I've searched the Wikis and this forum, but can't find answers to these questions.
It must be obvious because several posters have already created plugins successfully.
import Domoticz
Where does this library come from?
Does the plugin run continuously?
How to run new versions of my code?
I hope this doesn't involve restarting Domoticz every time!
Python plugin: how to develop?
- Westcott
ubee
- Domoticz version: 2021.1
Re: Python plugin: how to develop?
The library is provided by the plugin system in Domoticz. Please note the Python plugin support is just available in the beta version.
The plugin executes on specific events by call-back functions.
You have to restart the Domoticz daemon if you update your plugin.
- Westcott
Hi Ubee,
I think I'll stick with my Python equivalent of Egregius' pass2php
- G3rard
- Target OS: -
- Domoticz version: No
Pressing the Update button in the hardware page is most of the times sufficient.ubee wrote: You have to restart the Domoticz daemon if you update your plugin.
At least when changing code in the plugin.py. When you add/change fields to the XML part, then a restart is necessary, but most changes will be to the code and the new code is available after pressing the Update button.
The library is loaded from Domoticz (
Have a look at https://www.domoticz.com/wiki/Developin ... hon_plugin. That gives a lot of additional information.
Not using Domoticz anymore
- Westcott
G3rard, thanks for the extra info!
I had read that wiki, which then prompted my 3 questions.
