I tried the Windows 10 IoT on Raspberry P3 and it works fine, but I can't install Domoticz on it.
Does anyone tried it yet? And does it work?
Domoticz on Windows 10 IoT?
ErnstPD
- Domoticz version: V3.8153
Hardware:
- Raspberry Pi 3B/3B+ and Banana Pi M3 with:
Honeywell evoHome (Wifi)
Philips Hue (v2)
P1-meter
SolarEdge (Web API)
- Raspian Stretch lite with:
Domoticz
SweetPants
Re: Domoticz on Windows 10 IoT?
I don't think this will workErnstPD wrote:I tried the Windows 10 IoT on Raspberry P3 and it works fine, but I can't install Domoticz on it.
tontze
- Domoticz version: Beta Ch
For my knowledge, you need to compile programs for win10 iot. Windows progs wont run directly in it :/
Smartthings
zigbee2mqtt
RFLink 433mhz / Nrf 2.4Ghz
Mi Light
esp8266MiLight Hub
Smartthings
zigbee2mqtt
Mi Light
esp8266MiLight Hub
ErnstPD
Microsoft says that it can run WUP and win32.exe on the website. That sounds like it should be possible in one way or the othertontze wrote:For my knowledge, you need to compile programs for win10 iot. Windows progs wont run directly in it :/
I saw at Microsoft a developer kit to (re)compile an executable. I tried it and after 24 hours with no processor load I quit the tasks.
But it should also be possible to compile if you have the source.
I do have the kit, but I can't find the full source code. On githubs you can find a lot, but I don't know which one to use?
Hardware:
Philips Hue (v2)
P1-meter
SolarEdge (Web API)
Domoticz
