I just started using Domoticz (on a Pi3) and it looks very promising!
Having a Smart Meter with P1 interface (DSMR v4.2 Landis+Gyr 350), I would like to collect usage data over the network as my Pi is not near the Smart Meter. I stumbled upon this very nice article (http://domoticx.com/p1-poort-slimme-met ... z-esp8266/) with ready to run code based on a ESP8266 WiFi SoC.
One thing that puzzles me is what to do on the Domoticz side to receive and collect the data. I installed a 'P1 Smart Meter with LAN interface' in Domoticz, but that seems to be the wrong device since it wants to collect data on its own by polling a remote device, while the code on the ESP8266 wants to send the data to Domoticz as well.
I need a little help to point me in the right direction. Where should I configure what, to have Domoticz receive and collect data sent by the ESP8266?
Domoticz settings for sending P1 smart meter data over network
- Domoticz version: stable
Re: Domoticz settings for sending P1 smart meter data over network
Hi Noppes,
I have configured ser2net which is a program that can transport serial over tcp, for example a small device like a raspberry configured with ser2net which has an IP adres 192.168.0.1 and has a listener on port 3000. With this you are able to select in domoticz hardware P1 Smart meter with lan interface and set the IP adres of 192.168.0.1 and port 3000.
I have no experience with ESP8266 but i think it will work like this.
Thanks for this suggestion. That should work ;o).
Preferably, I would like to do it the other way around: have the P1 interface send it's data to Domoticz instead of having Domoticz poll the device.
so the script updates the domoticz device using json:
You should read the wiki regarding json
If i remember correctly under hardware you need to add a dummy node.
when this is created you can press the Create Virtual Sensors button on it and select a Gas\Energy sensor.
This sensor will then be updated using Json. (test this using your own browser before testing it with the ESP8266
sprintf(url, "http://%s:%d/json.htm?type=command¶m=udevice&idx=%d&nvalue=%d&svalue=%s", domoticzIP, domoticzPort, idx, nValue, sValue);
Thanks. I will give it a try.
That worked like a charm, both for electricity and gas.
Thanks again.
Thanks again.
hi,
it seem to work in your network.
can you help to get it work to.
regards
regards
