JSON: RGBW - How to change color/blightnes separately
Evelen
Domoticz version: 2.4538
Post by Evelen »
Hi.
I have some MiLight pears, and want to use JSON to change DIM level whitout changing current color, also opposite: I want to change color whitout changing DIM level.
Is this posible?
dood1967d
Re: JSON: RGBW - How to change color/blightnes separately
Post by dood1967d »
I have the same question...
thanks
Aad3229
Post by Aad3229 »
Is this solved (possible) yet? I can change a lot of settings with Json, only I don't know the syntax for setting hue and brightness.
Domoticz V4.10717 on Synology, RFXtrx433E USB 433.92MHz Transceiver, 9 x KAKU Switch (APA3-1500R), 1 x ABST-604 KAKU Dusk sensor, MiLight iBox V6, OpenZwave USB-stick Aeon LabS, Zwave PIR, Zwave door sensors, Zwave powerplugs
