch-value (AAN or UIT) for geofencing and only use the green or red house-icon?
EdwinK
Post by EdwinK »
My dashboard; still a work in progress, but I was asked to show it. So.. here you go.
Config.js
var _LANGUAGE = 'nl_NL'; //or en_US
var _HOST_DOMOTICZ = 'http://192.168.0.10:8084';
var _DOMOTICZ_REFRESH = 10; //in seconds
var _THEME = 'default'; // default = dashticz default theme
var _HOST_ZIGGO_HORIZON = ''; //e.g. http://192.168.1.3/domoticz/switch_horizon.php';
var _APIKEY_WUNDERGROUND = '<API>>';
var _WEATHER_CITY = 'Rhoon';
var _WEATHER_CITYNAME = 'Albrandswaard';
var _WEATHER_COUNTRY = 'NL';
var _USE_DUTCH_TRAFFICINFO = false;
var _USE_DUTCH_TRAININFO = false;
var _BACKGROUND_IMAGE = 'background.jpg';
var _USE_AUTO_POSITIONING = false;
var _USE_FAVORITES = false;
var _HIDE_SECONDS_IN_CLOCK = false;
var _HIDE_MEDIAPLAYER_WHEN_OFF = false;
var _NEWS_RSSFEED = 'http://www.nu.nl/rss/algemeen';
var _USE_FAHRENHEIT = false;
var _USE_BEAUFORT = true; //Bft instead of m/s
var _SHOW_LASTUPDATE = false;
var _LASTUPDATE_FORMAT = 'DD-MM-YY HH:mm';
var _STANDBY_AFTER_MINUTES = false;
var _IDXmoonpicture = 1; //index of the uservariabele MoonPicture
var _SCREENSLIDER_EFFECT = 'slide';
var _DASHTICZ_REFRESH = 30; //in minutes
// trafic map
var _APIKEY_MAPS = 'API';
var _MAPS_LATITUDE = 51.860067;
var _MAPS_LONGITUDE = 4.412692;
var _MAPS_ZOOMLEVEL = 11;
//predefined colors, when you have RGB-lamps
var _SAVED_COLORS = ['black', 'white', 'blanchedalmond','rgb(255, 128, 0);', 'hsv 100 70 50', 'lightyellow'];
// calendar
[[removed for privacy]]
calendars.combined = {}
calendars.combined.calendars = [
{ color:'white',calendar:calendars.first },
{ color:'#ccc',calendar:calendars.second },
{ color:'#ccc',calendar:calendars.third }
calendars.combined.url = 'https://www.icloud.com/#calendar';
var buttons = {}
buttons.buienradar = {width:12, isimage:true, image: 'http://api.buienradar.nl/image/1.0/Rada ... =285&h=256', url: 'http://www.weeronline.nl/Europa/Nederland/Rhoon/4057944'}
buttons.moon = {width:12, isimage:true, refreshimage:60000, image: 'moon'}
//CUSTOM POSITIONING:
var blocks = {}
blocks['blocktitle_1'] = {}
blocks['blocktitle_1']['title'] = 'Schakelaars';
blocks['blocktitle_2'] = {}
blocks['blocktitle_2']['title'] = 'Weer';
blocks['blocktitle_4'] = {}
blocks['blocktitle_4']['type'] = 'blocktitle';
blocks['blocktitle_4']['title'] = 'Energieverbruik';
blocks['blocktitle_5'] = {}
blocks['blocktitle_5']['type'] = 'blocktitle';
blocks['blocktitle_5']['title'] = 'Gas';
blocks['blocktitle_6'] = {}
blocks['blocktitle_6']['type'] = 'blocktitle';
blocks['blocktitle_6']['title'] = 'Media - Film';
blocks['blocktitle_8'] = {}
blocks['blocktitle_8']['type'] = 'blocktitle';
blocks['blocktitle_8']['title'] = 'Media - Radio';
blocks['blocktitle_9'] = {}
blocks['blocktitle_9']['type'] = 'blocktitle';
blocks['blocktitle_9']['title'] = 'Synology usage';
blocks['blocktitle_10'] = {}
blocks['blocktitle_10']['type'] = 'blocktitle';
blocks['blocktitle_10']['title'] = 'Synology Drives';
blocks[1] = {}
blocks[1]['width'] = 4;
blocks[104] = {}
blocks[104]['title'] = 'Thermostaat';
blocks[104]['switch'] = true;
blocks[105] = {}
blocks[105]['title'] = 'Temperatuur'
blocks[105]['switch'] = true;
blocks[113] = {}
blocks[113]['switch'] = true;
blocks[113]['width'] = 8;
blocks[113]['icon'] = 'fa-tint';
blocks[115] = {}
blocks[115]['image'] = 'Ping.png';
blocks[116] = {}
blocks[116]['icon'] = 'fa-upload';
blocks[117] = {}
blocks[117]['icon'] = 'fa-download';
blocks[142] = {}
blocks[142]['width'] = 12;
blocks[142]['icon'] = 'fa-trash-o';
blocks[120] = {}
blocks[120]['icon'] = 'fa-moon-o';
blocks[120]['title'] = 'Maan';
blocks[120]['switch'] = true;
blocks[123] = {}
blocks[123]['icon'] = 'fa-moon-o';
blocks[123]['title'] = 'Maan fase';
blocks[123]['width'] = 12;
blocks[123]['switch'] = true;
blocks[124] = {}
blocks[124]['icon'] = 'fa-male';
blocks[124]['width'] = 12;
blocks[124]['title'] = 'Edwin';
blocks[128] = {}
blocks[128]['switch'] = true;
blocks[128]['icon'] = 'fa-tint';
blocks[129] = {}
blocks[129]['switch'] = true;
blocks[132] = {}
blocks[132]['switch'] = true;
blocks[133] = {}
blocks[133]['switch'] = true;
blocks[134] = {}
blocks[134]['icon'] = 'fa-hdd-o';
blocks[134]['title'] = 'HDD 1 / backup';
blocks[134]['switch'] = true;
blocks[135] = {}
blocks[135]['title'] = 'Virt. Memory';
blocks[135]['switch'] = true;
blocks[136] = {}
blocks[136]['icon'] = 'fa-hdd-o';
blocks[136]['switch'] = true;
blocks[137] = {}
blocks[137]['icon'] = 'fa-hdd-o';
blocks[137]['switch'] = true;
blocks[138] = {}
blocks[138]['icon'] = 'fa-hdd-o';
blocks[138]['switch'] = true;
blocks[139] = {}
//blocks[139]['title'] = 'Temperatuur';
blocks[139]['switch'] = true;
blocks[140]= {}
blocks[140]['switch'] = true;
blocks[141]= {}
blocks[141]['switch'] = true;
blocks[142]= {}
blocks[142]['icon'] = 'fa-trash';
blocks[142]['switch'] = true;
blocks['s2'] = {}
blocks['s2']['width'] = 12;
blocks['s2']['icon'] = '';
//defining number of columns, their contents en widths
//width can be a number 1 to 12, but total widths of all columns should always be 12
var columns = {}
columns[1] = {}
columns[1]['blocks'] =
['blocktitle_1','s1',104,105,91,51,99,125,52,53,54,55,56]//[calendars.combined] //idx 104 = Setpoint. 57 - 62 reserve KaKU
columns[1]['width'] = 5;
columns[2] = {}
columns[2]['blocks'] = ['blocktitle_2','currentweather_big','weather',113,128,129,'139_2',140,141]
columns[2]['width'] = 5;
columns[3] = {}
columns[3]['blocks'] = ['clock','sunrise',124,142,buttons.moon,123]
columns[3]['width'] = 2;
columns[4] = {}
columns[4]['blocks'] = ['blocktitle_4','graph_109','109_1','109_2']
columns[4]['width'] = 6;
columns[5] = {}
columns[5]['blocks'] = ['blocktitle_5','graph_110']
columns[5]['width'] = 6;
columns[6] = {}
columns[6]['blocks'] = ['blocktitle_6',48,49]
columns[6]['width'] = 5;
columns[7] = {}
columns[7]['blocks'] = ['s2']
columns[7]['width'] = 2;
columns[8] = {}
columns[8]['blocks'] = ['blocktitle_8',130,131]
columns[8]['width'] = 5;
columns[9] = {}
columns[9]['blocks'] = ['blocktitle_9',132,133,135]
columns[9]['width'] = 6;
columns[10] = {}
columns[10]['blocks'] = ['blocktitle_10',134,136,137,138]
columns[10]['width'] = 6;
//if you want to use multiple screens, use the code below:
var screens = {}
screens[1] = {}
screens[1]['background'] = 'background.jpg';
screens[2] = {}
screens[2]['background'] = 'background.jpg';
screens[2]['columns'] = [4,5] //blocks can be size 6
screens[3] = {}
screens[3]['background'] = 'background.jpg';
screens[3]['columns'] = [6,7,8]
screens[4] = {}
screens[4]['background'] = 'background.jpg';
screens[4]['columns'] = [9,10]
var columns_standby = {}
columns_standby[1] = {}
columns_standby[1]['blocks'] = ['clock','currentweather_big','weather']
Custom.css
.col-data .title {
font-size:15px;
.col-data span {
font-size:15px;
#graphoutput109 { height:150px;}
#graphoutput110 { height:150px;}
.fa.fa-male.on {color: green}
.fa.fa-male.off {color: red}
.fa-male:before{font-size: 36px;}
.swiper-pagination-bullet {
width: 0px;
height: 0px;
.fa,.wi {
font-size:24px !important;
.fa.fa-lightbulb-o.on {
color: rgba(255, 220, 10, 0.9);
/* Background blocks */
.transbg.col-xs-1,
.transbg.col-xs-2,
.transbg.col-xs-3,
.transbg.col-xs-4,
.transbg.col-xs-5,
.transbg.col-xs-6,
.transbg.col-xs-7,
.transbg.col-xs-8,
.transbg.col-xs-9,
.transbg.col-xs-10,
.transbg.col-xs-11,
.transbg.col-xs-12 {
padding-top:15px;
padding-bottom:15px;
border: 7px solid rgba(255,255,255,0);
background: rgba(0,0,0,0.2);
background-clip: padding-box;
border-radius: 25px; /* Round corners */
Custom.js
//add custom javascript in here
function afterGetDevices(){
function getExtendedBlockTypes(blocktypes){
return blocktypes;
function getBlock_124(device,idx){ //change 233 to the idx of your device! //old one 124
$('.block_'+idx).attr('onclick','switchDevice(this)');
var html='';
html+='<div class="col-xs-4 col-icon">';
if(device['Status']=='Off') html+=iconORimage(idx,'fa-toggle-off','','off icon');
else html+=iconORimage(idx,'fa-toggle-on','','on icon');
html+='</div>';
html+='<div class="col-xs-8 col-data">';
html+='<strong class="title">'+device['Name']+'</strong><br />';
if(device['Status']=='Off') html+='<span class="state">AFWEZIG</span>';
else html+='<span class="state">AANWEZIG</span>';
if(_SHOW_LASTUPDATE) html+='<br /><span class="lastupdate">'+moment(device['LastUpdate']).format(_LASTUPDATE_FORMAT)+'</span>';
html+='</div>';
return html;
pkrabben
Domoticz version: 3.5877
Post by pkrabben »
rbo0567 wrote:
pkrabben wrote:Here is mine current dashboard still work in process to fine tune.
Looks very nice!
You can hide this with
blocks[idx]['hide_data'] = true;
gielie
Domoticz version: latest β
Post by gielie »
EdKo66 wrote:My dashboard; still a work in progress, but I was asked to show it. So.. here you go.
Looks really nice Ed, I'm gonna copy some stuff from your config.
- Aeotec MultiSensor 6
- FIBARO FGS223
- FIBARO FGWPE Wall Plug
- Neo CoolCam Power plug
- Popp Smoke Detector
- Toon
- Kodi Media Server
ropske
Domoticz version: V3_8394
Post by ropske »
Config.js
// trafic map
// calendar
var buttons = {}
var blocks = {}
blocks[1] = {}
blocks[104] = {}
blocks[105] = {}
blocks[113] = {}
blocks[115] = {}
blocks[116] = {}
blocks[117] = {}
blocks[142] = {}
blocks[120] = {}
blocks[123] = {}
blocks[124] = {}
blocks[128] = {}
blocks[129] = {}
blocks[132] = {}
blocks[133] = {}
blocks[134] = {}
blocks[135] = {}
blocks[136] = {}
blocks[137] = {}
blocks[138] = {}
blocks[139] = {}
blocks[140]= {}
blocks[141]= {}
blocks[142]= {}
blocks['s2'] = {}
var columns = {}
columns[1] = {}
columns[2] = {}
columns[3] = {}
columns[4] = {}
columns[5] = {}
columns[6] = {}
columns[7] = {}
columns[8] = {}
columns[9] = {}
columns[10] = {}
var screens = {}
screens[1] = {}
screens[2] = {}
screens[3] = {}
screens[4] = {}
Custom.css
.col-data .title {
font-size:15px;
.col-data span {
font-size:15px;
width: 0px;
height: 0px;
.fa,.wi {
.transbg.col-xs-1,
.transbg.col-xs-2,
.transbg.col-xs-3,
.transbg.col-xs-4,
.transbg.col-xs-5,
.transbg.col-xs-6,
.transbg.col-xs-7,
.transbg.col-xs-8,
.transbg.col-xs-9,
.transbg.col-xs-10,
.transbg.col-xs-11,
padding-top:15px;
Custom.js
return blocktypes;
var html='';
html+='</div>';
html+='</div>';
return html;
Can you post again please? I can't see you picture :)
Jonb
Post by Jonb »
Dashboard at the beginning. Now busy with complete restyle and functionality. Will upload my new picture soon. This was the traditional first version of the dashboard :D
corbin
Post by corbin »
pkrabben wrote: Can I ask where you found the motion icons (moving man) I cant find then in the icon gallery
thanks in advance for your reply
They are the defaults for motion sensors, but images rather than icons and located at:
img/motion_off.png
img/motion_on.png
See Custom Positioning: https://www.domoticz.com/wiki/Dashticz_V2_-_Positioning
pkrabben
Post by pkrabben »
img/motion_off.png
img/motion_on.png
Thanks I found the issue inside Domoticz I didn't set the switch to a Motion sensor.
EdwinK
Post by EdwinK »
Changed my background.
The empty site on the left will one day, hopefullt, hold my calendars
ropske
Post by ropske »
is it something at me, but i can't see EdKo66 his pictures :s and i'm curious to see what he realized :)
EdwinK
Post by EdwinK »
Strange. They are really there.
Maybe somehow either your ISP blocked postimg.org, or there is something wrong with your internet.
EdwinK
Post by EdwinK »
Maybe this works
poudenes
Post by poudenes »
My own creation to implement "NS Vertrektijden" Have created a .PHP on my VPS and created a API Account at NS (Free, and you can do 50.000 request a day) Maybe when people wants it it can be build into Dashticz and Rob creates a nice block editable script for it?
See a code problem... the platform number is not in center.. haha
SwordFish
Domoticz version: V4.11375
Post by SwordFish »
poudenes wrote:My own creation to implement "NS Vertrektijden" Have created a .PHP on my VPS and created a API Account at NS (Free, and you can do 50.000 request a day) Maybe when people wants it it can be build into Dashticz and Rob creates a nice block editable script for it?
Looks really nice
Would be nice to have it into Dashticz
pkrabben
Post by pkrabben »
This looks very nice and I'm interested to have this inside Dashticz
robgeerts
Domoticz version: 3.7067
Post by robgeerts »
If you can create a public url (with apikey as parameter), I can create a block for this..
