Esp-12 i.c.m Rotary encoder
Everything about esp8266 and more.
rhendriks
Domoticz version: Newest
Post by rhendriks »
I have made an dimmer with a slider in Domoticz, this works great.
But now I want connect an Rotary encoder to the esp in the place of a wallswitch.
Technical no problem , only the software I don't know.
Can anyone tel me how I can make A Rotary encoder to an esp-12 en read out?
How can I set this in "rules" en sent to Domoticz and so that the slider moves to.
I Have ever an Rotary program with picbasic , see below.
If PORTB.0 = 1 Then
  If PORTB.1 = 1 Then
    Dec teller
  Else
    Inc teller
  EndIf
For teller is the dim value.
heggink
Domoticz version: 12451
Re: Esp-12 i.c.m Rotary encoder
Post by heggink »
What did you use for the dimmer with esp?
Verstuurd vanaf mijn HUAWEI NXT-L29 met Tapatalk
DASHTICZ 🙃
P1 meter & solar panel
rhendriks
Post by rhendriks »
heggink wrote:What did you use for the dimmer with esp?
I want to use an separate rotary encoder.
And connect to 2 inputs from the esp.
heggink
Re: RE: Re: Esp-12 i.c.m Rotary encoder
Post by heggink »
Have you looked at https://www.tindie.com/products/nEXT_EV ... er-mpdmv41 ?
DASHTICZ 🙃
rhendriks
Post by rhendriks »
I have seen this but the problem is that , if I set the external potmeter to 100% , I can't dim it with a ipad.
The electronics is not the problem but the software I don't understand.
rhendriks
Post by rhendriks »
Below is the schematic how I want to do it.
The Rotary encoder has four different possibilities, to looking for these, this can determine the direction.
And than prog the output to +1 or -1.
