dzVents 1.1.2 install problem
emme
Domoticz version: latest
Post by emme »
Ciao,
tring to install dzVents 1.1.2 on my pi3 running 3.7377...
I have a stange error log:
EventSystem: in /home/pi/domoticz/scripts/lua/script_device_main.lua: /home/pi/domoticz/scripts/lua/dzVents/Domoticz.lua:317: attempt to call field 'log' (a nil value)
Authentication should be ok settings are configured with the LAN ip (not the localhost)... and cannot figure out what's worng :(
did you get a similar problem before?
ciao
M
"We always done this way"
tontze
Domoticz version: Beta Ch
Re: dzVents 1.1.2 install problem
Post by tontze »
I just yesterday installed it on my raspb, works fine.
Smartthings
zigbee2mqtt
RFLink 433mhz / Nrf 2.4Ghz
Mi Light
esp8266MiLight Hub
emme
Post by emme »
Uh.. found it!!!
I had a Utils.lua file with my functons in it in the lua folder...
that was the error...
It might be a good idea to specify in the installation instruction that you should NOT have a Util.lua file in your script folder (or any other lua file included in dzVents :P)
ciao
M
