Z-wave switches that dont need neutral
tontze
Domoticz version: Beta Ch
Post by tontze »
Hi !
Been trying to find information about z-wave switches that dont need neutral wire. My light switches doesnt have neutral line :(
Anyone ? EU frequencies :)
-T
Smartthings
zigbee2mqtt
RFLink 433mhz / Nrf 2.4Ghz
Mi Light
esp8266MiLight Hub
AimoPaukku
Domoticz version: Stable
Re: Z-wave switches that dont need neutral
Post by AimoPaukku »
Junction box on ceiling has neutral, put module there.
mlamie
Domoticz version: 3.5877
Post by mlamie »
Aeotec Nano Dimmer
http://aeotec.com/z-wave-light-dimmer-switch
Neutral not required.
Nano Dimmer isn’t just better at lighting compatibility, it’s better at wiring compatibility too.
Whether your lights are installed in a 2-wire or 3-wire system, Nano Dimmer is compatible. Lighting Engine auto-detects whether your light switches have a neutral wire or not, then automatically adjusts it settings.
Raspberry Pi 3, RaZberry, RFXtrx433
Various Z-Wave devices, KlikAanKlikUit devices, ESP8266 NodeMCU, Sonoff POW and a Essent E-thermostaat
IP camera: Dahua 4MP IPC-HDBW4421R-AS, Vivotek FD8134V
lost
Post by lost »
tontze wrote:Hi !
-T
The Fibaro FGD-212, if you need a dimmer. I think Fibaro also have simple switches not needing neutral...
Lot's of modules need neutral because they switch the AC at next 0V crossing, which is less stressful especially for heavy/inductive loads.
tontze
Post by tontze »
mlamie wrote:Aeotec Nano Dimmer
This looks perfect, they have also nano switch coming up :)
Smartthings
zigbee2mqtt
Mi Light
esp8266MiLight Hub
jurgen
Domoticz version: stable
Post by jurgen »
Does anyone know if the nano dimmers from eaotec also compatible with domoticz?
mlamie
Post by mlamie »
Domoticz uses OpenZwave. In OpenZwave the new nano dimmer is included 2 months ago see also line 126.
https://github.com/OpenZWave/open-zwave ... ecific.xml
When looking at this OpenZwave Openzwave is included into the Domoticz binary. As long as you don't compiled Domoticz yourself, you will receiver the verion Gizmocuz includes.
viewtopic.php?t=13988
When you do compile Domoticz yourself, you manually can update openzwave.
kdschlosser
Post by kdschlosser »
GE/Jasco also makes a dimmer without a neutral. as a note tho... if you do not have a neutral then you can only use incandescent and halogen bulbs (AC only). so pretty much anything that has a driver or a ballast has to have a neutral wire at the switch and a z-wave dimmer that is capable. I have not come across a dimmer that can do led's or the 12 volt halogens with no neutral. Doesn't mean it doesn't exist tho ¯\_(ツ)_/¯
