I am French, excuse me for my bad English and if these evolutions have already been proposed.
Dear developers,
I propose two evolutions in the timer of the switches
1) In "Command" add "close or decrease" and "open or increase"
In addition to "On" and "Off"
example :
Close 50% for a shutter, runs only if the shutter position is > 50%
Open 35% for a shutter, runs only if the shutter position is < 35%
Decrease 50% for a dimmer, only run if the lamp is > 50%
2) In the condition "When" add option:
"User variable name" / "equal or different" / "value to be entered"
To manage public holidays or other personal conditions
example :
May 01 = public holiday, the variable "WeekEnd or Holidays" is assigned to "True" by a LUA program. The Week End is at "True", the other days it is at "False".
In the timer of the shutters in place of "Weekends" I use the condition:
Variable "WeekEnd or Holidays" = "True" and my shutters are managed on a public holiday like the WeekEnd.
Thank you and best regards.
Add "Close" and "Open" in the timer of the switches and new "When" condition
- emme
- Domoticz version: latest
Re: Add "Close" and "Open" in the timer of the switches and new "When" condition
I'm not a programmer... but I think this cannot be done with UI by a limitation in the system design... but of course this can be done with no problems in LUA...
you should just check the sValue of your blind (otherdevices_svalues) and act by consequence....
I have the same scenario: blinds came up at 7.00 on working days, but on weekend/holydays they are not supposed to move...
to do this, I have a dummy switch (WORKING DAY ALARM) seto on/of... with a timer on it... I switch it off automatically on weekends, or by a specifica date/time...
than the code check blinds position, the switch status and take the needed actions
ciao
M
ciao
M
"We always done this way"
phil8785
- Domoticz version: 3.5877
How do you do ? without creating blockly or LUA scripts ?I have the same scenario: blinds came up at 7.00 on working days, but on weekend/holydays they are not supposed to move...
My proposition: Allow a non-specialist programming user to set up specific conditions without creating blockly or LUA scripts.
Resuming an already existing LUA script that updates a variable or a dummy switch and can customize the timer at will would be a welcome simplification.
I have a timer that closes a shutter at 35%, 2 hours after sunset to allow the cats to return. But if the shutter was closed manually before this command, it reopens to 35% (and cats go up !!!). Hence my proposal to add "open" or "close" in addition to "On" and "Off", without script LUA or blockly.than the code check blinds position, the switch status and take the needed actions
Is there a way to do these operations without freezing them in a LUA or blockly script. I wish my wife and children could adapt the timer to the daily without knowing anything about programming
Thank you for your feedback.
Phil.
pvm
- Domoticz version: 4.10538
In my opinion blockly is the way to go, especially for the less experienced users. Similar to the fibaro, zipato solutions.
The homey is also quite similar but a bit more user friendly with their building blocks.
- emme
it could be a solution to implement a sValue check in Blocky, but remember you cannot make neasted condition in LUA (neither in fibaro HC I suppose)
I have a script in case of rain that sets 2 different level based on the windows state: of it's open close completely the shade, if closed set to 75%, but if the shade is already over 75% it does nothing
this cannot be done in Blocky since there are 2 or 3 if-neasted that is not supported
what you suffest is a control like:
set LEVEL YY IF XX
where YY is the level % and XX is an operator (less or greater).... right?
set LEVEL YY IF XX
phil8785
in timer of switches shutters
I have :
What I propose
Close (35%) => The command ON (35%) is executed only if the position of the shutter is > 35% (for Shutter, Blinds, Dimmer)
Open (70%) => The command ON (70%) is executed only if the position of the shutter is < 70% (for Shutter, Blinds, Dimmer)
"Var1"="true" => The command is executed only if the variable named var1 is true ("Var1"="true" only the Open days for exemple)
"Var2">3 => The command is executed only if the variable named var2 is greater than 3
I have :
Active Type Date Time Randomness Command Day
Yes After Sunset 02:00 Yes ON (35%) Weekdays
Active Type Date Time Randomness Command Day or Condition
Yes After Sunset 02:00 Yes Close (35%) "Var1"="true"
Yes After Sunrise 00:15 Yes Open (70%) "Var2">3
pvm
You can fix nested ifs with AND and ORs
