when not sure where to post, post here and mods will move it to right forum .
Moderators: leecollings , remb0
Lebo2d9
Posts: 139 Joined: Tuesday 06 September 2016 20:39
Domoticz version: L stab
Post
by Lebo2d9 » Wednesday 03 May 2017 20:40
I want to implement a switch that i want to turn on when my drive time in Waze to home is 30 minutes or less.
Does someone know if this is possible?
I know there is already a lot concerning waze on this forum but I didn't start reading it yet
Kind regards
Domoicz on RPI3 (wifi) directly connected 3x ds18b20 for CV temp, Evohome (9 zone), 1 remote 220V switch based on ESP-12. RFXtrx433E, 16x AMST-606, 5 Somfy RTS motors
Domoticz on RPI3(wifi) as slave for terraruim control
More to come
Lebo2d9
Post
by Lebo2d9 » Friday 05 May 2017 10:04
this what i have for the moment.
A script that does the calculation for the drive time. But with fixed value's.
Now i want to extract koenx, koeny, luciex and luciey from mosquito_sub but I don't know how to do this.
Cam someone help me ?
#!/bin/bash
## user variables
DOMOTICZ_SERVER="127.0.0.1:8080"
IDXK="356" ## IDX dummy Drive time Koen
IDXL="357" ## IDX dummy Driver time Lucie
homex="4.XXXX" ## Home
homey="50.XXX"
koenx="" ## Koen MQTT lat
koeny="" ## Koen MQTT lon
luciex="" ## Lucie
lucieY=""
tmpfileK="/tmp/wazeKoen.txt"
tmpfileL="/tmp/wazeLucie.txt"
log="/tmp/wazelog.txt"
rm -rf $log
rm -rf $tmpfileK
rm -rf $tmpfileL
#echo "Start." > $log
##MQTT location koen
## CURL route Koen
urlK='https://www.waze.com/row-RoutingManager/routingRequest?from=x%3A'$koenx'+y%3A'$koeny'&to=x%3A'$homex'+y%3A'$homey'&returnJSON=true&returnGeometries=true&returnInstructions=true&timeout=60000&nPaths=1&clientVersion=4.0.0&options=AVOID_TRAILS%3At%2CALLOW_UTURNS'
/usr/bin/curl -s -o $tmpfileK $urlK
#echo "urlK : "$urlK >> $log
## Sleep to avoid 503 errors
sleep 5
## CURL route Lucie
urlL='https://www.waze.com/row-RoutingManager/routingRequest?from=x%3A'$luciex'+y%3A'$luciey'&to=x%3A'$homex'+y%3A'$homey'&returnJSON=true&returnGeometries=true&returnInstructions=true&timeout=60000&nPaths=1&clientVersion=4.0.0&options=AVOID_TRAILS%3At%2CALLOW_UTURNS'
/usr/bin/curl -s -o $tmpfileL $urlL
#echo "urlL : "$urlL >> $log
## calc Koen
tempstrajetminsK=$(/usr/bin/jq -r .response.results[].crossTime $tmpfileK | /usr/bin/awk '{s+=$1} END {print s}' | /usr/bin/awk '{sum = $1 / 60 ; print sum }' | /usr/bin/cut -f1 -d\. )
#echo "Drive time Koen : "$tempstrajetminsK >> $log
## calc Lucie
tempstrajetminsL=$(/usr/bin/jq -r .response.results[].crossTime $tmpfileL | /usr/bin/awk '{s+=$1} END {print s}' | /usr/bin/awk '{sum = $1 / 60 ; print sum }' | /usr/bin/cut -f1 -d\. )
#echo "Drive time Lucie: "$tempstrajetminsL >> $log
## Results
echo "Drive time Koen : $tempstrajetminsK min"
echo "Drive Time Lucie : $tempstrajetminsL min"
## updating dummy sensors
updateK='http://'$DOMOTICZ_SERVER'/json.htm?type=command¶m=udevice&idx='$IDXK'&nvalue=0&svalue='$tempstrajetminsK
updateL='http://'$DOMOTICZ_SERVER'/json.htm?type=command¶m=udevice&idx='$IDXL'&nvalue=0&svalue='$tempstrajetminsL
#echo "URL Update K : "$updateK >> $log
#echo "URL Update L : "$updateL >> $log
/usr/bin/curl -s $updateK &
/usr/bin/curl -s $updateL
exit 0
More to come
