With HW acceleration enabled the sliding animation is much smoother, but there is a little graphical glitch at the end (the flashing).
But this superslide project is very old and is not maintanced anymore, isn't there a better option? Like Swiper or any other project.
Thanks, will look into this!
You can change it to Fade instead of Slide function. I did it myself and it has a superb result! 100% smoothly and looks better too!
1. edit your jquery.superslides.js
2. find animation:"slide"
3. change to animation:"fade"
4. done (I'm sure you will like it)
You also can change the speed if you want, for me the standard speed value is great.
Nice solution, but you don't need to change jquery.superslides.js.
This is a virtual switch. If I name it 'Thuis' it gives 'aanwezig' as status. If I leave it, obviously it gets the Domoticz name. In my case 'VirtualPresence'.
The first is the prevered state. But , I it does not show the set icon in that case (see screenshot). Should this be a custom image instead of the font awesome one?
Thx
Ralph
RPi 3B (master): RFXtrx433, Harmony Hub, Z-Wave devices, CoCo units, Hue, Xiaomi Aquara
RPi 2B (slave): P1 connection, MySensors with custom built watermeter sensors on Aquadis+
RPi’s with: Mosquitto MQTT, Home Bridge, Home Assistant (for evaluation only)
Please add this information to the Wiki, it's missing. +add info that graph_IDX === IDX is the actual IDX of the device. I searched for graph_IDX, but I then found that IDX is for device. Thanks.
//There is a bug with this graph with temp+hum+baro (or other multi output device), but we can fix this later if someone going to use it. Priority: low.
Thx
Ralph
This is some custom code Rob has put in main.js for me. Maybe it's better that he removes this part because we have custom.js now.
Thx
Ralph
Well, i had one exception for another user wich had a switch named Thuis. Will change this!
Thx
Ralph
Maybe it was my question, if you remove this, how can i put it back in the custom.css
- Aeotec MultiSensor 6
- FIBARO FGS223
- FIBARO FGWPE Wall Plug
- Neo CoolCam Power plug
- Popp Smoke Detector
- Toon
- Kodi Media Server
madrian wrote:Please add this information to the Wiki, it's missing. +add info that graph_IDX === IDX is the actual IDX of the device. I searched for graph_IDX, but I then found that IDX is for device. Thanks.
Maybe I don't see it, but what information has to be added to the Wiki??
ps. You have also the possibility to add it yourself That's the nuce thing about the wiki Feel free and give it a try.
mvveelen wrote:Is it possible to implement the security panel?
When I add it now, it shows only "off", and I can't switch it on (using a code). Maybe a Dashticz-v2-style pop-up or something ?
Will look into this. Only problem is that I dont have a security panel to test this..
Oh, but I mean the security panel from Domoticz. When you click on the 'security panel switch', it shows a page with the security panel.
Other question:
It seems the nzbget and the traffic add-ons are deleted? In the older versions I see some settings for this, but no documentation for it for the v2. Is that right?
