Gerwin
Re: Domoticz app 2.0
I get unable to get the server configuration information
On the tablet
Gerwin
On the tablet
Gerwin
Re: RE: Re: Domoticz app 2.0
Location is on. Google fit tracks my activity all over twn without any problems. Othwr apps can find my location and i can search. Domoticz finds my location but doesn't fill in the address so I can't select an address for the geofence.Gerwin wrote:Here works geofencing great ,
Location of the phone must be switched on else find he no address
Long. Lat. entry would be a great workaround for me.
Sent from my ZTE A2017G using Tapatalk
Gerwin
See picture
rlschulz
- Domoticz version: 3.5877
I am also getting the "Permissions denied" "These location permissions are needed for Geofencing and to get the Wifi SSID's around you!" I tried to reinstall it from the play store to see if it would help. I also checked the permissions in Apps and it has location enabled. It seems to have started this with the last update.
- galadril
- Domoticz version: latest
Your running beta?rlschulz wrote:I am also getting the "Permissions denied" "These location permissions are needed for Geofencing and to get the Wifi SSID's around you!" I tried to reinstall it from the play store to see if it would help. I also checked the permissions in Apps and it has location enabled. It seems to have started this with the last update.
- galadril
galadril wrote:Your running beta?rlschulz wrote:I am also getting the "Permissions denied" "These location permissions are needed for Geofencing and to get the Wifi SSID's around you!" I tried to reinstall it from the play store to see if it would help. I also checked the permissions in Apps and it has location enabled. It seems to have started this with the last update.
Hmm it looks like the google maps view of the location picker also uses the WRITE_EXTERNAL_STORAGE to cache the google maps..
Can it be that you've not enabled that permissions (needed for settings and more also)?
Can you check the permissions on the settings screen/
- galadril
galadril wrote:galadril wrote:Your running beta?rlschulz wrote:I am also getting the "Permissions denied" "These location permissions are needed for Geofencing and to get the Wifi SSID's around you!" I tried to reinstall it from the play store to see if it would help. I also checked the permissions in Apps and it has location enabled. It seems to have started this with the last update.
I've added the permission check on the latest beta for now
pj-r
- Domoticz version: V3.8650
I have faced this selector thing also and its bit annoying.bueno79 wrote: ---snip---
this type of switch is not manage very well on the apps. It could be great to have the button always display. Currently I need to go in setting, activate option to see ON/Off button (whyyyy?); then I type ON, a combo box appear and I have to choose the mode...not very cool.
If you can do something better...I will be your biggest fan in France
Bueno
Would it be possible to update the selector control to not have the separate On/Off switch?
Only the drop down with off option if its enabled in selector settings.
LXC(x64 Ubuntu Xenial), RFXtrx433E, MySensors
rlschulz
I am using 0.1.391(2757). It still lists that as an error when I use it, but it is working. I also found that it works well with actual switches, but fails with dummy switches. I was trying to get it to open the garage door, if it wasn't already open, by using a dummy switch that checks the door sensor before closing the garage door switch. It works fine when I manually press the dummy switch, and the geofence also works when I use the actual switch. It will not switch the the dummy switch for some reason. It is an awesome app and I thank you for all the hard work you put into it.
I am now on latest beta. Even though I am home, when i start the app I get the "entering" notification?galadril wrote:I recreate all geofences on app restart.olskar wrote:Every time i open the app the geofence triggers, anyone else see this?
But the latest beta has a change that it doesn't set the switch again if it's not needed..
Winne0345
It is possible to change that behavior?galadril wrote:good point.. didn't thought of thatWinne0345 wrote: But it isn't behave like expected. The widget is getting bigger, but font size not.
I tried different launchers and all behave like that. What launcher should i use?
Or is this too complicated?
Hey everyone,
I am having a strange issue - when I turn a virtual switch on/off from dashboard using the Domoticz App, it always triggers the command twice.
This does not happen when I trigger the same switch from the web interface.
Example:
Domoticz App:
2017-04-19 09:17:06.984 User: Administrator initiated a switch command (31/VT_AWAY/On)
2017-04-19 09:17:12.202 EventSystem: Script event triggered: vt_away
2017-04-19 09:17:12.238 User: Administrator initiated a switch command (31/VT_AWAY/On)
2017-04-19 09:17:17.511 EventSystem: Script event triggered: vt_away
Domoticz Web:
2017-04-19 09:13:29.201 User: Administrator initiated a switch command (31/VT_AWAY/On)
2017-04-19 09:13:34.422 EventSystem: Script event triggered: vt_away
Anyone else noticed this behavior?
Example:
Domoticz App:
Domoticz Web:
jannl
- Domoticz version: 2025.5.x
The app always wants to enable wifi scanning for geofencing. I really do not want this because it drains batteries. Besides that geofencing does not work always, looks like the must have been started or so.
Verstuurd vanaf mijn SM-G930F met Tapatalk
- galadril
Sorry not really high om my agenda at this moment..Winne0345 wrote:It is possible to change that behavior?
busy days now I'm rebuilding the total app also for iOS
I think I figured out what is going on here. When a switch triggers a lua scrip that takes a few seconds to run, for some reason the Domoticz App triggers the action twice. This does not happen from the web interface with the same switch and same lua script triggered.tequila wrote:Hey everyone,
Example:
Domoticz App:
Domoticz Web:
In my case, a sript was playing a sound - os.execute ("aplay /home/pi/domoticz/scripts/sounds/sound.wav &") - and I was missing the "&" at the end, so the script was waiting for the sound to finish (5 seconds or something like that).
Once I added the "&" and the script was no longer waiting for the sound, the problem with executing it twice from the Domoticz App disappeared.
do you plan to update the app to be able to be use on ancroid wear 2.0. For now i can't have it
- galadril
sbaloo wrote:do you plan to update the app to be able to be use on android wear 2.0. For now i can't have it
Its not working on 2.0?
I only have old moto 360 1st gen device..
Thomasdc
Thomasdc wrote:Hi!
I have a question regarding the Widgets
I like this because this makes 'shortcuts' right on the home screen from my phone.
But i used to have 'imperihome' and there the 'shortcuts' were not Widgets but simple 'shortcuts' --> this give te benefit of grouping them in a folder
So this i my request --> instead of using widgets, using 'shortcuts' that can be placed in a folder on the homescreen
--> 1X1 widget for togle devices
or add an option 'create shortcut' from a scene/toggleswitch (just like imperihome does)
why?
grouping is just nice, and also to prevent unwanted touches
(i have a button to open the gate --> so when i accidentally push it it will open --> when its in a folder i need to open the folder first and than te button --> that way i wont accidentally open the gate and if i want to open te gate its still verry fast accessible.)
I also have a 'graphic/design' proposal for with the widgets .. would it be possible to add the option 'no background/fully transparant background' ?
is this something that would be possible? those "shortcuts" .. because with the widget it happens that i accidently push it... and then my door is open..
with shortcuts i dont have that problem because i can 'group' them so i have to push first once to open the folder and a second time for opening the door in my case.. so when i accidently open the 'group' i dont have my door opened.
i dont know if its clear what i mean.. otherwise i will try make some screenshots...
- galadril
I think you mean something like this right?Thomasdc wrote: is this something that would be possible? those "shortcuts" .. because with the widget it happens that i accidently push it... and then my door is open..
with shortcuts i dont have that problem because i can 'group' them so i have to push first once to open the folder and a second time for opening the door in my case.. so when i accidently open the 'group' i dont have my door opened.![]()
https://guides.codepath.com/android/Cre ... n-Launcher
Thomasdc
i didn't even think of that, but that seems also nice,galadril wrote:I think you mean something like this right?Thomasdc wrote: is this something that would be possible? those "shortcuts" .. because with the widget it happens that i accidently push it... and then my door is open..
what i meant was just "shortcuts" that appear on the homescreen like 'apps' so you can drag them together so it forms a 'folder'
https://goo.gl/photos/TbqrJ42UcFnZT8WS8
in the link is a video of how i use it with Imperihome
in the video i open the "imperihome" app, the 'scenes' tab, long press it --> and than choose the option 'create chortcut' this way the icon appears on the homescreen of the phone like shown in the video.
when i have serveral i can just drag them togeter.
that way i can not accidently touch it to open my garagedoor.. i first have to open the folder and then click the 'chortcut' to open it..
